Download
Universal Blu-ray Converter
DVDFab Blu-ray Ripper is a universal Blu-ray Converter which can convert Blu-rays to virtually all popular video/audio formats for playback on the mainstream devices. It is easy to use and allows you to customize the output effect freely. Now please follow me to have a look at how to use it to do Blu-ray conversion.
Step 1: Run DVDFab, load the Blu-ray source under Ripper option.
Start up DVDFab after downloading and installing it on your PC. Choose the Ripper option. Then insert the Blu-ray disc into the Blu-ray drive connected to your PC for DVDFab to load it. Or if the source is saved as a Blu-ray folder or an image file, click Add button on the DVDFab interface to load it. After the movie is in, you can see the longest movie title being selected with audio tracks, subtitles and first/last chapter changeable.
Step 2: Choose a format/device profile
Click the profile icon on the left panel to open the profile library which includes all supported video/audio/device profiles. Go to Format, then you can view the video/audio/3D format profiles and select one.
Go the Device, then you can find all supported devices here and select one.
Step 3: Edit output effect
For an output video, you can click Edit button on the main interface to open Video Edit window, where you can trim and crop the video, add watermark, change the volume, load external subtitles, etc.
Step 4: Start conversion process
Now go to the main interface to specify a storage path in the bottom “Save to” box, then hit Start button to start conversion. You can view detailed progress info and preview the progress in real time if you like. You can also set your PC to shut down or hibernate when all tasks are done so that you don’t need to wait for the process completed.
OK. That’s all. For more info about this Blu-ray converter, please go to: www.dvdfab.cn/blu-ray-ripper.htm
Hot topic recommend, Are You Ready to Embrace the Ultra HD Blu-rays?
  • Discount
    CINA50AUG
    Aug 31, 2017
    for Buying
    The Universal Master Key
    Price: $60 Buy Now
    World's Best DVD Combo
    to Tackle All DVD Copying/
    Price: $79 Buy Now
