How Do I Copy Blu-ray DVD?
2020-07-09 02:19:04
DVD disc is much cheaper than Blu-ray disc, so some people may want to copy Blu-ray movies to DVD discs for backup. If you are one of them, you can never miss DVDFab Blu-ray Copy. DVDFab Blu-ray Copy is one of the most prominent Blu-ray copy software programs that can copy Blu-ray movie to DVD disc and guarantee the video quality at the greatest extent. Now please follow me to see how to copy Blu-ray DVD.
How Do I Copy Blu-ray DVD: Step 1 > Run DVDFab 10, choose Copy module, click the "Copy Mode" tab on the top left corner of the main interface and choose Main Movie mode.
How Do I Copy Blu-ray DVD: Step 2 > Load the source.
How Do I Copy Blu-ray DVD: Step 3 > After the source is loaded in, the longest title, namely the main movie, will be selected by default. Then you can change the chapters, audio tracks, subtitles and do advanced settings according to your needs. On "Advanced Settings" panel, you can choose the output as BD 9 (DVD 9) or BD 5 (DVD 5).
How Do I Copy Blu-ray DVD: Step 4 > Navigate to the dropdown list box at the bottom of the main interface to select your optical drive as the output directory.
How Do I Copy Blu-ray DVD: Step 5 > Click the "Start" button to start the copy process.
Note:
During the copy process, you will be promoted to insert a compatible media to your optical drive. Just insert a DVD 9/ DVD 5 to continue the copy process.
Though you copy the Blu-ray onto a DVD 9/ DVD 5, you can only watch the movie with a Blu-ray player.
For more detailed information about DVDFab Blu-ray Copy, please go to https://www.dvdfab.cn/blu-ray-copy.htm.
① Burn Blu-rays to blank discs or copy to HDDs as ISO files/folders
② Offer 5 different copy modes to meet versatile backup needs
③ Support all types of blank discs: BD-R, BD-RE, DVD±R and DVD±RW
④ Copy the Blu-rays in a lossless manner or compress them smaller
