How to Convert a DVD Video to MKV, MP4, AVI, MP3 and Other Audio/Video Formats
2020-06-24 02:16:08
If you want to convert your DVD videos to MKV format so that you can play them on your computer or on some portable devices, how should you do? Just use DVDFab DVD Ripper! It can help you convert DVD to MKV effortlessly.
How to Rip and Convert DVD to MKV: Step 1> Run DVDFab 10 and choose the Ripper module.
How to Rip and Convert DVD to MKV: Step 2> Insert the DVD into your optical drive, and DVDFab will load the content on the DVD automatically. You can also load the source manually by clicking the "+" button. But if the source is a file/folder, you can drag the file/folder directly to the main interface to load it.
How to Rip and Convert DVD to MKV: Step 3> Navigate to the profile library on the top left corner of the main interface and choose MKV format.
How to Rip and Convert DVD to MKV: Step 4> Now you can choose the titles, chapters, audios and subtitles, define the names of the titles, and do advanced settings according to your needs. You even can edit the DVD video with the built-in editor.
How to Rip and Convert DVD to MKV: Step 5> Click the "folder" button to select a directory to save the output video. And then you can click the "Start" button to start the ripping process.
You see, it is very simple to convert DVD to MKV.
For more information about DVDFab DVD Ripper, please visit https://www.dvdfab.cn/dvd-ripper.htm
