[Solved] How to Rip DVDs on Mac?
Summary: Maybe you are seeking for the answer to the question of how to rip DVDs on Mac given that digital video or music has been a trendy thing. If so, you are in your luck. This article introduces the most popular and efficient DVD ripping software to show you how to rip DVDs on Mac.
• Copy DVD and Blu-ray files with two backup modes: Full Disc and Main Movie
• Convert Videos/DVDs/Blu-rays to MKV or MP4 format
• Work at top speed and export files without quality loss
No doubt that this is an age of digital media which is more fast and convenient, even in higher quality. Therefore, even though you have a heap of DVD collections on your home, taking a lot of space of your shelves, you still rarely watched them these days, but spend many time watching videos on iTunes. Chances are that you have been wondering how to watch these DVD videos on your Mac computer to avoid throwing them away. Here comes the answer: ripping your DVDs on Mac. In this way you can enjoy them without a DVD player. This article covers all the methods you may use to know how to rip DVDs on Mac.
Note: If you want to know how to rip Blu-rays, click here.
When talking about how to rip DVDs on Mac, we have to put the DVDFab DVD Ripper on the list. Because DVDFab DVD Ripper is one of the most popular and qualified DVD ripping software in the world that can quickly convert and rip DVDs on Mac to any mainstream video & audio format for playback on mobile devices and in a home theater.
Main Features of this best DVD ripping software:
• Available on Windows 10/8/7 (32/64 bit) and Mac 10+
• 30-day full trial, free and paid versions
• Pentium 500 MHz, Intel or equivalent, minimum 2 GB RAM
• 20 GB HDD for DVD Ripper and 100 GB for Blu-ray Ripper
• Rip and convert DVD to various video/audio formats as well as some portable devices
• Customize your output via Advanced Settings and Video Editor buttons
• Share your output file on YouTube, Facebook and Vimeo in a direct way
• Support a wide range of formats, both audio and video.
• Work seamlessly with Enlarger AI to upscale video quality if needed
• Rip and convert DVDs, even those DVDs under protection
How to Rip DVDs on Mac with it?
Below we will discuss how to rip DVDs on Mac by using this well-working program.
Step 1: Download and installation
Like always, click on the Mac downloading button to download and install this DVD ripping software on your Mac PC.
Step 2: Run it and load your DVD source
Please double-click its desktop icon to start it. Then, locate on the Ripper module which is followed by clicking on that big plus button to upload your DVD source. Or if your Mac has an optical drive, you can insert the DVD disc, as a result, this ripping program will recognize it in automatic.
Step 3: Set up your video
As soon as your DVD source is uploaded, you are allowed to customize it so that you can output as what you desired. There are so many parameters you can change. And this is the most vital step of how to rip DVDs on Mac with this application.
• 1-Rename the DVD file;
• 2-Select chapters you want to rip;
• 3-Change the audio track;
• 4-Pick up a new subtitle if there is more than one;
• 5-Preview the video to maker sure this is the right DVD you are going to convert;
• 6-Change video quality, frame rate, bits, or audio codec, etc, via this Advanced Settings button;
• 7-Trim, crop, or add text and image to your video through this Video Edit button;
• 8-Select a video format or a device you want to rip to.
Step 4: Rip DVDs on Mac
After making sure that you have set up the video as you want, please move to the bottom of the main interface to select a proper location for your output video by tapping on the folder icon. And then, hit on the Start button to initiate the DVD conversion process.
VLC Media Player
Most people know the VLC as a media player, however, few people have been awared that the VLC can also be used to rip DVDs on Mac if needed. It is an all-in-one tool that embodies video/music/picture/DVD functions. So if you want to know how to rip DVDs on Mac, this is the program you can consider of. And it should be noting that this VLC media player even supports you to rip more than one DVD file at one time, regardless the file types. Keep reading to explore more.
How to rip DVDs on Mac with the VLC?
Step 1: Find the DVD conversion feature
Assume you have installed this DVD ripper Mac on your computer, then run it and go to the Media tab on the top option bar>choose the Convert/Save button.
Step 2: Upload the DVD source
As soon as you chose the Convert/Save button, a new panel pops up as a result from which you can tap the Disc button, listing on the second. Then choose the DVD under Disc Selection, add your DVD source by browsing your PC files.
Step 3: Make settings
You can set an output profile in the DVD ripping conversion. To do this, just tap on the drop-down list and choose a format the VLC program supports. It should be pointed out that not many formats are available here.
Step 4: Set the location file
Head to the Destination file and click on the Browse button to set the output location. When this is done, just proceed to tap on that Start button to start the process of ripping DVD on Mac.
Pros:
Add multiple DVD files to rip
An all-in-one tool
Provides basic DVD ripping functions
Cons:
Can not rip protected DVDs
Barely professional as a DVD ripper
Movavi Video Converter
Though named and designed as a video converter, this software also includes the ability to rip from DVDs to popular video formats with the minimum of fuss. What’s more, it can also allows you to rip the soundtrack of a video to MP3 files in case you only need the audio. Even better, this DVD ripper supports a wide range of devices and video formats.
How to Rip DVDs on Mac with Movavi
Step 1: Add your DVD to the program
Run this program and insert your to-be-ripped disc into the drive. Click Add Media>choose Add DVD>Click on Open DVD and pick the DVD you want to rip.
Step 2: Select a format
In the bottom of the main interface, locate a certain format you want to rip to. Want to see all the formats the DVD ripper Mac supports? Just go to the Devices tab to explore more.
Step 3: Rip the DVD on Mac
Make sure you have chosen the right place for your output file via that drop-down list of Save to before ripping the DVD on Mac.
Cons:
Note that ripping your DVDs on Mac with it may take quite some time so you need to show more patience.
That preview function doesn’t work now and then.
Summary
Three most popular DVD ripping tools are introduced here to show you how to rip DVDs on Mac. Each one has its pros and cons. However, among the three ones, only the DVDFab DVD Ripper is the most professional one and covers almost all the functions needed during the DVD conversion process. Therefore, if you are seeking for the best DVD ripper to rip DVDs on Mac, then the DVDFab program is the best option. And if you also curious about how to rip Blu-rays, you can try the DVDFab Blu-ray Ripper.
