iTunes DRM Audio Converter: How to Remove DRM Free
2020-07-08 10:14:04
Summary: This article aims to give you a clear picture of how to remove DRM from iTunes audio files and convert DRM-free M4P audios to M4A without effort with the best iTunes DRM audio converter. Read on to have a close look.
Know any best iTunes DRM audio converter? Have you ever felt obsessed with the DRM protected iTunes audio files? It seems ridiculous that you have no freedom to enjoy your purchased or rented iTunes audio files on other non-Apple authorized devices. What has happened?
Actually, the iTunes music you had bought from iTunes store before 2009 is protected by DRM, and the audiobooks of iTunes until now are all protected by DRM, so it is out of luck if you prefer listening to the iTunes music or audiobooks on other non-apple devices, or enjoy them in the car. Is there any way out there to resolve this problem?
Best iTunes DRM Audio Converter: DVDFab DRM Removal for Apple
Now here comes the best iTunes DRM audio converter, DVDFab DRM Removal for Apple, which can remove DRM from your iTunes audios by converting DRM protected M4B/M4P to unprotected M4A. Moreover, it also can remove DRM from Apple music if you download the music to your music library on iTunes. Now let me show you how to remove DRM protection within three simple clicks.
How to Remove DRM from iTunes Audio Files
Note: Before using DVDFab DRM Removal for Apple, you need to allow iTunes to “share iTunes library XML with other applications”. Please run iTunes, navigate to Edit > Preferences > Advanced, and check the box before “Share iTunes Library XML with other applications”. Moreover, you have to make sure your iTunes is logged in.
Step 1 > Run DVDFab 11 and choose ‘DRM Removal for Apple’ from ‘Utilities’
Then there pop up two options for you: ‘For Video’ and ‘For Audio’. Please choose the latter if you want to remove DRM from audio files and convert M4P/M4B audios to M4A. Otherwise, choose the former to remove DRM and convert video files to MP4.
Step 2 > Click “Add from iTunes” to add the audio from your iTunes.
Just check the songs and audiobooks you want to make sure you have added your wanted audio file from iTunes to this best iTunes DRM audio converter.
Step 3 > Click “folder” icon to save output DRM-free audio files
And then you can click the “Start” button to begin the process of removing DRM.
As a matter of fact, you can remove DRM from M4V files and converted DRM-free video files into MP4. Since this best iTunes DRM audio converter works well for all video contents such as videos, movies, TV shows, audio-books purchased or rented from iTunes files and Apple Music, you can feel free to gain your desired media files, even proceed with other tasks or for playback on other devices, like make a CD with converted audio files.
By the way, if you are unhappy with the resolution of the DRM-free converted video files, you can upscale video quality with AI-powered video enhancer from 480p to 1080p.
① Permanently and completely remove the DRM encryptions
② Support music, videos and audiobooks purchased from Apple
③ Preserve the original audio/video quality, even the original ID tags
④ Support batch conversion to process multiple tasks in a short time
⑤ Provide seamless and automatic operations, easy to all users
