How to Rip and Convert DVD to Cell Phone with DVD to Cell Phone Ripper?
2020-05-28 03:26:40
How often do you watch movies on your cell phone, or smart phone? Each year, there are a vast sea of cell phones being staged Apple, NOKIA, LG, Sony, Samsung, HTC, and Google, or those other unknown manufacturers. How often do you rip videos for your sell phone? As a user-friendly DVD to cell phone ripper software, DVDFab DVD Ripper helps you rip your DVD collections to compatible videos to play on your cell phones.
Go ahead to learn how:
Rip DVD for Cell Phones: Step 1 -> Download and install the latest DVDFab 9 onto your computer;
Rip DVD for Cell Phones: Step 2 -> Launch DVDFab 9, choose Ripper option at the Option Interface (or from the Option Bar at the Main Interface), then load the DVD you are about to convert;
Rip DVD for Cell Phones: Step 3 -> Click the Profile Box (or Profile Icon) to find the correct profile from Profile Library and press "OK" button, then just hit “Start” button at the Main Interface to go converting.
Note: there are many profiles for different smart phones in the built-in Profile Library, you just need to browse various brands under Device column to find your phone. If your phone is not listed, just choose one which is most similar to yours, or else, select one from the Cell Phone section.
Product you need order: DVD Ripper
For more information, you can go to DVDFab DVD Ripper page.
