How to Rip and Convert DVD to WMV with DVD to WMV Ripper?
05/27/2020
If you want to convert your DVD to WMV video for playback on Xbox 360, ZUNE, etc, you can try out DVDFab DVD Ripper, that can function as a wonderful DVD to WMV ripper. It’s easy to use and professional, as showed in the below step-by-step tutorial on how to do this conversion.
Step 1: Start up DVDFab 9 – Ripper; load in the source DVD
Start up DVDFab 9, choose Ripper option, then insert DVD disc, or drag and drop DVD backup on your PC into the program. Seconds later, DVDFab will import it in and auto select the longest movie tile. The audio tracks and subtitles of the title can be changed freely.
Step 2: Choose profile
Click Profile box to open it, in which all profiles are there. Let’s choose Format, and wmv, then select the very profile you like.
Step 3: Set parameters and edit effect
Click Advanced Settings button on the main interface to set video parameter, audio parameters, and more.
If you want to set video effect, just click Edit button on the main interface, to resize source aspect ratio and frame resolution, and to crop image for display.
Step 4: Start conversion
Hit start button on the main interface to start conversion. During the process, you can view detailed progress info and preview real-time images.
Aright. Leave the rest to DVDFab 9. More info of DVDFab DVD Ripper can be found at: https://www.dvdfab.cn/dvd-ripper.htm
