Top Ten Best GIF Makers to Convert PNG to GIF [You Can Do It Free]
Summary: GIFs are very popular nowadays on instant messaging apps like Twitter and Facebook Messenger when people want to communicate jokes along with other special meanings online. Have you ever wanted a PNG to GIF converter so that you can make your own GIFs with some PNG images? Now that you are reading this article, you will be lucky to find the best ways to convert PNG to GIF either on PC, Mac or online.
Like memes, emojis or stickers, GIFs are also gaining popularity on social network, such as Twitter, and Facebook Messenger, and even your phone’s keyboard, because they are very efficient in communicating jokes, emotions, and ideas. People use GIFs every day even you might not have realized some of the pics you send to your friends online are actually GIF images. So, have you wondered that would it be interesting to make GIFs using your own images, like PNG images, JPG images or any other types of images? To do that, you will need a GIF maker, or a PNG to GIF converter, if you would like to convert PNG to GIF. In this article, we’ll talk about the best apps you can use to achieve that purpose.
Part 1. Why Convert PNG to GIF?
PNG, short for Portable Network Graphics, is a lossless image format using DEFLATE compression. GIF, short for Graphics Interchange Format, is also a lossless image format that uses LZW compression algorithm. Despite the fact that PNG was originally intended as an improved and non-patented replacement for GIF, GIF was still favored over PNG for simple graphics in websites in its early days.
Given that PNG is now supported across all major devices and that PNG compression is about 5–25% better than GIF compression, GIF images are now mainly used only if the image contains animations. Simply put, GIFs contain animations and animations are far better at communicating ideas than still PNG images in certain cases.
Part 2. Top Five Best PNG to GIF Converter on PCs and Macs
There are many software tools or PNG to GIF converters you can use to convert PNG to GIF, here in this part, we will list the five best PNG to GIF converter software for you to choose from. Among those five options, some are only available on Windows computer, some are native macOS apps, still some are free PNG to GIF converters that offers very basic features, others are payware products, of which, PNG to GIF conversion is just a small of their many advanced features.
2.1 Convert PNG to GIF with DVDFab Video Editor (Payware)
Bundled in the 3-in-1 Video Converter Pro suite (the other two products being the video converter software from DVDFab 12 and the 28-in-1 DVDFab Toolkit), the Video Editor is a creative and intuitive video editing software that is super-easy to every video lover, veteran or inexperienced.
Available on: Windows as of now
Pricing plan: $54.99/year, $99.99/lifetime or purchase with the 3-in-1 Video Converter Pro suite at only $79.99
Key features of DVDFab Video Editor:
- Convert PNG to GIF with ease
- Customize videos with hundreds of filters, overlays, transitions, and more
- Add video intros and outros from tons of templates
- Built-in Speech & Text converter and extract subtitles
- Record computer screens, online classes and voiceovers
Follow the instructions below to convert PNG to GIF with this offline PNG to GIF converter,
Step 1 — Download and install Video Converter Pro, using the Download button below. As of now, only the Windows version is available.
Additional Tips: as stated above, Video Converter Pro will install three different products on your computer, including DVDFab 12 (Video Converter), Video Editor Video Editor and Toolkit.
Step 2 — To convert PNG to GIF, opt for the Video Editor software at the welcome screen after launching the program.
Step 3 — When at the Video Editor main interface, load your target PNG file using the Import button at the top left corner, or the Drag & Drop feature.
Step 4 — Hover the mouse pointer over the added PNG file until a green plus icon shows up at the bottom right corner of the thumbnail. Click on that plus icon to add the PNG image to the timeline.
Additional Tips: if you have added multiple PNG files to convert PNG to GIF, you can adjust the time interval of playing one image to the next. To do that, just drag the image edge on the timeline to the right/left to increase/decrease the time that image being played.
Step 5 — Click the Export button from the top menu bar. At the popup window, rename the output file, choose your wanted output folder, and set the output format as GIF, using the dropdown menu.
Additional Tips: If you want to change the output GIF resolution or bitrate before initiating the PNG to GIF conversion, click the Gear button to do that.
Step 6 — Click the Export button at the bottom right corner of this window to convert PNG to GIF.
Okay! The above guides are the details you need to know about how to convert PNG to GIF with the video editing software of Video Editor. Hope you enjoy the process.
2.2 Convert PNG to GIF with Windows Paint (Freeware)
If you only want to convert a single PNG to GIF without having to combine several PNG images to make one animated GIF, then you can simply do that using the Windows native Paint tool that come preinstalled in each and every version of Windows operating system.
Available on: Every iteration of Windows
Pricing plan: Totally free
To convert PNG to GIF with Windows Paint, refer to the steps below:
Step 1 — Open your PNG image with Paint
Step 2 — Navigate to File>Save as>GIF picture
Step 3 — Click the Save button to save the final GIF image
2.3 Convert PNG to GIF with IrfanView (Freeware)
IrfanView is a fast, compact and innovative graphic viewer for Windows XP, Vista, 7, 8 and 10 that is free of charge for non-commercial use. It features numerous image conversion and editing functions that for both novices and professionals to edit images the way they want. Converting PNG to GIF is also pretty easy with this GIF maker.
Available on: Windows XP, Vista, 7, 8 and 10
Pricing plan: Totally free for non-commercial purpose, but you can make donations to support the developer.
To convert PNG to GIF with IrfanView, refer to the steps below:
Step 1 — Open your PNG image with IrfanView
Step 3 — At the next window, choose GIF as the Save as type selection box, using the dropdown menu, and then click the Save button on this window to convert PNG to GIF.
2.4 Convert PNG to GIF with Pixillion Image Converter (Payware)
Pixillion Image Converter from NCH Software allows you to convert between JPG, PNG, GIF, NEF, ICO, RAW, and HEIC images, either one by one or with batch conversion. It can also resize images, add text captions and watermarks and even convert images from the right-click menu.
Available on: Windows XP, Vista, 7, 8 and 10 and all macOS versions
Pricing plan: Totally free for non-commercial purpose, $2.77/month or $34.99/lifetime for commercial use.
To convert PNG to GIF with Pixillion Image Converter, refer to the steps below:
Step 1 — Launch Pixillion Image Converter and use the Add File(s) button to load the PNG image.
Step 2 — At the Output Format selection box, choose GIF using the dropdown menu.
Step 3 — Click the Convert button to convert PNG to GIF.
2.5 Convert PNG to GIF with macOS inbuilt Preview App (Freeware)
Actually, Mac users don’t need to find a 3rd–party image converter software to convert PNG to GIF, because the native Preview app preinstalled in every version of macOS can do that. The Mac Preview app supports convert between any of the following types of images, including GIF, ICNS, JPEG, JPG, JPEG-2000, Microsoft BMP, Microsoft Icon, OpenEXR, PDF, Photoshop (PSD), PICT, PNG, SGI, TGA, TIFF.
Available on: Every iteration of macOS
To convert PNG to GIF with Mac Preview App, refer to the steps below:
Step 1 — Open your PNG image with Preview
Step 2 — From the File menu navigate down to Save As (or choose Export)
Step 3 — Select the GIF from the Format dropdown list
Step 4 — Click Save to save and convert PNG to GIF
Part 3. Top Five Best Online PNG to GIF Conversion Services
Now we’ve talked about how to convert PNG to GIF on Windows and Mac computers with offline PNG to GIF converters, have you ever wanted to convert PNG to GIF directly from a web browser? The advantage of converting PNG to GIF with an online PNG to GIF converter is that you don’t need to install any software. If you’re interested, read on to find the top five best online PNG to GIF conversion service we’ve listed ahead.
3.1 Convert PNG to GIF with ZAMZAR Online Converter
With ZAMZAR’s online file conversion service, you can convert all the major image files from one format to another, in just three steps, including from PNG to GIF. Check out below how do make it happen in three steps. Be aware that the PNG files you added cannot exceed 50MB, otherwise, you will be asked to pay for the PNG to GIF conversion.
Step 1 — Choose the PNG file that you want to convert.
Step 2 — Select GIF as the format you want to convert your PNG file to.
Step 3 — Click Convert to convert your PNG file.
3.2 Convert PNG to GIF with Online-Convert
Online-Convert offers the free media conversion service that you can use to convert PNG to GIF, besides converting PNG to GIF, this online converter also allows you to convert videos to GIF images. And you are also allowed to make custom settings about the output GIF images.
3.3 Convert PNG to GIF with EZGIF.COM
EZGIF.COM not only allows you to convert PNG to GIF, it also supports to convert animated PNG images to animated GIF images. Besides, you are offered the freedom to crop, resize and rotate the images, add special effects, texts and overlays. You should also mind that the APNG or PNG files you want to convert to GIF cannot exceed 35MB maximally.
3.4 Convert PNG to GIF with CloudConvert
CloudConvert converts your image files online. Amongst many others, it supports PNG, JPG, GIF, WEBP and HEIC. You can also use the extra options to control image resolution, quality and file size.
3.5 Convert PNG to GIF with AnyConv
If you just want the simplest PNG to GIF online conversion service, then AnyConv is what you should try out. It does not offer anything more during the PNG to GIF conversion process. No extra settings are necessary, just load your PNG files, click the Convert button, and then download the GIF images back to your local drive. That’s it!
Part 4. Final Words
When communicating online, such as on social platforms and chatting apps, sometimes when words fails to convey the meaning in the way you want, emojis, stickers and GIF images can better express what people want to say in a better way, that’s why they are very popular now, even your smartphone’s keyboard might have employed some default GIFs.
In this article, we’ve briefed you the many different ways to convert PNG to GIF images either using a PNG to GIF converter software compatible on Windows or Mac computers, or using online PNG to GIF conversion solution. No matter which approach you opt for, you should be able to convert PNG to GIF without any hassle now. In case you are also interested making GIFs out of videos, feel free to check out our featured article discussing how to convert videos to GIF images fast.
Other Articles You May Like:
Convert FLAC to MP3? — Why & How?
Convert MP3 to M4A — Is It Really Necessary?
How to Convert WAV to MP4 to Share Your Music to YouTube
What's a Video Converter Android?
How to convert videos to MP3 audios
How to Add Music to YouTube Videos
How to Convert OGG to MP3 for Better Compatibility
Most Competent Video Clip Editors Available in 2020
Top 13 Best Photo Restoration Software 2020
