Storing physical DVD discs can take up a lot of space and leave them vulnerable to damage or scratches. To solve this issue, why not consider copying DVDs to your hard drive for long-term preservation and flexible playback using DVD player software.
For a fast and high-quality DVD copy solution, we recommend DVDFab DVD Copy. In this post, you'll discover the key features of this user-friendly software and learn how to use it to copy DVDs to hard drive.
how to copy dvd to computer pc hard drive
1. Why You Need to Copy DVD to Harddrive?
The benefits of ripping DVD to Hard Drive
  • • First, DVD discs are easy to scratch and fail to play due to improper preservation and mechanical breakdown. By copying the content to your hard drive, you can preserve the original quality of the disc and prevent any potential damage.
  • • If you want to share the contents of a DVD with friends or family members, it is much easier to do so by copying the files to a hard drive and sharing them electronically.
  • • Once you have copied a DVD to hard drive, you can transfer the files to a portable device such as a laptop, tablet, or smartphone. This allows you to watch the content on-the-go without needing to carry around physical discs.
All in all, to avoid potential problems with disc readability or computer failure, you can copy your DVDs onto a hard drive. This method is considered one of the safest ways to store DVD content when done properly.
2. How to Copy Protected DVD to Hard Drive?
In order to help you burn DVDs to hard drive and PC easily without quality loss, DVDFab DVD Copy software is your best assistant.
DVDFab DVD Copy
DVDFab DVD Copy
As the fastest way to copy DVD to Hard Drive, it supports to remove any copy protection and lossless backup or compress DVDs
Features:
  • Keep updating for the latest DVD protection mechanism
  • Copy DVDs to a blank DVD-9 or DVD-5 with no loss of quality
  • Support for Disc, folder, and ISO input with six different copy modes
  • Copy DVDs to the hard drive as folders and ISO image files
  • Support batch DVD copying at lightning-fast speed
  • Various advanced settings allow you to customize DVD
How to Copy DVD to Harddrive Mac with DVDFab DVD Copy?
Step 1: Launch DVDFab DVD Copy and Choose a Copy Mode
Download and install this free DVD copy software. After launching it, select the module of 'Copy' and choose a copy mode from the 6 options below.
Next, insert a DVD disc into the optical drive of your computer. Alternatively, press the ‘+Add’ button to load the DVD ISO file or folder, or simply drag & drop the file onto the ‘+’ area. DVDFab can detect a DVD copy protection when reading your file and decrypt it automatically.
How to copy DVDs to hard drive with DVDFab DVD Copy?
💡Note:
  1. Full Disc: Copy all content of the disc/ISO/Folder source
  2. Main Movie: Only copy the main movie title of the disc/ISO/Folder source
  3. Customize: Copy any content you want form the disc/ISO/Folder source
  4. Split: Split one DVD 9 into two DVD 5
  5. Clone/Burn: Clone DVD or BD in 1:1 ration with nothing lost
  6. Merge: Merge multiple DVDs or BDs into one DVD or BD (DVD and BD cannot be mixed)
Step 2: Customize the Output DVD Video
After loading your source file, you can select chapters, audio tracks, subtitles your want to copy. You can choose your favorite from the source DVD video to make a backup copy of a DVD.
How to copy your DVDs to hard drive with DVDFab DVD Copy
Then click the option of 'Advanced Settings' to identify the volume label and output size: DVD-5 or DVD-9. Do not forget to tick ‘Copy DVD-Video (Video_TS folder)’, otherwise, you will get a blank disc or empty folder.
 how to copy your DVDs to hard drive with DVDFab DVD Copy
When you copy DVD to hard drive or computer via Full Disc or Main Movie mode, the source DVD might contain Cinavia watermark. If so, you need a Cinavia-free tool DVD Cinavia Removal to avoid suddenly muted playback.
Step 3: Set the Output Destination
Then set the file directory to save the output DVD content on a blank disc, as ISO file or DVD folder on computer HDD or on your external hard drive.
Step 4: Start to Copy DVD movie to Harddrive
Once done, tab the ‘Start’ button to copy the DVD. This DVD copying software will show real-time progress on the bar while copying DVD to hard drive or PC. In the meantime, you can stop copying DVD whenever you like, or just set your PC to auto shut down, exit the program, hibernate or do nothing when the DVD copy task is done. Once finished, you can watch the output DVD disc/ISO file/folder with PlayerFab on Windows or Mac, which will bring you a stunning visual experience.
DVDFab DVD Copy: fastest way to copy dvd to hard drive
3. FAQs
How to copy DVD to external Harddrive?
To copy a DVD to an external hard drive, you can use a DVD ripping software such as DVDFab DVD Copy.
1.Download and launch DVDFab softwar. Then select the Copy tab.
2.Insert the DVD you want to copy into your computer's DVD drive.
3.Choose the copy mode you prefer, such as Full Disc or Main Movie.
4.Select the external hard drive as the destination location by clicking on the Save to button.
5.Click on the Start button to start the copying process.
How to rip DVD without copy protection to Hard Drive?
HandBrake is a open-source video transcoder that allows you to copy unprotected DVDs to Harddrive.
Step 1: Insert the homemade DVD into your computer's DVD drive.
Step 2: Open the HandBrake and load the contents of the DVD.
Step 3: Choose the output format and destination where you want to save the copied files on hard drive.
Step 4: Click on the Start button to begin the copying process.
4. Conclusion
In a nutshell, next time when you wonder how to copy DVD on Mac or Windows's harddrive, do not forget to read through this simple guideline. With this recommended DVDFab DVD copy software, you will be able to get a DVD backup with high quality and blazing fast speed.
