Rip 3D Blu-ray to 3D M2TS
2020-05-28 03:29:29
DVDFab Blu-ray Ripper can rip any 3D Blu-ray to various 3D videos, including M2TS format. This tutorial is about how to rip 3D Blu-ray to 3D M2TS. And through this step-by-step tip, you can see how easy and professional everything could be with DVDFab. Now let’s go to have a look how to rip 3D Blu-ray to 3D M2TS.
Step 1: Start up DVDFab 9, choose Ripper option and load in the Blu-ray source
Start up DVDFab 9, choose Ripper option, and insert the Blu-ray disc into optical drive. Seconds later, DVDFab will load the movie in and the longest title will be selected by default. You can change the audio tracks and subtitles freely.
Step 2: Choose a M2TS profile
Click Profile box to navigate to 3D Format, then choose m2ts format. Now select a profile for the output.
Step 3: Set 3D parameters and effect
Click Advanced Settings button. In the pop up, choose 3D tab to set the 3D format as anaglyph 3D, side-by-side 3D, etc. And go to Video tab and Audio tab you can see and set all video parameters and audio parameters.
Click Edit button to open Video Effect window, where you can resize source aspect ratio and frame resolution, and you can crop the image for display.
Step 4: Start conversion
Hit Start button on the main interface to start conversion after you make sure that all settings are OK. During the process, you can view all detailed progress info.
OK. Leave the rest to DVDFab. Soon the task will be done. More info about DVDFab Blu-ray Ripper, just go to: https://www.dvdfab.cn/blu-ray-ripper.htm
