How to Rip DVD for iPod with DVDFab DVD Ripper?
2020-05-28 03:28:32
There are several ways to watch videos on your iPod: download videos from iTunes directly which shall cost you a small bit of money for each video, or you can search for free videos compatible on iPod, or you can also convert DVD movies into iPod compatible M4V videos. This tip below is aimed at the third solution: converting DVD movies for iPod with a popular DVD Ripper software, like DVDFab DVD Ripper.
Follow the step-by-step guide to see how to do it:
Convert DVDs for iPod: Step 1 -> Download and install the latest DVDFab 9 onto your computer;
Convert DVDs for iPod: Step 2 -> Launch DVDFab 9, choose Ripper option at the Option Interface (or from the Option Bar at the Main Interface), then load the DVD you are about to convert;
Convert DVDs for iPod: Step 3 -> Select the movie title, audio track and subtitle stream you want to keep at the Operation Window, click the Profile Box (or Profile Icon) to find iPod from Profile Library and press "OK" button, then just hit  “Start” button at the Main Interface to go converting.
Note: you need the proper profile your iPod model, as there are several profiles in the built-in Profile Library for different models of iPod.
Product you need order: DVD Ripper
For more information, just move on to DVDFab DVD Ripper page.
