This tutorial is about how to rip 3D Blu-ray to 3D MKV with DVDFab Blu-ray Ripper. Only a few steps and clicks, everything can be done. You are allowed to customize the 3D parameters and video effect. Please follow me to have a look then you can try it yourself.
Step 1: Start up DVDFab 9, choose Ripper mode and insert the BD
Start up DVDFab 9, choose Ripper mode. Insert the BD into optical drive. Seconds later, the movie will be in with the longest title auto selected and the audio tracks and subtitles selectable.
Step 2: Open Profile box to choose a MKV profile
Click to open Profile box, and navigate to 3D Format. Select the mkv format and go to choose a profile.
Step 3: Set 3D effect
Click Advanced Settings button. Then go to 3D tab to choose the 3D format and set 3D effect. You can also go to Video tab and Audio tab to set video and audio parameters.
Now click Edit button if you want to edit the video effect. In the Resize mode, you can change the aspect ratio and frame resolution of the video. In Crop mode, you can crop the image for display.
Step 4: Hit Start button to start conversion
Hit Start button to start conversion. During the process, you can view all detailed progress info and preview the progress with real time images.
OK. Done. More info about DVDFab Blu-ray Ripper, just go to: https://www.dvdfab.cn/blu-ray-ripper.htm
