Home »  DVD Copy »
Copy DVD
How to Copy DVD with DVDFab DVD Copy?
DVDFab DVD Copy is powerful and flexible when it comes to copy DVD. In this article, I’ll simply show you how to copy DVD into blank DVD disc with this professional DVD copy software. And it’s very easy to use. Let’s get started now.
Step 1: Start up DVDFab 9, and go to Copy option
Double click on DVDFab 9 desktop icon to start it, then choose Copy option on the welcome screen, and you’ll see this main interface of Copy option.
Step 2: Choose one copy mode, and insert the DVD you want to copy
DVD Copy has many copy modes, and you can freely choose any one you like. Here, let’s use the default Main Movie mode to copy the longest movie title. Now time to insert the DVD disc into optical drive for DVDFab to load it in. When it’s in, the longest movie title will be selected by default, and you can change subtitles, audio tracks of the title. For the output, you can choose to copy it to a DVD5 or DVD9. At last in this step please make sure that the in box behind “Save to”, we choose the writer for DVD burning. By the way, you can preview the title in real time to check if all settings are OK.
Step 3: Start DVD copy
Click Next button to go the next interface, if everything is OK, just hit Start button to start copy. During the process, you can view detailed progress info, even with real time images preview. And you can set your PC to shut down or set the program to auto exit after all tasks are done. You need to notice that in the process, there’ll be one time that you’re prompted to insert a compatible media to start write process, just insert a blank or rewritable DVD5/DVD9 according to what you choose for the Output in the last step. Then write process will begin, and an outstanding DVD copy disc will be in your hands very soon.
OK. Done. For more information about DVDFab DVD Copy, please go to: http://www.dvdfab.cn/dvd-copy.htm
