Rip 3D Blu-ray to 3D TS
2020-05-28 03:29:28
DVDFab Blu-ray Ripper can rip 3D Blu-ray to 3D TS video for your specific need. You can customize the 3D format and effect like a master with DVDFab. Everything is darn easy. Now please come with me to the following simple tutorial about how to do the customization and conversion, then you can give it a shot.
Step 1: Start up DVDFab 9, choose Ripper option, and load in the Blu-ray source
Start up DVDFab 9, and choose Ripper option. When the main interface appears, just insert the source Blu-ray disc into optical drive. Seconds later, you’ll see the movie is in with the longest title auto selected and audio tracks and subtitles changeable.
Step 2: Choose a TS profile
Click Profile box to open it, and navigate to 3D Format tab, then select ts format on the left panel. Now go to choose the ts profile you prefer for the output 3D video.
Step 3: Set 3D effect and more
Click Advanced Settings button, then go to 3D tab. Here you can choose the 3D format as anaglyph 3D, side-by-side 3D, and more.
Now go back to the main interface to click Edit button, then go to resize the source aspect ratio and frame resolution of the video, or go to crop the image for display.
Step 4: Start conversion
Hit Start button to start conversion, and you can view all detailed progress info of the progress.
OK. Done. More info about DVDFab Blu-ray Ripper, please go to: https://www.dvdfab.cn/blu-ray-ripper.htm
