Best Performing DVD Creator for Mac and Windows
Summary: You may want to create your own DVDs or DVD folders out of favorite digital video files but still have no idea about that. Or you may want to enjoy DVD viewing experience in your home movie center after creating DVDs by converting digital files. Therefore, it is necessary to filter all these paid or free DVD creating software to find the most convenient and professional one. In this way this article will come to your rescue because you will have a chance to examine the following DVD Creators in the vast market from a professional perspective
- • Burn videos into DVD discs/ISO files/folders
- • User-friendly and easy-to-use
Introduction to DVD Creator
When it comes to DVD Creators, you may refer it to as just making DVDs after converting videos files. That is true that the basic function of DVD Creator is to make DVDs via video conversion. And a lot more value-added functions are varied among different DVD Creators.
These different functions such as assured output quality, personalizing DVD movies or faster conversion speed than normal DVD Creators. And these factors will to a large extent decide which DVD Creator will be the best one in many aspects.
In the following sections there will be a detailed description about best performing DVD Creators and steps to present you rough steps to finish DVD making for your reference to make a careful contrast.
Best Performing DVD Creators for Mac and Windows
It is worth noting that all the following DVD Creators that will be mentioned are available for both Mac and Windows systems. Therefore, there is no need for you to worry about system compatibility but have a try.
DVDFab DVD Creator
DVDFab is known for its comprehensive and professional service in all video-related solution providing, whether DVD Ripper, DVD Copy or DVD Creator. It can always outperform other brands in edging technology-driven core features, accelerated processing speed, high-level image quality as well easy to follow instructions for new starters to finish video converting tasks.
As for DVDFab DVD Creator, it is professional at providing DVD Creation service for more than 80 million global users with more than 200 formats supported. There is no doubt that it almost covers all commonly seen formats, which is outstanding in this aspect.
Featuers
Create DVD from any format: DVDFab DVD Creator can make DVDs from more than 200 video formats including AVI, MP4, MKV, M2TS, FLV, MOV, VOB, Xvid, TS, etc.
Burn any video to DVD blank disc/ Iso/folder: DVDFab Movie Creator enables you to burn homemade videos to a blank DVD disc for storage if you are a real DVD lover. DVDFab DVD creator supports all sorts of disc formats including DVD-9, DVD-5, DVD±R/RW, and DVD±R DL.
Assured high-quality video output: This best DVD Creator allows you to make standard DVDs from homemade videos or videos downloaded from other channels with high-quality video images.
Free to personalize DVD movies via menu templates: With multiple sets of static and dynamic menu templates, you may feel free to make your own DVDs to a higher level.
Pros
- More than 200 video formats are supported for DVD creation
- High-quality video image output
- Free to customize your own DVDs
- 50 times faster DVD burning speed
- User-friendly interface and operating steps
- Operating Guidance of DVDFab DVD Creator
Steps for DVDFab DVD Creator
Step 1: Download DVDFab DVD Creator to your PC
Step 2: Double click the softweare and then drag files you want to convert in to the middle of interface or add files via clicking ADD button.
Step 3: Click the wrench icon and choose the output size and quality you want and then start DVD Creation.
Step 4: Here in the task queue you can check all information throughout the process.
Wondershare DVD Creator
Wondershare DVD Creator is another leading software in making DVDs out of video files. It shows support to more than 150 formats to DVD, DVD folder, blu ray DVD folder, ISO files or blu ray discs.
Almost all popular disc types are supported by this software including DVD-9 and DVD-5; DVD-R/RW, DVD+R/RW, DVD+R DL, DVD-R DL, DVD-RAM; BD-R, BD-RE, BD-25, BD-50, BD-100.
It is quite easy to burn DVDs with only one click, completely easy for everyone. With built-in video editor, you will feel free to edit DVD videos as you wish. For example, you can trim unwanted parts of videos, or adjust video contrast or brightness for a better viewing experience.
Features
Create DVDs with any video: Wondershare is capable of burning videos in 150 formats to DVD, DVD folder, blu ray DVD folder, ISO, blu ray disc. For example, you can create DVDs out of MP4 files, MKV, AVI and other video formats.
Easy to burn DVD with just one click: Wondershare DVD Creator is professional at its user interface design to make it simple for users to quickly burn multiple videos of various formats to a DVD at one without any limitation. With quick creation, users can also enjoy quick resume editing.
Built-in video editor for easy editing: Various kinds of editing functions are supported including trimming, cropping, enhancing videos, removing watermark as well as adding subtitles to your DVD movies.
Empowered CD burner: As a feasible CD burner, Wondershare enables users to burn music to a DVD with an easy and straightforward process. Also, it supports burning MP3 and all other audio formats to create DVDs.
Pros
- Various formats supported to create DVD
- User-friendly steps for DVD creation to save more time
- Built-in video editor to customize your DVDs
- Audio files including music supported to burn into CD
- Offer 100 free DVD templates
Cons
- Blu-ray discs are only available for the windows version
Easy Steps to Create DVD with Wondershare
Step 1: Simple drag video files or photos to the DVD creator
Step 2: Customize your DVD menu due to your own needs
Step 3: Preview and start to burn video or photos to DVD.
Leawo DVD Creator
Leawo DVD Creator can be seen as one of your alternatives to Wondershare due to its comprehensive service for both Mac and Windows systems. As for DVD creation, Leawo DVD Creator provides the easiest-to-use solution for movie fans to convert video and burn videos to DVD discs with abundant access to customization features.
It is a powerful software not only in DVD creation since it is capable of converting various videos of all kinds of formats to DVDs. Together with ingenious video editing features, this DVD creator makes it definitely easy for you to create your own DVDs, even if you are a new starter.
What’s more, it can further act as a 3D DVD creator, which could burn plain 2D to vivid 3D DVD for amazing 3D movie viewing experience.
Features
Free to enjoy all kinds of videos on DVD: No matter what format your videos are in, Leawo DVD Creator enables you to convert and burn videos to DVD-5, DVD-9 disc, folder or ISO files easily.
Built-in editor to customize movies: Leawo DVD Creator provides detailed video editing features to meet specific user requirements with built-in video editor. It allows users to trim or crop videos for your desired video clip. And it enables users to remove black margin and same space for enriched entertainment.
DIY disc menu and templates: Leawo DVD Creator provides 40+ preset free disc menu and templates models for video to DVD burning, specified in Standard, Business, Education, Holiday, Nature, and some other categories.
Create 3D movies with 2D to 3D converter: Featured by 2D to 3D converting ability, Leawo DVD creator could easily create 3D movies out of various 2D videos with multiple formats.
VideoSolo DVD Creator
Generally speaking, VideoSolo is another DVD creator that stands out for its comprehensive features, covering almost all the basic functions demanded by DVD movie fans like creating DVDs of various image quality and editing DVD videos.
Also, it outperforms some new features that will certainly bring you much more convenience while creating DVDs. For example, you can easily add audio if you want since it supports almost all popular audio formats so you can add them for a better experience. Also, you can stylish video subtitles ranging from SRT, SSA to ASS to adjust its position, transparency, and delay to make it fun.
Pros
- Capability to import 3D video, high-definition video in various formats
- Support common used disc type
- Create a professional-looking DVD via editing DVD
- Add audio you want
- Stylish video subtitle
- Merge and split the chapters to make coherent narration.
Cons
- Mac version is unable of creating a video to blu ray disc, folder, or ISO files
- Steps review of VideoSolo DVD Creator
Steps for VideoSolo DVD Creator
Step1: Import video files and then edit and personalize videos with simple clicks
Step2: You may select DVD menu or set background music as you want
Step3: Click button to start to burn into DVDs and bluray discs, folders or ISO files
Final Words
After a detailed introduction of best performing DVD creators of various brands, you must have got a full picture of them. And it is easy to find out that DVDFab DVD Creator is more professional at providing all-around service related to DVD creation. And you may have a try since it provides a free trial.
