MP3 to WAV: Convert MP3 to WAV Free & Easily 2024
Summary: Are you looking for the best mp3 to wav converter to convert mp3 to wav free and easily for better audio quality played on CD or other devices? If so, you are on the right page. This post aims to offer you the best ways of how to convert mp3 to wav free and easily with easy-to-use but professional mp3 to wav converter tools. Read on for more details.
Have you thought of trun mp3 to wav for a better play on your CD player or mobile devices? Despite the fact that MP3 files have been the most widely used audio format for web pages, it still fades next to WAV files in some aspects. Thus, it’s imperative that you convert mp3 to wav for special uses. This post focuses on how to convert mp3 to wav with different applications that are available on desktop, online or mobile. Check them right now.
PART 1: Why Need MP3 to WAV Converter?
Why do you convert mp3 to wav? You probably want to listen to the original audio file. That’s the point. WAV files are lossless and uncompressed, meaning that they have no quality loss compared with the original recording. On the contrary, MP3 files are compressed audio, reducing the size of an audio file in the compression process.
If you want to save storage space on your mobile devices, MP3 files might be preferred. Because WAV files are large, making them impractical for portable devices and streaming. If you anticipate original lossless audio files played on your quality CD player at home, WAV format will be your first choice. Most web animations adopt WAV as the audio file. In this sense, you need to convert mp3 to wav for a better audio experience. How to convert mp3 to wav free and easily? Move on to the next part.
PART 2: How to Convert MP3 to WAV with Best MP3 to WAV Converter
Among all so-called mp3 to wav converter programs on the market, there is one versatile yet professional audio and video converter for your first choice. Now let’s take a close look at the mp3 to wav converter in detail.
DVDFab Video Converter
Available on: Windows & macOS
Pricing: Free trail, $29.99
Flagship features:
- Convert video and audio into other popular formats playable on various devices
- Edit video via necessary edits to improve video quality
- Customize quality output via parameter settings
- GPU acceleration to quicken conversion process
- Work with Enlarger AI to upscale low-res videos to 4K
- Intuitive interface, perfect for personal and professional use
Supported formats: AAC, AC3, MP3, WAV, WMA, OGG, FLAC, M4A, MKA, DTS, EAC3, AIFF, APE, AU, COPY
Compatible devices: Apple, Amazon, Google, Blackberry, HuaWei, Microsoft, HTC, Box, Samsung, Sony, LG, Xiaomi, and more.
This easy-to-use mp3 to wav converter enables you to convert mp3 to wav at a lightning fast speed and with peak quality due to its GPU hardware acceleration technologies. Above all, it supports conversion for tons of audio files with full compatibility on various devices. In addition to its strong converting function, this software specilizing in trun mp3 to wav will also enable you to edit your videos as your desired. Working seamlessly with Enlarger AI to upscale video to 4K empowers you to be exposed to better watching experience.
How to Turn MP3 to WAV in 3 Simple Clicks?
After checking its outstanding features, let’s take a look at how to turn mp3 to wav free and easily. Here is a guideline for your reference.
Step 1: Launch DVDFab Video Converter and add MP3 music file
Download and install this mp3 to wav converter, load mp3 music files when it runs. You can add music files from the local, or mobile, even drag & drop the file on the UI.
Step 2: Choose WAV profile and customize the output
Click the drop-down menu showing Choose Other Profile, go to Audio tab in the left pane and select WAV from the profile bar.
For a better audio play, you can change audio channels as needed. If you long to adjust the output audio volume, hit the Wrench icon for Advanced Settings to turn up or turn down the music volume via the dragging slide.
Step 3: Start to convert mp3 to wav
Click the Start button to start mp3 to wav conversion. After converting mp3 to wav, you can share the output music file on your YouTube channel via the Earth button. No need to keep a close eye on the whole mp3 to wav conversion process. There will pop up a windows saying Process Completed successfully! Just leave the mp3 to wav converter work in the background. With GPU acceleration, mp3 to wav conversion will be finalized within a short time beyond your expectation.
Note that DVDFab Video Converter is the standard version for video and audio conversion. Once you aim to convert videos or audios while editing them via multiple tools and creative effects, go ahead to try out its Ultra version, DVDFab Video Converter Pro, a perfect yet powerful 3-in-1 video converter and editor designed for amazing conversion and marvelous edits.
PART 3: Alternative MP3 to WAV Converter for Your Choice
Aside from mp3 to wav conversion with DVDFab product, there are other alternative audio converters worth your concern. Check the following list.
Freemake Audio Converter [Windows]
This free mp3 to wav converter is able to convert most non-protected audios into popular formats including MP3, AAC, WMA, M4A, OGG, FLAC, WAV, and AIFF. The output audio files will be compatible with iPhone, Samsung, HTC, Huawei, Xiaomi, etc. Besides, it can convert videos to MP3, M4A, or others.
How to Convert MP3 to WAV Easily
Step 1: Add mp3 music files to the audio converter via +Audio or drag & drop button
Step 2: Choose WAV as the output format
Settings to improve quality audio output via parameters such as codec, channels, sample rate, file size.
Step 3: Convert mp3 to wav via Convert button
After converting mp3 to wav, you can save the output wav file in the local HD, on Dropbox, Google Drive, or One Drive for online storage. Mind that the biggest shortcoming of this free mp3 to wav converter is that you have to pay for its Infinite Pack so that you can convert mp3 to wav files that are longer than 3 minutes.
Zamzar Online File Conversion
As a web-based file conversion app, Zamzar enables you to convert video and audio file directly online without any software installation. How convenient! Simply load your video or audio file to the online converter, choose output format, and click the Convert Now button. You can load mp3 file from the local or add audio link.
Note that this free mp3 to wav converter allows you to convert total file size not exceeding 50MB. Besides, the converted file can be stored within 24 hours. If you want to convert mp3 to wav above that file size limit, go to its subscription plan.
MP3 Converter [Android App]
MP3 converter is a nice audio conversion app for music lovers since it enables you to easily convert mp3 files into other popular audio formats . Meanwhile, you can edit your audio files with simple edit tools. For those who are keen on storing audio files on smartphones (large storage space preferred), this mp3 to wav converter is a good choice.
Just follow the instruction to convert mp3 to wav within simple clicks. Note that this free mp3 tp wav converter contains business ads on a free basis.
Final Thought
In this post we have discussed how to convert mp3 to wav with different applications which are available on Windows, macOS, web-based or mobile app. As to which mp3 to wav converter you shall use, user experience, supported file format, and conversion speed shall be taken into consideration. By the way, you can normalize audio with professional tool before mp3 to wav conversion.
Of course, if you want to convert video to popular format, ai upscale video resolution and improve its quality, DVDFab Video Converter will be your only choice. This audio and video converter works seamlessly with an AI-based video upscaling program, Enlarger AI. Anyway, if you want to upscale low-res videos to 4K on a separate program, then DVDFab Video Enhancer AI will also work well.
