How to Lower Volume of Video and Audio Easily
01/22/2021
Summary: Want to lower the volume of video and audio with easy clicks? This article focuses on how to lower volume of video and audio files with professional but versatile software, DVDFab Toolkit, with which video fans and music lovers can enjoy the perfect sound effect.
For video fans and music lovers, there might be times when the volume of the video or audio file is too loud however you lower the volume on the window speaker. Why is that? Probably, the source file has been encoded at a louder volume, which means turning down the speaker does not work much. Hence, to well protect your hearing, you need to lower the volume of the media files by resorting to an editing program instead of merely adjusting the loudspeaker.
How can I lower the volume of audio or video files? No bother at all! The following guideline aims to demonstrate to you how to lower volume with DVDFab Toolkit, a versatile tool that brings you a stunning audio experience. Act accordingly and refer to the tutorials step by step.
PART 1: How to Lower Volume with DVDFab Toolkit
Step 1: Run DVDFab Toolkit and choose the Volume Adjust module from Audio Tools
Download, install and launch this program from the official website with well-marked Free Download. Up to now, only the Windows version is available. Upon installation, feel free to enjoy it immediately. Then locate Volume Adjust that stands next to the Trim button.
Step 2: Load the source media file (audio/video)
Here are two options to import a source file. First, directly press the + button on the center of the interface to load your wanted audio or video. Alternatively, simply drag and drop the audio or video file onto the + section. Note that you have a chance to import more than one video or audio file at one go, and later adjust volume one by one.
Step 3: Lower volume of the audio or video file
Vertically on the preview window stands a loudspeaker, designed to lower or enlarge the playback volume. If you lower the volume to the minimum level, only to find that the audio or video voice is still quite loud beyond your hearing. In this case, hover your mouse over the horizontal volume slider from right to left, or directly changing the value in the percentage box, to change the volume. Here take the audio file as an example, lower the volume value to 20% to check the sound effect. If you are satisfied with the adjusted sound, retain that value. Otherwise, keep on changing the volume value until you are feeling OK with the sound effect. The same goes for lowering the volume of video files.
Step 4: Set file directory and hit the Start button
Remember to set the file destination to save the final file. Then tab the Start icon to wait for the resulting audio file. Here you can see the real-time converting progress, which takes seconds for a short audio or video file. Meanwhile, on the timeline appears the source info, giving you a clear clue to the current adjustment task.
PART 2: How to Lower Volume of Media File on iPhone
As for how to lower volume on iPhone, there come three simple ways for your reference.
Way 1: Volume Button
Step 1: Tab the volume button to lower the ringer sound
When you do not play any media, pressing the ringer volume can change your phone notification sound including an alarm clock, email, and text messages. Just turn down the ringer sound to lower all sound.
Step 2: Hitting volume button to lower media-sound
When you are playing a video, a piece of music, or a game, simply click on the volume button will help you to adjust the current media playback volume.
Way 2: Settings
- Step 1: Locate the Settings with round gear shape on the home screen
- Step 2: Choose the Sounds option next to Wallpaper
- Step 3: Move the slider from right to left to lower the ringer and alarm volume
- Step 4: Trigger Change with Buttons
When this button is on, the volume button will adjust the ringer volume on the condition that there are no media playing at the same time. On the contrary, the volume button is applicable to adjust media volume.
Way 3: Control Center
- Step 1: Open control center
Swipe up from the bottom of the home screen to locate Control Center. When you are playing a video, you need to swipe up twice.
- Step 2: Swipe from right to left to open the media panel
When you are enjoying a video or music, playback control will appear on this panel.
- Step 3: Adjust volume along with the slider
Move the slider from right to left to lower the media volume that is under playback.
The above-mentioned methods are applied to adjusting the media volume on iPhone, which might be familiar to most iPhone users. Here just mention it for your clear memory.
PART 3: Appealing Features of DVDFab Toolkit
Tiny as it is, DVDFab Toolkit possesses all features essential to addressing the issues related to video, audio, and image. With these functions, you can edit your video or audio files as hoped. Such an integrated tool means a great favor to video fans and music lovers, which has outperformed many homogeneous products. In a nutshell, the key features of this software can be categorized as below.
Video Tools
- Converter: convert videos between various mainstream formats
- Trim: trim unwanted video clips from the timeline
- Crop: crop unwanted sections from the display area
- Speed up/down: adjust the playback speed of videos
- Mirror/Flip: flip videos horizontally or vertically
- Rotate: rotate videos clockwise or counterclockwise
- Sharpen/Unsharpen: sharpen or unsharpen the video screen
- Deshake: stabilize shaking videos
- De-interlace: convert interlaced videos to progressive ones
Audio Tools
- Converter: convert audios between popular formats
- Trim: trim unwanted audio clips from the timeline
- Volume Adjust: adjust audio volume
- Denoise: reduce noises from audios
Image Tools
- Video to GIF: make GIF images from videos
- Video to PIC: take pictures from videos based on a specified frame or time intervals
As a matter of fact, the above-mentioned features can find their wide use in the process of editing video, audio, and image when you want to gain the best final product. So to speak, to lower the volume with DVDFab Toolkit is far more cost-effective in that you can simultaneously enjoy other features aside from volume adjustment.
In general, DVDFab Toolkit efficiently addresses common issues related to video, audio, and image within one program, let alone simply lowering the volume of the media file. If you are curious enough, you can explore other features as many as possible. Do believe this tool will be your great assistant.
① Video: convert, trim/crop, mirror/flip/rotate, sharpen/unsharpen,deshake, denoise
② Audio: convert, trim/merge, normalzie, remux, extract audio, and adjust volume
③ Image: video to GIF/PIC, GIF/PIC to video
④ Watermark: add text/time/image to video
⑤ Subtitle: add subtitles to video, extract subtitles from video
