Download
Universal Blu-ray Decoder
DVDFab Blu-ray Ripper is a universal Blu-ray decoder which can convert 2D and 3D Blu-rays to various video and audio formats, for playback on video and audio playback devices. Now let’s have a look at how to use this Blu-ray decoder for your specific tasks. Tip: Within the 30-day trial period, DVDFab is free with complete functions. Just download it and follow me to this step-by-step instruction.
Step 1: Run DVDFab, go to Ripper option and load the source
Run DVDFab, click Ripper option. Insert the BD you want to convert into the Blu-ray drive connected to your PC. Or if the source for conversion is a digital Blu-ray file, just click Add button to load it. Seconds later the movie will be in with the longest title selected automatically. The audio and subtitles can be changed. You can also change its start/end chapter to specify the part of the title you want to convert.
Step 2: Select a video/audio/device profile
Click the profile icon on the left panel to bring about the profile library. Choose Device option then navigate on the left panel to choose a device profile.
And choose Format option then you can select a video format, an audio format, or even a 3D format.
Step 3: Settings and editing
You can change the default video/audio parameters if you like. Just click Advanced Settings button on the left panel to open Advanced Settings window. In this window, you are free to change the video codec, resolution, encoding method, quality, audio codec, channels, bit rate, etc.
And you can also click Edit button to set video effect by trimming and cropping the video, adding watermark, etc. on the Video Edit window.
Step 4: Start conversion
OK. Now click Start button to start conversion. During the process, you can view detailed progress info and even preview the progress with real time images. If you don’t want to wait, you can set here for your PC to shut down or hibernate when all tasks are done.
OK. Leave the rest to DVDFab. Learn more about DVDFab Blu-ray Ripper please go to: www.dvdfab.cn/blu-ray-ripper.htm
  • Discount
    CINA50AUG
    Aug 31, 2017
    for Buying
    The Universal Master Key
    Price: $60 Buy Now
    World's Best DVD Combo
    to Tackle All DVD Copying/
    Price: $79 Buy Now
