DVD Ripper Mac: Ripping Files in an Easier Way!
Summary: Finding a decent DVD ripping software for your device can be tedious, especially when the market is flooded with multiple options. If you, too, are looking for some advanced DVD ripper Mac software, then you are probably at the right place as we have provided you with the top 8 options for the best DVD ripper for Mac. Let us quickly get started.
- • Improve video quality by 300% in collaboration with Enlarger AI
Introduction
Although with the developments in technology, Blu-Ray has replaced the DVDs to quite an extent, but many people still have their DVDs retained as they are packed with their necessary information.
Now is where the DVD ripping tools come in handy to extract the vital information from the DVDs and create a backup copy for emergencies.
Why Do You Need a DVD Ripper?
DVD ripping is the digital extraction of your files. But then, not all of the available DVD ripping software provides you with excellent video quality and more remarkable performance.
A DVD ripper may help you in endless ways, such as :
- Creates a backup or copy of the relevant information and video files
- Relieves you from your dependency on the DVDs
- It helps extract the encrypted DVD information
- Supports changing and customizing the audio and video formats
Here we have eased your work by covering you with some of the selected DVD ripper Mac software with a comparative analysis for a clear and deeper understanding.
Top 8 DVD Ripper for Mac
Here is a list of top 8 DVD Ripper for Mac with an in-depth comparative analysis of all for your greater understanding.
Serial No. |
Product Name |
OS Compatibility |
Price |
1. |
DVDFab DVD Ripper |
Windows 11, 10, 8.1, 8, 7 and Mac 10.10 - 12.3 |
Trial Version: Free Monthly Subscription: $39.99 Annual Subscription: $59.99 |
2. |
Video Solo BD-DVD Ripper |
Windows and Mac |
Annual Fee: US $49.95 Lifetime License Fee: $59.95 |
3. |
Any MP4 DVD Ripper |
Windows and Mac |
Monthly Subscription Fee: $21.75 Lifetime License Fee: $44.25 |
4. |
MacX DVD Ripper Free Edition |
Mac |
Free version |
5. |
WinX DVD Ripper Platinum |
Windows and Mac |
Annual Fee: $29.95 Lifetime License Fee: $47.95 Family License: $69.95 |
6. |
Leawo DVD Ripper |
Windows and Mac |
Annual Subscription Fee: $29.95 Lifetime Plan: $39.95 |
7. |
MakeMKV |
Linux, Windows and Mac |
Free version |
8. |
Handbrake |
Free version |
Let us quickly discuss the thorough details of each DVD Mac ripper one by one.
1. DVDFab DVD Ripper for Mac
Get seamless playback on any device, media player, or home theater
DVDFab DVD Ripper is a professional tool that allows you to convert your DVD, folder, and ISO image file to any digital file either in audio format or a video format at a rapid speed with OS compatibility for both Windows and Mac.
It supports thousands of audio and 2D/ 3D video formats allowing you to convert your output videos to 3D MKV.H.265, 3D AVI, 3D MP4, MKV.4K, MP4, MKV/ MP4 Passthrough, etc., and output audios to WAV, AAC, M4A, DTS, MP3, MP4, etc.
It provides seamless playback services for all devices, including home theaters and media players.
Features:
Some of the many available features of the DVDFab DVD ripper include:
- Easily removes copy protections from DVDs:
DVDFab easily removes the copy protection from the encrypted DVDs to convert them to digital files. You can also convert your DVDs to digital files through multitasking mode.
- Preserves video quality:
DVDFab DVD Ripper preserves the quality of video files even when their size is compressed for mobile devices.
- Excellent quality of audio and video for home theater:
Now rip your DVDs for home theater without compromising on the audio and video quality only through DVDFab DVD Ripper.
- Upscales video resolution through AI enhancements:
DVDFab upscales video resolution from 480p to 1080p seamlessly without compromising on the video quality. It is a good solution as an ai video upscaling software.
- Boosts DVD ripping speed:
With DVDFab, your DVD ripping speed boosts up to 50 times through its advanced use of GPU technology.
How to Rip DVD Using DVDFab DVD Ripper
Now you can rip DVDs following a few basic steps:
- Step 1: Launch after installing the application:
Install and launch the DVDFab DVD Ripper application on your Mac.
- Step 2: Select ripper and add files:
Tap twice on the DVDFab 12, and from the option bar, select ‘Ripper.’ Now, either insert your DVD or tap on the ‘+’ button to load. You can also choose to drag and drop your ISO file.
- Step 3: Select a profile:
Now from the left pane of the interface, select the profile library. Select the profile to be needed once the source gets loaded.
- Step 4: Customize and edit the output video:
Edit your output videos after customizing them by selecting the audio and subtitles of your choice. Then choose the option of ‘Save to’ to select the output path.
- Step 5: Start the ripping process:
Now tap the start button to rip your DVD with the selected profile. Once the task is complete, a progress report will be generated automatically.
2. VideoSolo BD-DVD Ripper
VideoSolo BD-DVD Ripper is another easy-to-use DVD Mac ripper that works equally well on a Windows OS.
It rips a physical DVD into a digital format quite easily and at 6 times faster speed and supports more than 300 output formats for audio and video. You can choose to preserve the audio tracks and subtitles while converting your DVDs to digital files.
Features:
- DVD digitalization to various formats
- Customization for output audios and videos
- Great conversion speed
- High-quality output files
- Enhances the videos
Pros:
- Quick and simple DVD ripping process
- Flawless output quality
- Supports various formats
- Aided with advanced tools
Cons:
- It lacks a video recorder
- Unreliable support system
3. Any MP4 DVD Ripper
Any MP4 DVD Ripper is another Mac DVD ripper that allows you to rip your DVDs quickly with lossless conversions. It helps retain the original quality of the video files even while editing.
You can easily install and launch the software. Then load the disc, click on profile and select your preference. Once everything is set, proceed with the Convert button to start your ripping process.
Features:
- Supports multiple devices
- Supports trim and crop
- Faster conversion speed
- Supports advanced editing features
- Retains original video quality while ripping
Pros:
- Smooth ripping process
- Undamaged ripped files
- Amazing 3D output
- Customizable output parameters
Cons:
- Unavailable forced subtitles
- Outdated interface
4. MacX DVD Ripper Free Edition
MacX DVD Ripper Free Edition is a free DVD ripping software available exclusively for Mac users for an excellent DVD ripping performance.
It does not require third-party tools and can support all the latest and common encryption schemes, including Region Code, Disney X Project DRM, CSS, RCE, etc.
You can load the DVD, select the preferred output format and start the DVD ripping process for seamless results.
Features:
- Rips DVDs for multiple screens
- Builds TV shows and movie libraries
- Creates digital copies of DVDs
- It supports all the DVDs
- Converts DVDs to any format for any device
Pros:
- Easy to use interface
- Supports bulk conversions
- Flexible settings for parameters
- Excellent ripping performance
Cons:
- Unsupported Blu Ray
- It doesn’t work sometimes
5. WinX DVD Ripper Platinum
WinX DVD Ripper Platinum is a DVD ripping software that provides you with a phenomenal DVD ripping experience.
You must simply load your disk, customize your output, and hit the blue button to rip your DVDs quickly. Even the large files get ripped in under 5 minutes, and it supports all the DVD formats and works pretty well on intractable DVDs.
Features:
- All types of DVDs are supported
- Created exclusively for intractable DVDs
- Crops and trims DVDs
- Backs up DVD without losing on video quality
- Multiple input and output formats are supported
Pros:
- High-quality videos
- Great ripping speed
- Video conversion and video editing
- Multiple modes of operations
Cons:
- Watermarks in the free version
- Limited customization
6. Leawo DVD Ripper
Leawo DVD Ripper is a Mac DVD ripper that helps rip DVDs for audio and video for multiple devices. It is compatible with Windows and Mac.
It supports more than 180 formats for converting DVDs to audio and video files. You can easily adjust your parameters for the output videos and audio. It also provides you with multiple facilities, including audio codec, bit rate, video codec, frame rate, etc.
Features:
- It helps remove disc restrictions
- It helps in DVD audio ripping
- Aids in video merging
- Provides customized audio files
- Allows selecting subtitles from the source
Pros:
- Easy and intuitive user interface
- Supports DVD copy protection
- Convenient editing
- Excellent video quality even in compressed files
Cons:
- Only 5 minutes of DVD ripping on the trial version
- Slower ripping process
7. MakeMKV
MakeMKV is a free, standalone, and multilingual DVD ripping software for Linux, Mac, and Windows that allows you to rip protected DVDs in MKV formats. It is really good for beginners.
It offers you a quality video output while preserving the audio and video tracks with their meta information. It supports various file formats such as DVD, Blu-Ray, MKV, ISO, TS, etc.
It also supports the latest AACS and Blu-Ray protection technologies.
Features:
- It helps preserve the meta-information
- It supports saving all audio tracks and video files
- Reads all Blu-Ray and DVD files
- Self-sufficient in decryption
Pros:
- Simple and intuitive UI
- Compatible with Linux, Mac, and Windows
- No watermarks, viruses, and even ad-free
- Great DVD ripping speed
Cons:
- Converts DVD to MKV formats only
- Unsupported video customization
8. Handbrake
Handbrake is another popular open-source DVD ripper Mac software that is free and works on Linux and Windows as well. It is great for advanced users.
It supports better encoding on Mac with powerful video cards. It also aids you in ripping unprotected DVD files. It is one of the most powerful video transcoders and allows you to convert your DVD files in H.264, H.265, H.265 MPEG 4, VP8, VP9, Theora, etc.
Features:
- Resizes and crops the videos
- Restores old and low-quality videos
- Helps in bulk scanning
- Supports various input formats and output formats
- Adds chapter markers
Pros:
- A free and open-source platform
- Supports bulk video conversions
- Supports multiple OS platforms
- Supports multiple presets
Cons:
- Poor playback quality
- Supports only MP4 and MKV format
Frequently Asked Questions
Is the DVD ripper software for Mac safe for use?
Yes. the list of DVD ripper software we provide here is safe for use.
What is the best DVD ripper for Mac that provide the quality output file?
Currently, DVDFab DVD Ripper is the best DVD ripper for Mac that you can avail quality output file.
Is there any Mac freeware DVD ripper available?
MakeMKV, Handbrake, and MacX DVD Ripper Free Edition are some of the available Mac freeware DVD ripper.
Final Words
Selecting one of the best out of the many available options can indeed be a hectic task. But we have already shortlisted some of the best DVD ripper Mac software for your convenience. In the meanwhile, blu-ray burning software can be chosen here. You can select any software according to your usage and need.
If you are still confused regarding which one to choose, then our suggestion would be to opt for DVDFab DVD Ripper as currently, it is the leading DVD ripper for Mac. Not only does it provide you with a seamless DVD ripping experience, but its performance and the goodness of other features are unmatchable.
