Looking For Ways to Convert DVDs to MP4? [Solved]
Summary: This article tells you everything you need to know about how to convert DVDs to MP4. In this article, we have discussed some software, and sources that you can use for the conversion process.
- • Copy DVD and Blu-ray files with two backup modes: Full Disc and Main Movie
- • Convert Videos/DVDs/Blu-rays to MKV or MP4 format
- • Work at top speed and export files without quality loss
Whether you like them or you hate them, you cannot deny the fact that DVD discs have played an important role in our lives. Almost everyone who might be reading this article might have fond memories related to DVD discs.
DVD discs can be considered as our window to the past because they store invaluable images, and videos related to your past. Regardless of the information they store, DVD discs are fragile objects, and they can be damaged easily, and all your memories would be gone with the disc.
So is there a way using which you can permanently preserve the content stored in a DVD disc? Yes, you can convert DVD to MP4 by making use of appropriate software that is made with the sole purpose of letting you convert DVD to MP4, and convert MP4 to DVD files with ease.
Best Software to Convert DVD to MP4: DVDFab DVD Ripper
Now, there are hundreds of pieces of software on the internet that claim to be the software to convert DVD to MP4 on Mac and Windows computers. However, which software amongst all the others is the best software to convert MP4 to DVD files, and vice versa.
The DVDFab DVD Ripper is currently one of the best DVD ripper or DVD to MP4 converter applications at the moment for a good number of reasons. It is a highly versatile application, and it can work on almost any computer, even with bare minimum specifications. It supports multiple audio, and video formats, in just under 5 minutes.
So now that we know that the DVDFab DVD Ripper is one of the best applications for ripping DVD files. But how to convert DVD to MP4 using the DVDFab DVD Ripper application? This is what we cover in the next section.
How to Convert DVD to MP4 using the DVDFab Ripper?
If you want to use the DVDFab DVD Ripper application, you might refer to the following user guide on using the application.
Step #1: Download the Application
So the first step you need to take is to download the setup file for the application. So the easiest way to download the DVDFab DVD Ripper application is via the official website. Just visit this page, and spot the “Download Button.”
If you have a Windows computer, select the Windows option, else if you have a Macbook, select the Mac option. Hit the download button, and you will see the setup file will be downloaded shortly.
Step #2: Install the Setup File
Once the setup file has been downloaded, it is time for you to install the application. Locate the setup file and double-click on the file. This should launch the installation wizard that looks like the one shown in the picture below.
Now, you can simply click on the “Click to Install” button or wait for 30 seconds for the installation process to start. Alternatively, if you want to have a look at additional settings, click on the “Custom” option, and it will give you access to additional settings.
Once the installation process has been completed successfully, you will see a “Start DVDFab 12” option. Click on this button to launch the DVDFab DVD Ripper application.
Step #3: Launch the Application
Once the application has been installed successfully on your device, launch it. On the homepage of the DVDFab DVD Ripper’s application, you will spot the “Ripper” option on the top menu of the software.
Step #4: Add Files to the Software
Once you have selected the Ripper module, it is time for you to add the files to the software. Insert the DVD disc into your computer’s optical disk drive, and select the appropriate disc.
Alternatively, you can also add an ISO file or an .ISO folder to rip.
Step #5: Customize the Output Video
Once you have selected the appropriate disc file, it is time for you to make the settings for the output video.
Click on the “Choose Other Profile” option followed by the “Format” option. Now you have to select the “Video” option. Here you need to select whether you want to convert DVD to MP4, or if you want to convert DVD to some other format.
These are just one of the few settings you can make. The software also allows you to add subtitles to the video, extract subtitles from the video, upscale the video quality, customize the video as per different devices, and more.
The full features, and their possible uses are mentioned in the pic attached below.
Step #6: Launch the Conversion Process
Once you have made all the settings as per your requirements, it is time for you to kickstart the conversion or ripping process. You can either click on the “Start” button to kickstart the conversion process immediately, or you can click on the “Continue Later” option to initiate the conversion process at a later point of time.
So that is how you can use the DVDFab DVD Ripper application to convert DVDs to Mp4 files, and many other formats as well. This guide was based on how to convert DVDs to Mp4 Windows 10, and the guide for MacOS would not be much different.
DVDFab DVD Creator: Convert MP4 to DVD Files and More
So far we have discussed how the DVDFab DVD Ripper application can be used to convert DVD files into Mp4 files or other commonly used video file formats. But what if you have a different scenario at hand? What if you want to convert your Mp4 files into a DVD file. How to convert MP4 to DVD?
Just like how to convert a DVD to MP4 on Mac, and how to convert a DVD to MP4 on Windows, you will need software. You will need a dedicated software that specializes in converting MP4 to DVD files.
Out of all the software present on the internet currently, the DVDFab DVD Creator application is simply one of the best. It has a highly interactive, yet an easy to use interface which makes it easier for almost anyone, and everyone to use this application without any troubles whatsoever. It is a powerful application, and it would help you with your conversion needs for sure.
You can use the following link to visit the official website of the DVDFab DVD Creator software. The homepage of the website looks similar to the one shown in the pic below.
As you move down, you will see the different features, and benefits offered by the DVDFab DVD Creator application to its users.
If you click on the “Guide” option present in the top-right corner of the page. This would redirect to you a section on the same page that provides you with a detailed guide on how to use the application.
Before you can download, and use the application, it would be better if you check for the specifications first before downloading the application. Click on the “Tech Specs” option right next to the guide option. You will be redirected to a section of the page that lists the minimum required specifications required to run the application.
Other Wonderful Software to Convert DVD to MP4
We have discussed how the DVDFab DVD Ripper application is one of the best software to convert any DVD file to an MP4 file. But is the DVDFab DVD Ripper the only worthy DVD ripping application. No. There are plenty of other DVD ripping or DVD to MP4 converting applications that are just as good as the DVDFab DVD Ripper application, if not better.
Alternative #1: The VLC Media Player
The VLC Media Player is one of the most popular media players of all time, and for a wide number of reasons. VLC is open-source software that has allowed the software to be used by millions of people from across the world without paying any mandatory charges. One of the many features offered by the VLC Media Player is allowing you to RIP a DVD file as per your needs and requirements.
Although it might seem like the VLC Media Player is one of the best software for converting DVD to MP4, and other file formats. This statement might be true for people who just want to get done with the conversion process. However, if you are a professional, and you want to make some changes to the file before converting it from DVD to MP4 file, then the VLC Media Player would not be of much help to you.
You can download the VLC Media Player from the official website of the software.
Alternative #2: Use Online Converters
If you have a one-time use, or if you do not want to get yourself involved in the unnecessary hassles involved with downloading, and using the offline software can use the online software as well. All you need to do is head on to a search engine of your choice, and type in, “DVD To MP4 Converter”, and you will see hundreds of websites offering you to convert DVD video files into files of other formats.
However, it is worth noting that the conversion quality offered by a majority of these websites are not up to the mark. They might get the job done, but do not expect amazing quality during the conversion process.
Alternative #3: Leawo DVD Ripper Application
If there is an application that challenges the DVDFab DVD Ripper application fiercely for the first spot, then it is the Leawo DVD Ripper application. The Leawo DVD Ripper is one of the best DVD Ripper applications out there, and a major reason why we say so is because of the features offered by the application.
For starters, the Leawo DVD Ripper application is one of those few ripping applications that can even RIP a Copyright-protected software, and convert it into the MP4 or some other format. The Leawo DVD Ripper also supports over 180 video and audio formats, and you can convert DVDs into any of the formats from the given 180 formats.
When you combine the anti-copyright feature, and 180+ supported formats, you get software that can convert almost any DVD on the planet into a video file format of your choice. This should give you a fair idea of how good the Leawo Ripper application is really.
Some of the other useful features of the Leawo DVD Ripper application are: adjusting output parameters as per different devices, adding images or watermarks, cropping the size of the original DVD file, creating 3D movies, and much more.
You can learn more about the Leawo DVD Ripper application from the official website of the software. You can visit the official website of the software using this link.
Alternative #4: HandBrake Ripper Application for macOS
If you are a macOS user, and if you are looking for software that helps you with your DVD conversion needs, then you should check out the HandBrake Ripper application. It is one of the best applications MacOS users can use to convert DVDs to MP4 or other file formats on their macOS computers.
You can get access to the download link for the software directly from the official website of the software. Just click on this link, and you will be redirected to HandBrake’s official website.
In this article, we have told you almost everything you need to know about how to convert DVDs to MP4 video, and vice versa. A lot of people might find it difficult to convert their favorite DVD files into MP4 or other video files so that they can continue storing the contents of the DVD disc for a longer period of time.
It is mainly because a lot of people are not aware of the software that is best suited for converting DVDs to MP4 files, and vice versa. In this article, we have discussed some of the best software to convert DVD files to MP4 files. This software has a dedicated DVD to Mp4 conversion feature, and they are some of the best software you can come across.
