Why DVD to MKV and how to convert DVD to MKV? The days of storing all our favorite movies on DVDs are quickly coming to an end thanks to the rise of Blu-ray and easy access to online streaming platforms like Netflix. Then how to deal with your old DVD discs? Converting DVD to MKV is a good choice.
How to convert DVD to MKV files and create a digital collection that you can store locally on your computer or on an external hard drive? You need the help of a DVD to MKV converter. Do you want to convert DVD to MKV for free? Then what freeware should you use? Now, follow me to find the best answer to DVD to MKV conversion.
1. The Best Program to Convert DVD to MKV- DVDFab DVD Ripper
How to rip DVD to MKV? DVDFab DVD Ripper is the best software you can use to convert DVD to MKV on both Windows and Mac. This DVD to MKV converter can rip any type of DVD disc and can even be used to convert ISO files and folders to a format that runs on any compatible media player. Besides DVD to MKV conversion, this DVD to MKV converter also supports other formats as well, such as AVI, MP4, WMV, and more. 3D and 4K formats are also included, as is a conversion from video to audio.
Choose DVDFab DVD Ripper to convert DVD to MKV, the processing speed will be very fast and it supports batch DVD to MKV conversion. Apart from the output formats, you can also choose the output device like the iPhone XS or Samsung Galaxy S9. Want to convert DVD to MKV and personalize the video in the process? No problem. DVDFab DVD Ripper comes with many powerful editing and customization tools that allow you to do exactly that. Now let's learn how this DVD to MKV converter works.
 i  Free Download     i  Free Download
(1) Download DVDFab 12 and choose the "Ripper" Module
How to rip DVD to MKV? DVDFab DVD Ripper is one of the modules of DVDFab 12. So when you launch DVDFab 12, select the "Ripper" module from the top menu. Once there, either insert the DVD disc or click the “Add” button to load your file. Meanwhile, if you want to convert DVD to MKV, especially an ISO file or folder to MKV, simply use the drag & drop method. Thanks to the batch conversion feature, you can convert DVD to MKV in batches. Then, it becomes easy to watch DVD in MKV format on mobile devices or laptops.
Convert DVD to MKV
(2) Set the output format as MKV
hOW TO RIP mkv? With the source loaded up, it’s time to select the format. To do this go to the "Choose Other Profile” in the upper left corner and select ”Format -> Video“. We want to convert DVD to MKV so we’re going to pick MKV as the output format. Also on this panel, you can click the option of "Device" near "Format" to choose the output preset. Click "Audio" to convert DVD to MP3. And improve video quality using the option of "Enlarger AI" while you convert DVD to MKV. DVDFab DVD Ripper is versatile MKV software.
DVD to MKV with DVDFab DVD Ripper
The supported output video formats by this MKV software ripper include AVI, FLV, M2TS, MKV, MP4, TS, and WMV,
DVD to MKV
You can also the Audio format based on your need.
Rip MKV with DVDFab DVD Ripper free
(3) Edit MKV using "Advanced Settings" (Optional)
There are some video editing tools in this DVD to MKV software for your use. Be clear about where to find them first.
MKV software - DVDFab DVD Ripper
Before we start to convert DVD to MKV it’s time to do a bit of customization. For example, you can change the name of the output MKV file, pick the audio tracks, subtitles, chapters, and titles you want to rip. For a more in-depth level of customization, however, you’ll want to check out the "Advanced Settings" menu on this DVD to MKV converter. Here, you can change a lot of things about the output, including the resolution, frame rate, encoding method, video quality, and more before DVD to MKV conversion. This menu also lets you make changes to the audio and render/add subtitles directly on the video or stored in a separate .sub file.
Convert DVD to MKV
(4) Edit MKV using "Video Edit" (Optional)
Also, you can edit MKV before DVD to MKV conversion with another tool known as "Video Edit" expressed by a "Pen" icon. With it you can change MKV properties including the brightness, contrast, and saturation, or by cropping and trimming the video. The "Video Edit" menu also lets you add external subtitles to the video as well as text or image watermarks.
DVD to MKV
(5) Start to convert DVD to MKV
After customizing MKV video, where you want to save the converted file? From left to right at the bottom, you can choose ‘Mobile Device’, folder or YouTube to convert DVD to MKV on such devices. Then,you can watch DVD in MKV format on your phone or desktop.
DVD to MKV
2. Other 6 DVD to MKV Converters Recommended
Besides DVDFab DVD Ripper, there are other free software to convert DVD to MKV. For example, you can burn MKV to DVD Handbrake. Now, let's learn what they are.
  • MakeMKV (Windows, Mac, Linux)
  • HandBrake ( Windows, Mac, Linux)
  • FFMPEG (Windows)
  • Freemake (Windows)
  • UniConverter (Mac)
  • OGMConvert (Ubuntu)
Compared with DVDFab DVD Ripper (Windows/Mac), each of such DVD to MKV converter has its compatible operating system. Besides this need, what else you need to take into consideration. Let me give you some tips. If you desire multiple output video formats, don't choose MakeMKV or HandBrake to convert DVD to MKV, MakeMKV only supports DVD to MKV conversion and HandBrake only helps you convert DVD to MKV or MP4.
In my opinion, DVDFab DVD Ripper is the best tool to convert DVD to MP4, since it supports many output formats like MKV, MP4, WMV, TS, FLV, etc. Meanwhile, is allows you to convert DVD to MP4 in batches. Most importantly, you can try it free for 30 days.
DVD to MKV
3. Conclusion
Converting DVD to MKV is a great way to keep your movie collection safe by transforming it to digital format. Unlike physical discs, digital movies don’t degrade over time, which means that you’ll never have to worry about your collection ever again. There are many tools that allow you to rip DVD to MKV but if you want the best we recommend trying out DVDFab DVD Ripper. Converting MKV to DVD DVDFab will complete batch DVD to MKV conversion and convert DVD to MKV losslessly. Apart from ripping DVD to MKV, if you are also interested in how to convert MKV to DVD.
