How to Copy DVD with DVD Copy on Win & Mac?
2020-08-24 06:09:40
You have an expensive DVD and want to backup it on your hard drive or a blank DVD disc in case that it is lost or is damaged, how should you do? Yes, you need a DVD backup tool. Here I recommend you DVDFab DVD Copy. It is a professional DVD copy tool which offers you 6 copy modes to choose. Now let's have a look at the copy process.
How to Copy DVD with DVDFab DVD Copy: Step 1> Run DVDFab 10, choose Copy module and click the "Copy Mode" tab on the top left corner of the main interface to choose a copy mode. You have 6 modes to choose. Here I take Main Movie mode as an example.
How to Copy DVD with DVDFab DVD Copy: Step 2> Load the source.
How to Copy DVD with DVDFab DVD Copy: Step 3> After the source is loaded in, the longest title, namely the main movie, will be selected by default. Then you can change the chapters, audio tracks, subtitles and do advanced settings according to your needs. On "Advanced Settings" panel, you can decide the output as DVD 5 or DVD 9.
How to Copy DVD with DVDFab DVD Copy: Step 4> Navigate to the bottom of the main interface to select a directory to save the output DVD: to select your optical drive as the directory from the drop-down list box is to save the output to a blank disc; to select a directory by clicking the "folder" icon is to save the output as a DVD folder; to select a directory by clicking the "image" icon is to save the output as an ISO image file.
How to Copy DVD with DVDFab DVD Copy: Step 5> Click the "Start" button to start the copy process.
Note:
You are not allowed to do any operation to customize your output DVD on Clone/Burn mode; on Full Disc mode, you cannot choose the titles, chapters, audio tracks and subtitles but you can do advanced settings.
If you choose to save the output to a blank disc, you will be prompted to insert a compatible media to your optical drive during the copy process. Just insert a blank disc to continue the copy process.
For more detailed information about DVDFab DVD Copy, please visit https://www.dvdfab.cn/dvd-copy.htm
