DVD Flick is a popular program that allows users to create DVDs from various video files. It is a free and open-source DVD burner, meaning anyone can contribute to its development. However, DVD Flick review shows that it has not been updated since 2009 and is no longer being developed. The last version is 1.3.0.7 released in 2009. There might be some problems with using DVD Flick on the latest Windows operating system and computers. That's why many users looking for alternatives to DVD Flick.
Luckily, there are some great alternatives out there and one of the best ones is DVDFab DVD Creator. In this article, we'll take a look at what this tool has to offer and how it compares to DVD Flick. We will also provide a step-by-step guide on how to use DVDFab to create a DVD. So, let's get started.
Best Free DVD Flick Alternative - DVDFab DVD Creator
DVDFab DVD Creator.
DVDFab DVD Creator
Create DVD disc/ISO/folder from any popular video format and make your own DVD menu via stylish templates & customized options.
Features:
  • Produce studio-level home DVDs out of all formats of videos
  • Support all types of blank discs like DVD±R and DVD±RW
  • Burn the created DVDs to blank discs or save as ISO files/folders
  • Offer multiple sets of beautifully crafted menu templates
  • Output high-quality video for better viewing experience
Furthermore, the best part is it supports 50x faster speed with GPU acceleration including AMD, NVIDIA CUDA, Video ToolBox (macOS), and more. So, it's very fast and you don't have to wait for long periods of time for your DVDs to be created. It also saves output-friendly meta info. and automatically detects and loads DVD-related metadata from the Internet for you. Overall, it's a great alternative to DVD Flick download and we highly recommend it.
DVD Flick:Best Free DVD Flick Alternative - DVDFab DVD Creator
How to Use DVDFab DVD Creator to Create DVDs?
Now that we've gone over the features of DVDFab DVD Creator, let's take a look at how to use it to create DVDs.
Step 1: Download and Install DVDFab
First, you need to download and install DVDFab DVD Creator on your computer. You can get it from the official website. Once it's installed, launch the program and you'll see the main interface.
Step 2: Choose Creator Mode and load the source videos
First, choose the "Creator" mode on the main interface. Load the source video(s) you want to burn with the Add button on the main page, or by simply dragging and dropping the file into the main page.
DVD Flick:How to Use DVDFab DVD Creator to Create DVDs?
Step 3: Customize Your DVD With DVD Creator's Built-in Templates
Select the output size and quality you want after loading your source video. Click the wrench icon, then pick the desired output size and quality. You may also customize your menu by clicking the Set Menu icon next to the Wrench.
DVDFab DVD Creator.
Step 4: Choose Destination Folder ans start Creating
Select the output directory in Save to Part. Once you've selected all the settings, you can click on the "Start" button to start creating your DVD. The process will take some time depending on the size of your video file.
DVDFab DVD Creator step 4.
And that's it! You've successfully created a DVD using DVDFab DVD Creator. As you can see, it's very easy to use and it only takes a few minutes to create a DVD.
Frequently Asked Questions
Q
Why Choose DVDFab DVD Creator as the Best Free Flick Alternative?
There are many alternatives to download DVD Flick but we think that DVDFab DVD Creator is the best one. It is the most effective and quickest DVD Flick alternative with new features being added on a regular basis. It is available on Windows 11, Windows 10, Windows 8, and Windows 7 as well as for Mac.
A
Q
Can DVD Flick support MKV files and convert them to DVD?
Yes. DVD Flick can support MKV files and convert them to DVD. But, many times DVD Flick may don't work or may encounter problems during the conversion process. So, it's better to use an alternative like DVDFab DVD Creator which is more reliable and effective to convert mkv to dvd.
A
Q
What are the system requirements for using DVDFab DVD Creator?
The minimum system requirements for using DVDFab DVD Creator are: Windows 7, 8, 8.1, 10 or 11; Pentium II 500 MHz or above, 2GB of RAM; 20GB of free hard disk space, a DVD drive as well as live internet connection to download the software. But, it's recommended that you have a higher specification computer for better performance.
A
The Bottom Line
DVD Flick, as a DVD maker, is a great program for creating DVDs but it has some limitations. As it is not updated regularly so it may not work with the latest operating systems. So, we recommend that you use DVDFab DVD Creator which is the best free alternative to DVD Flick. It is very easy to use and it offers many features that download DVD Flick doesn't have. Plus, it is regularly updated so you won't have any compatibility issues. Now, you can make your own DVD using DVDFab DVD Creator without any problems.
