Coming Soon
How to Rip and Convert DVD to DPG for NDS with DVD to DPG Ripper?
Wanna watch your DVD movie on your NDS? Then you need to convert DVD to DPG video that is compatible on your NDS. DVDFab DVD Ripper is a superior DVD to DPG ripper that performs very well for you to complete this DVD to DPG conversion professionally. Next let’s take a look at how everything is easy and flexible via below tutorial.
Step 1: Start up DVDFab 9, choose Ripper option, and load in the DVD
Choose Ripper option after starting DVDFab 9, then you’ll see the Ripper interface. Insert DVD disc into optical drive, or drag and drop DVD folder/ISO saved on your PC, to load it into DVDFab. When it’s in, the longest movie title will be auto selected, and the audio tracks and subtitles can be chose freely. BTW, you can preview the title in real time in the right part of the interface to check all settings you made during the whole process.
Step 2: Choose DPG profile
Now click Profile box to open profile list. Go to Device, to NDS, then choose this DPG profile.
Step 3: Set and edit freely
Now click Advanced Settings button to set video and audio parameters if you like.
OK. Now back to the main interface to click Edit button to open Video Effect window to Resize source aspect ratio and frame resolution of the video, and/or to crop the output image of the video.
Step 4: Start conversion
After all settings are alright, just hit Start button to start conversion. During the process, you can view detailed progress info, preview progress with images, and choose Exit Program or Shut Down for the time when all tasks are done.
OK, Done. More detail of program can be found at: http://www.dvdfab.cn/dvd-ripper.htm
  • Discount
    FAB-CNN-OFF
    Jan 23, 2017
    for Buying
    The Universal Master Key
    Price: $60 Buy Now
    World's Best DVD Combo
    to Tackle All DVD Copying/
    Price: $79 Buy Now
