DVDFab DVD Ripper can be a great DVD to VOB ripper for ripping DVD to VOB video for playback on compatible devices. It’s easy to use with a couple of steps and clicks. What’s more, all complex settings can be done extremely easily as well. Next is a simple step-by-step tutorial on how to complete the task with DVD Ripper.
Step 1: Start up DVD Ripper and load in the source
Start up DVDFab9, choose Ripper option to go to the main interface of Ripper. Insert the DVD disc you want to rip into optical drive and seconds later, the DVD will be imported in and the longest title will be auto selected with the audio tracks and subtitles changeable.
Step 2: Choose profile
Open Profile box to go to Format, then choose vob profile.
Step 3: Advanced settings and editing
Click Advanced Settings on the main interface to set video parameters, audio parameters, and more.
OK. Now click Edit button on the main interface to open Video Effect window. There you can resize source aspect ratio and frame resolution of the video. You can also crop images of the video for display.
Step 4: Start conversion
Hit Start button on the main interface to start conversion. During the process, you can monitor detailed progress info, and preview the progress with real time images.
OK. Done. Have fune.
