Coming Soon
How to Copy Blu-ray Movies in an Easy and Professional Way?
If you want to copy Blu-ray movie and want to copy flexibly with different outputs only using one tool, just give DVDFab Blu-ray Copy a shot. You can use it to copy Blu-ray to Blu-ray disc, or onto the HDD on your PC. And it’s very easy to use. Next please come with me to have a look at it.
Copy Blu-ray Movie > Step 1: Start up DVDFab, choose Copy option, and load in the source
Start up DVDFab 9, and choose Copy option. Then load in the Blu-ray movie by inserting the BD into optical drive. After the movie is in, you can see there’re 4 copy modes for Blu-ray Copy: Full Disc, Main Movie, Customize, Clone/Burn. And we’re going to choose Main Movie mode. You can see that the longest movie title is selected by default, with the audio tracks and subtitles changeable. For the Output, you can choose BD25 or BD50 according to what size do you want for the output. If you want to copy Blu-ray into a Blu-ray disc, just choose a writer for the Save to box; if you want to backup Blu-ray as folder on your HDD, just click folder icon to choose a directory; if you want to backup it as an ISO image file, just choose image icon to select a directory on your PC. BTW, you can preview the title in real time to check all settings. OK. Now click Next button.
Copy Blu-ray Movie > Step 2: Hit Start to begin copy
On the next interface, you can choose to remove HD audio or convert DTS/LPCM audio to AC3 if you like to make the output size smaller. Then hit Start button to start conversion.
During the copy process, you can view detailed progress info.
Alright. Leave the rest to DVDFab. More info about DVDFab Blu-ray Copy, please go to: http://www.dvdfab.cn/blu-ray-copy.htm
  • Discount
    FAB-WYF-OFF
    Jan 30, 2017
    for Buying
    The Universal Master Key
    Price: $60 Buy Now
    World's Best DVD Combo
    to Tackle All DVD Copying/
    Price: $79 Buy Now
