How to easily clone a DVD movie? There are many software tools can do that, some are very easy to use, while others might be kind of complicated. DVDFab DVD Copy is the most easy-to-use and quick-to-learn DVD cloner software that lets you clone a DVD movies as easy as pie.
Walk over this tip to see how easy it is:
Ways to Easily Clone a DVD: Step 1 > Start up DVDFab 9, then navigate to Copy option and Clone/Burn mode;
Ways to Easily Clone a DVD: Step 2 > Insert the DVD-video disc you want to clone into your disc tray, after a while, DVDFab will start to analyze it. When this process finishes, click the disc icon behind the "Save to" selection box to choose one location from your computer HDD to store the resulting ISO image file;
Ways to Easily Clone a DVD: Step 3 > Press the “Start” trigger and start to make the clone.
Note: if you want to clone the DVD movie onto another blank DVD disc, you just need set the target to your DVD drive which is capable of writing DVDs and put a blank DVD in.
Software you need: the latest build of DVDFab 9
Product you need order: DVD Copy
For more information, please visit www.dvdfab.cn/dvd-copy.htm
