How to Copy DVD on Mac: 6 Best Copy Software in 2024
Summary: This article provides a guide on how to copy DVD on Mac, highlighting the best ripper and copy software available. It aims to help Mac users easily back up their DVD collections or convert them into digital formats for convenient viewing on various devices.
Introduction
Most DVD collectors aim to preserve their discs in a scratch-free, unbroken, and secure state for an extended period. However, these DVDs often experience mishaps. On the one hand, we can choose to copy a DVD on the Mac hard drive. On the other hand, we can rip DVDs to Mac, and the digital format is compatible with various Apple devices, such as iPhone, iPad, and Apple TV. Therefore, to copy DVD on MAC, we need to use two types of tools.
- DVD copy software: Convert any DVD to a blank disc, make a lossless backup of it, or save it as an ISO file or folder on an HDD.
- DVD ripping software: Convert DVDs into a variety of audio or video files. Ripped files can be played anywhere and stored on USB sticks, iPads, mobile phones, etc.
So, how to copy DVD to blank DVD on Mac? How to save DVD on Mac in digital format? We'll introduce you to the best tools and procedures. You can choose between different solutions to copy a DVD on Mac.
Copy DVD To Mac Using DVD Ripping Software
💻Available on: Windows 11/10/8.1/8/7 & Mac 10.10 - 13
👍Key features of DVDFab DVD Ripper
- The only tool that can decrypt the latest copy protection from discs.
- Input any protected DVD disc (2D & 3D), DVD folder, DVD ISO image file.
- Output 1000+ video/audio formats: MP4, MKV, AVI, MP3, TS, WebM, etc.
- Profile Filter: 3D, Passthrough, 4K/5K/8K, H265, 10/12 bit, etc.
- Export 260+ devices: iPhone, Android, Xbox One, USB, and other preset devices.
- Speed: 50x faster ripping speed with GPU acceleration & batch conversion.
- Quality: 1:1 original video quality and 5.1 audio tracks.
- Video editing tools: trim, crop, watermark, subtitle, video effects, contrast, brightness, etc.
How to Copy and Save DVD to Mac with DVDFab DVD Ripper?
Step 1: Install and launch it on your Mac, and click the module "Ripper" first. Insert your disc into a DVD drive, and then this program will detect it quickly. If your source file is an ISO image or folder, you can also simply drag and drop it to the main interface.
Step 2: Click "Choose Other Titles" to select the whole or part of DVD titles you want to rip. You can also select chapters, audio tracks, subtitles or add external subtitles. Then use the options of Advanced Settings and Video Edit to edit your file based on your reference.
Then click "Choose Other Profile" to customize it by selecting the output video/audio formats and device category.
Step 3: Save the file and click the "Start" button to begin ripping your DVD to MP4 or other digital formats on Mac.
MakeMKV
MakeMKV is also an great option to save DVD to Mac. MakeMKV is a free DVD ripping software that allows you to convert DVDs, Blu-ray discs, and files into MKV format only. The program also supports ISOs and BDMVs as well as folders containing IFO and DAT files. Despite its simplicity, MakeMKV offers little customization options which may not appeal to advanced users.
Features:
- It can be used over multiple software including Windows, Mac, and Linux.
- Allows simple tools for ripping the DVD in the fastest way possible.
- Allows choosing of preferred directory for output to provide great and proper management of files.
- keep all meta-information (track language, audio type), as well as all video and audio tracks.
- No watermarks or ads.
- Decrypt AACS and BD+ copy protections.
- Keep DVD ripping files intact as the original videos.
- Output is limited to MKV format.
- No video editing functions.
- Cannot handle other copy protections.
- The output MKV file is too large.
Wondershare UniConverter
If you have been looking for an answer to how to copy a DVD in Windows 10 and Mac, then this software can be your option. It allows for the conversion of audio and video format and also combines a variety of essential features such as compressing, downloading, editing, and sharing. The simple user interface is neat enough to help the users indirectly jump to the task that is needed to be completed.
Features:
- Allows support for more than 1000 audio and video formats that also include MP4, MKV, and many others.
- There are amazingly powerful editing functions for videos like cropping, adding watermark and trimming, etc.
- Allows cropping of videos and you can even crop different parts of a particular video into different lengths and formats.
- Allows burning of DVD to any kind of format for video without any loss in quality.
- Wide range of supported formats
- Maintain the quality of the copied DVD
- Offer other functionalities like DVD burning
- Its cost may be considered high
- Limited DVD protection handling
Copy DVD On Mac With Best DVD Copy Software
DVDFab DVD Copy
DVDFab DVD Copy software allows you to losslessly copy any DVD on Mac to a blank disc directly or save it as an ISO image file or folder on your hard drive.
DVDFab DVD Copy allows you to copy DVD to DVD with 1:1 ratio or compress it to save storage space, only copy main movie title, or copy any content you desire from the source. Besides, you can split one DVD-9 into two DVD-5, or merge multiple DVDs into one DVD. Moreover, you can burn DVD to a blank DVD disc, or clone DVD with 1:1 ratio to gain lossless output DVD.
👍Features of DVDFab DVD copy
- Removal of any protection for backup of a DVD or copy-protected DVD to Mac.
- Support to encrypted new discs by providing services like cloud decryption.
- Copy DVD in Batch at lightning-fast speed.
- Customized settings for output size, audio and subtitle languages
- 6 Copy modes: Full Disc, Main Movie, Clone/Burn, Merge, Split and Customize
How to Copy and Save DVD to Mac by using DVDFab DVD Copy?
Step 1: Launch the DVDFab software and load the source.
Now you can proceed by inserting a DVD that you need to take backup of into your optical drive. In case it is a folder or an iso file then you just need to drag and drop the required file into the software's main page.
Step 2: Selection of the copy mode and customize the output DVD.
Clicking the copy mode as per your requirement. Next, select "Advanced Settings" to choose between DVD-5 and DVD-9 as the output size. Remember to check the "Copy DVD-Video (Video_TS folder)" box; if you don't, you'll receive a blank disc. Next, place a blank DVD disc into your computer's optical drive.
Step 3: Starting the DVD Copy process on Mac.
Now, you just need to tap on the start button to copy DVD to computer. DVDFab software will be completing the task of copying a DVD with amazing lightning speed and great quality.
4videosoft DVD Copy
4Videosoft DVD Copy enables you to copy and save any DVD disc, folder, or ISO file on Mac with high-quality and fast speed. Whether you want to clone a DVD to another blank disc, back up your DVD movies, or make a digital copy for easy playback, this versatile software can meet all your DVD copying needs.
With 4Videosoft DVD Copy, you can choose to copy the entire DVD or just the main movie to save space. Additionally, you can also compress DVD-9 to DVD-5 with excellent quality, ensuring your copied DVD occupies less space without compromising on the visual and audio effects.
- Ensure fast and efficient copying of DVDs
- Supports various DVD types
- Allows users to customize the copy settings
- Have limited advanced features
- No support for Blu-ray
- Lack of frequent updates or feature additions
Xilisoft DVD Copy 2
Xilisoft DVD Copy 2 is a powerful DVD copying software for Mac. With this software, you can easily make copies of your favorite DVDs, backup your DVD collection, or create DVD disc images. It provides several copy modes, including Full Disc, Main Movie, and Customized. It also offers advanced settings for experienced users, such as adjusting the compression rate, choosing the target disc size, and previewing the DVD content before copying.
Features:
- Allows the facility of copying of DVD to DVD to be it dvd5 or dvd9 in a 1:1 ratio.
- It also helps in burning ISO to DVD so that you can watch them on your favorite DVD player.
- You can easily erase the rewritable disc and load them with new information anytime.
- Allows multiple languages along with multi-skin features and personalizes your experience.
- Flexible copying options
- Maintain the original quality of DVD
- Support for various disc formats
- Compatible with most DVD players and media devices
- Lack regular updates or improvements
- Lacks additional features like DVD ripping
- No direct support for encrypted DVDs
Handbrake is free and open-source software that can be used for copying a DVD on Mac devices. Moreover, as the free version of DVDFab DVD Copy/Ripper, DVDFab HD Decrypter also allows conversion of most encrypted DVDs and Blu-rays into MP4 or MKV formats exclusively.
To copy a DVD on a Mac without using software, you can use the built-in Disk Utility tool. Here is how:
- Insert the DVD you want to copy into your Mac's DVD drive.
- Once Disk Utility is open, select the DVD from the list of devices on the left-hand side.
- Choose a destination where you want to save the DVD image file. Click Save to start creating the disk image.
- Once the disk image is created, eject the original DVD from the drive. And insert a blank DVD into the drive.
- In Disk Utility, select the newly created disk image. Adjust the burn settings as desired and click Burn to start copying the DVD onto the blank disc.
From the comprehensive and feature-rich options to the more straightforward and user-friendly ones, there is something to suit every need. Whether you want to create backups of your DVD collection or digitize them for portable devices, these top six copy software for Mac provide the capabilities required for a smooth and efficient copying process.
