How to Copy Blu-ray to DVD?
2020-05-28 03:26:46
Do you want to copy Blu-ray movies to DVD disc for backup to save money? Then your best choice would be DVDFab Blu-ray Copy. DVDFab Blu-ray Copy is a fabulous Blu-ray copy software program that can copy Blu-ray movie to DVD disc without too much video quality loss. Now let me show you how to copy Blu-ray to DVD with DVDFab Blu-ray Copy.
Burn Blu-ray onto DVD: Step 1 > Run DVDFab 10, choose Copy module, click the "Copy Mode" tab on the top left corner of the main interface and choose Main Movie mode.
Burn Blu-ray onto DVD: Step 2 > Load the source.
Burn Blu-ray onto DVD: Step 3 > After the source is loaded in, the longest title, namely the main movie, will be selected by default. Then you can change the chapters, audio tracks, subtitles and do advanced settings according to your needs. On "Advanced Settings" panel, you can choose the output as BD 9 (DVD 9) or BD 5 (DVD 5).
Burn Blu-ray onto DVD: Step 4 > Navigate to the dropdown list box at the bottom of the main interface to select your optical drive as the output directory.
Burn Blu-ray onto DVD: Step 5 > Click the "Start" button to start the copy process.
Note:
During the copy process, you will be promoted to insert a compatible media to your optical drive. Just insert a DVD 9/ DVD 5 to continue the copy process.
Though you copy the Blu-ray onto a DVD 9/ DVD 5, you can only watch the movie with a Blu-ray player.
For more detailed information about DVDFab Blu-ray Copy, please go to https://www.dvdfab.cn/blu-ray-copy.htm.
① Burn Blu-rays to blank discs or copy to HDDs as ISO files/folders
② Offer 5 different copy modes to meet versatile backup needs
③ Support all types of blank discs: BD-R, BD-RE, DVD±R and DVD±RW
④ Copy the Blu-rays in a lossless manner or compress them smaller
