MOV to GIF: The Best Alternative of MOV to GIF Photoshop
Summary: Do you want to convert MOV to GIF on Windows? There is a free program which offers two methods for you to do that. You can download it independently or install the versatile package and get three video editors.
Convert MOV to GIF without the help of Photoshop and FFmepg. There are three free programs, the best MOV to GIF converters on Windows. You can use them to eidt your file in any way, such as adding audio, text, overlays, transitions, mosaic to your file. Split, crop, trim your video, convert video to audio or vice versa. Now, follow me to explore the best alternatives of MOV to GIF Photoshop and FFmpeg.
1. DVDFab Toolkit – Alternative of MOV to GIF Photoshop
Supported source video formats by this MOV to GIF converter:
3gp, 3g2, avi, divx, flv, f4v, m2ts, mts, mp4, m4v, mpeg, mpg, dat, mkv, ogm, rmvb, rm, ts, tp, vob, wmv, wtv, asf, dvr-ms, webm
How to convert MOV to GIF with DVDFab Toolkit? Follow the steps below and you will make it.
Step 1: Download and install DVDFab Toolkit on Windows
This alternative of MOV to GIF Photoshop is compatible with Windows. It is very easy-to-use and versatile enough to satisfy your demands. Here, I have listed all the tools embedded in this MOV to GIF converter. Have a look at them.
- Video Tools: Converter, Trim, Speed Up/Down, Mirror/Flip, Rotate, Crop, Sharpen/Unsharpen, Deshake (GoPro), De-interlace, Merge, Extract Videos.
- Audio Tools: Converter, Trim, Volume Adjust, Denoise, Normalization, Merge, Extract Audio, Remux Audio.
- Image Tools: Video to GIF, Video to PIC, PIC to Video, GIF to Video
- Watermark Tools: Text, Time, Image
- Subtitle Tools: Render Subtitles, Extract Subtitles
Step 2: Double click the button - Video to GIF
For the purpose of converting MOV to GIF, you need the help of this button – Video to GIF. Remember the video formats this MOV to GIF converter supports, among which MOV is just one of them.
(mov, 3gp, 3g2, avi, divx, flv, f4v, m2ts, mts, mp4, m4v, mpeg, mpg, dat, mkv, ogm, rmvb, rm, ts, tp, vob, wmv, wtv, asf, dvr-ms, webm)
Step 3: Add your file to this MOV to GIF converter
DVDFab Toolkit offers a 30-day free trial. During this period, you can convert any video to GIF, including but not limited to MOV to GIF. Click the + icon or drag your files to this free MOV to GIF converter directly.
Step 4: Set Start Time and End Time
How long do you want your MOV to GIF file last? Set it using the options of Start Time and End Time or move the marker on the timeline. Aside from that, you can decide the looping time (1, 2, 5, 10, 30, unlimited), playback speed (1x, 1.5x, 2x, 3x 4x), file size (320 x 240, 400 x 240, 480 x 320, 480 x 272, 480 x 360, 720 x 480, 720 x 576, 800 x 480, 1280 x 720, 1920 x 1080) and frame delay options based on your need.
Step 5: Set the output destination
Where are you going to save your converted MOV to GIF file? In line with the Save to button, there is a default output destination. You can use it or create a new folder in your computer to save your GIF.
Step 6: Start to convert MOV to GIF
After setting the Start Time and End Time, click the button Start in the lower-right corner. With just seconds, DVDFab Toolkit will finish the task and remind you where to find your file. It is very easy-to-use for both beginners and experts. Most importantly, this is a free MOV to GIF converter.
The role of DVDFab Toolkit is not just limited to an MOV to GIF converter. It is also the best video trimmer, audio converter, PIC to Video converter, watermark tool, and subtitle extractor, etc.
2. Video Editor – Alternative of MOV to GIF FFmpeg
Another MOV to GIF converter I am going to introduce is FFmpeg. Compared with DVDFab Toolkit, it adds more functions like transitions, filters, elements, mosaic, etc. Now, let me take you to have a try of it.
Supported file formats by this MOV to GIF converter:
- Audio files: aac, ac3, flac, m4a, mp2, mp3, wav
- Image files: bmp, jpg, png, tif, jpeg, tiff, heic
- Video files: gif, mp4, avi, 3gp, asf, mov, f4v, mpeg, mpg, ts, mts, mkv, wmv, webm, flv, mxf
Step 1: Download and install Video Editor, the best alternative of MOV to GIF FFmpeg
With three clicks, you will come to the main interface of this free software. During your installation of Video Editor, no malware will disturb you but a smooth and pleasant download experience. There are three choices as to aspect ratio, including 9:16, 16:9, 4:3. Click one of your favorites and go ahead. After you enter this MOV to GIF converter, another two aspect ratios can be found in the settings, including 3:4 and 1:1.
Step 2: Add your file to this MOV to GIF converter
Click the button Import and add your MOV video to this free software. Images and audios can also be imported from this section. Afterwards, you can set which kinds of files to be displayed by clicking Video, Image and Audio.
Step 3: Drag your file to the timeline section
Move your mouse cursor onto the video you have added to this MOV to GIF converter. Then, there will appear a + icon. Click it and your MOV video will come to the timeline section automatically. Alternatively, drag your video to the timeline directly.
Step 4: Customize your MOV video
There are lots of tools available in this MOV to GIF converter. On the left, there are 207 Audios, 43 Texts, 52 Filters, 54 Overlays, 59 Transitions, and146 Elements for your use. Above the Timeline section, there are Edit, Split, Delete, Crop, Zoom, Mosaic, Freeze Frame, Set Duration, Record Voiceover, Green Screen Cutout, and Speed & Text Converter options. You can use any of these functions in this MOV to GIF converter to customize your file. But before you do that, remember to click the video clip first in the timeline section. Alternatively, right-click the video clip and use the options like Mute, Audio Detach, Voice enhancement, Extract subtitle to edit your file.
What is the function of Edit in this MOV to GIF converter?
Click the button of Edit and you will see three options, including Video, Color Correction and Audio. Under each of the options, you can do the things below.
- Video: speed, reverse, rotate, background color
- Color Correction: contrast, saturation, brightness, hue, highlight, shadow
- Audio: volume, fade in, fade out
How to use the function of Speech&Text Converter?
Click the option of Speech&Text Converter and Video Editor will record the sound or music at that moment automatically. You can end the recording anytime. Then export the recording and your imported MOV video together. Or, mute the original MOV video first and then add the recorded music to your video.
Step 5: Click the button of Export
This is the most important step to convert MOV to GIF. Press the button of Export and then choose Video and set the name and output folder. Set the video format as GIF and select your preferred video quality for your file. Video Editor MOV to GIF converter supports the exported files in MP4, AVI, WMV, MKV, MOV and GIF formats.
If it is necessary, you can also convert video to audio in the format of mp3 or AAC format. Video Editor is very glad to help you do that. Then click the button of Export and wait for your converted MOV to GIF file.
What do you think of this program, compared with DVDFab Toolkit? Would you like to convert MOV to GIF with the help of this free software? What if you like both Toolkit and Video Editor and want to get them together. Music to your ears. There is a method to have them both. Continue to read and find the best answer.
3. DVDFab Video Converter Pro
Free download and install DVDFab Video Converter Pro on your computer, and you will get more than Toolkit and Video Editor. There is another free video converter bound with them. Would you like to kill two birds with one stone? This MOV to GIF converter is compatible with Windows as well. As the picture shows below, three free programs are embedded in this package. Aside from Toolkit and Video Editor, the Converter tool helps your convert videos and audios from one format to another free. And you can also use it to convert video to audio or vice versa. No other MOV to GIF converters can be so powerful. So seize this chance.
4. Conclusion
Have you had a full picture of how to convert MOV to GIF? DVDFab Toolkit, Video Editor and DVDFab Video Converter Pro are all your best free assistants. The third programs includes the former two, so it is highly recommended for you to convert MOV to GIF. All of these three programs are free to use, so why not get the most powerful software and edit your files?
Related Articles Recommended:
2022 Super Resolution AI Software to Upscale Image without Quality Loss
Unblur Photos Free and Fast [Remove Blur from Photo]
