How to Copy Blu-rays on Win/Mac with DVDFab Blu-ray Copy?
2020-07-09 02:21:13
Do you want to copy your expensive Blu-ray discs for backup or for playback in different places? Then you can never miss DVDFab Blu-ray Copy. It is a professional and powerful Blu-ray copy tool which provides five copy modes for you to choose and can copy your Blu-ray quickly. Now let’s have a look at how to copy Blu-ray discs with DVDFab Blu-ray Copy.
How to Copy Blu-ray Discs with DVDFab Blu-ray Copy: Step 1> Run DVDFab 10, choose Copy module and click the "Copy Mode" tab on the top left corner of the main interface to choose a copy mode. You have five modes (Full Disc, Main Movie, Customize, Merge, and Clone/Burn) to choose. Here I take Main Movie mode as an example.
How to Copy Blu-ray Discs with DVDFab Blu-ray Copy: Step 2> Load the source.
How to Copy Blu-ray Discs with DVDFab Blu-ray Copy: Step 3> After the source is loaded in, the longest title, namely the main movie, will be selected by default. Then you can change the chapters, audio tracks, subtitles and do advanced settings according to your needs. On "Advanced Settings" panel, you can decide the output as BD 50/BD 25/BD 9/BD 5.
How to Copy Blu-ray Discs with DVDFab Blu-ray Copy: Step 4> Navigate to the bottom of the main interface to select a directory to save the output Blu-ray: to select your optical drive as the directory from the drop-down list box is to save the output to a blank Blu-ray disc; to select a directory by clicking the "folder" icon is to save the output as a Blu-ray folder; to select a directory by clicking the "image" icon is to save the output as an ISO image file.
How to Copy Blu-ray Discs with DVDFab Blu-ray Copy: Step 5> Click the "Start" button to start the copy process.
Note:
You are not allowed to do any operation to customize your output DVD on Clone/Burn mode; on Full Disc mode, you cannot choose the titles, chapters, audio tracks and subtitles but you can do advanced settings.
If you choose to save the output to a blank Blu-ray/DVD disc, you will be promoted to insert a compatible media to your optical drive during the copy process. Just insert a blank disc to continue the copy process.
BD 9/BD 5 refers to DVD 9/DVD 5. But if you copy Blu-ray to DVD 9/DVD 5, you can only play the DVD 9/DVD 5 with Blu-ray player.
For more detailed information about DVDFab Blu-ray Copy, please go to https://www.dvdfab.cn/blu-ray-copy.htm.
① Burn Blu-rays to blank discs or copy to HDDs as ISO files/folders
② Offer 5 different copy modes to meet versatile backup needs
③ Support all types of blank discs: BD-R, BD-RE, DVD±R and DVD±RW
④ Copy the Blu-rays in a lossless manner or compress them smaller
