WebM to GIF | Convert WebM to GIF Fast with Ease
Summary: This article shows you in great details on how to convert WebM to GIF either on Windows computers or Macs with an offline WebM to GIF converter, or with an online WebM to GIF conversion service directly from a web browser. If you happen to be looking for such a solution to convert WebM to GIF, then you are lucky to be coming to the right place.
- • Provides more than 20 video and audio editing tools
- • Enhanced video editing ability, such as editing filters, transitions, etc
- • 3-in-1 video editing tool that offer the most comprehensive solution
Are you looking everywhere to find a WebM to GIF converter software that you can use to convert your WebM videos to GIF images? Then read this article to the end, you won’t need to go anywhere else, because in this article, you will be able to find the correct WebM to GIF conversion solution, free or paid, and regardless of what operating system you have.
Part 1. WebM and GIF explained
WebM is an open-source royalty-free container that Google first announced at its 2010 I/O conference but as of today has been widely used on streaming platforms such as YouTube. This container format can pack video and audio files and it was originally intended to be a free alternative to the popular MP4 container. Inside, WebM supports VP8 and VP9 encoded videos and Ogg Vorbis and Opus encoded audios.
GIF, the abbreviation of Graphical Interchange Format, is an image format invented in 1987 to animate images in the smallest file size. In other words, GIFs are a series of images or soundless video that will loop continuously and doesn’t require anyone to press play. Now you can see GIFs almost everywhere on the internet, including social media platforms, instant messaging apps and more.
Part 2. Convert WebM to GIF on PCs with Offline WebM to GIF Converter
After learning what WebM videos are and what GIFs refer to, then we can move forward to see how one can convert WebM to GIF on Windows computers with an offline WebM to GIF converter.
The WebM to GIF converter we’re going to introduce is the Video Converter Pro from DVDFab Software that actually is a 3-in-1 suite which bundles the video converter software inside DVDFab 12, the VideoCruise video editor software and the Toolkit software into one package. While to convert WebM to GIF, the latter two products can both help you accomplish the goal.
2.1 Convert WebM to GIF Offline with DVDFab VideoCruise
Featuring a myriad of robust video editing capabilities, DVDFab VideoCruise is an advanced video editor software for both novices and experienced veterans to edit videos in their own ways, including converting WebM to GIF with ease.
Available on: Windows as of now
Pricing plan: $54.99/year, $99.99/lifetime or purchase with the 3-in-1 Video Converter Pro suite at only $79.99
Key features of DVDFab VideoCruise:
- Convert WebM to GIF, MP4, MKV, WMV, MOV or AVI
- Choose your wanted output resolution and bitrate
- Allow you to crop and trim the WebM videos before conversion
- Many other advanced video editing features
To convert WebM to GIF with this offline WebM to GIF converter, follow the instructions below:
Step 1 — Download and install Video Converter Pro, using the Download button below. As of now, only the Windows version is available.
Additional Tips: as stated above, Video Converter Pro will install three different products on your computer, including DVDFab 12 (Video Converter), VideoCruise and Toolkit.
Step 2 — To convert WebM to GIF, opt for the VideoCruise software at the welcome screen after launching the program.
Step 3 — When at the VideoCruise main interface, load your target WebM video file using the Import button at the top left corner, or the Drag & Drop feature.
Step 4 — Hover the mouse pointer over the added WebM video until a green plus icon shows up at the bottom right corner of the video thumbnail. Click on that plus icon to add the WebM video to the timeline.
Step 5 — Click the Export button from the top menu bar. At the popup window, rename the output file, choose your wanted output folder, and set the output format as GIF, using the dropdown menu.
Additional Tips: If you want to change the output GIF resolution or bitrate before initiating the WebM to GIF conversion, click the Gear button to do that.
Step 6 — Click the Export button at the bottom right corner of this window to convert WebM to GIF.
2.2 Convert WebM to GIF Offline with DVDFab Toolkit
DVDFab Toolkit, one of the included product inside the Video Converter Pro suite, also features a dedicated WebM to GIF converter tools that allows you to convert WebM to GIF fast and efficiently.
Pricing plan: $26.99/year, $79.99/lifetime or purchase with the 3-in-1 Video Converter Pro suite also at only $79.99
Key features of DVDFab Toolkit:
- Convert WebM to GIF with ease
- Set the start and end time to convert only a small duration of WebM to GIF
- Set the looping times, playback speed and frame delay as you wish
- This toolkit also offers more than 20 other video/audio/image/subtitle/watermark tools
Now let’s go over the details to check out how to convert WebM to GIF with the WebM to GIF converter offered in the Toolkit:
Step 2 — To convert WebM to GIF, opt for DVDFab Toolkit at the welcome screen after launching the program.
Step 3 — When you are at the Toolkit main interface, choose the Video to GIF tool from the Image Tools section which is the one that help to convert WebM to GIF.
Step 4 — Add the WebM video that you want to convert to GIF. To do that, you can directly drag & drop the WebM video into the window, or you can also use the giant Plus icon at the center to load the WebM video.
Step 5 — Once the WebM video is added, then you can freely set the start time and end time of the WebM video to convert WebM to GIF, set the looping times, speed, output resolution and also the frame delay if you want, respectively.
Step 6 — When you are ready at the values, click the Start button at the bottom right corner to convert WebM to GIF immediately.
Alright! Above are the two WebM to GIF converters you can use to convert WebM to GIF on Windows computers. But how to convert WebM to GIF on macOS? Don’t panic. Read on to find all the answers.
Part 3. Convert WebM to GIF on Macs with Offline WebM to GIF Converter
As the two WebM to GIF converters do not work on macOS as of now, we’re going to show you some other ways to convert WebM to GIF on Mac computers. There are many alternatives that are designed specifically for macOS. Now dig deep to find out the WebM to GIF converters that you can use on your iMac, Macbook, or whatever Mac models you own.
3.1 Convert WebM to GIF with GIPHY Capture
GIPHY Capture is a free GIF maker app designed for macOS that you can use to convert WebM to GIF in a few steps. Besides converting WebM to GIF, you can also benefit from many other features that come along with this GIF maker, such as such as adding captions, adjusting the size, trimming the WebM clips for the desired frame, and others.
Refer to the steps below to see how you can convert WebM to GIF image with this Mac WebM to GIF converter application:
Step 1 — Download, install, and launch GiphyCapture app on your Mac. As the app opens, a green square shall appear on your screen.
Step 2 — Play the WebM video with your video player software, and reposition the green box over the playback screen to make it fit properly.
Step 3 — Click on the Start Recording button to create an animated GIF image.
You can locate the created GIF image file by clicking the GIPHY Capture logo in the Menu bar. What’s more, you can also trim or resize the GIF image as you wish. But do be noted that you can only convert WebM to GIF with GIF maker at no longer that 30 seconds.
3.2 Convert WebM to GIF on Mac with Adobe Photoshop
Lucky to Photoshop users, you don’t have to find another WebM to GIF converter, you can convert WebM to GIF on macOS with Photoshop itself. To do that, follow the instructions below.
Step 1 — Run Photoshop on your Mac. Click on the File>Import>Video Frames to Layers. Choose your target WebM file and click on the Open button. A new dialog box will pop up, showing the video along with some other options.
Step 2 — If you want to convert the entire WebM to GIF, select From Beginning to End option. Otherwise, use Selected Range Only option to select your wanted clip.
Step 3 — When you’re done with all the settings, click on the OK button to import your WebM video to Photoshop as frames. Next, click on the File>Export>Save for Web (legacy) to convert the imported WebM to GIF format.
Step 4 — Click on the Save button and select an output folder to save the created GIF image.
Part 4. Convert WebM to GIF with an Online WebM to GIF Converter
Apart from converting WebM to GIF with an offline WebM to GIF converter, there is also possibility to convert WebM to GIF on your Windows and Mac computer with an online WebM to GIF conversion service, directly from your web browser without installing any software product. Now let’s check out how to convert WebM to GIF in that way, with one of the best online conversion solutions offered by Online-Convert, which is totally free of charge:
Step 1 — Add your source WebM file. You can drop it here, add a URL, or load from your Google Drive or Dropbox cloud storage.
Step 2 — Click the green Start conversion button to convert the added WebM file.
Additional tips: if you want more control over the specifications of the final GIF image, manually fill in the values at the Optional settings part.
Step 3 — Wait until the conversion finishes, then your GIF image will start to download automatically.
Part 5. Final Words
In this article, we discussed a couple of different ways that can help you convert WebM to GIF, including with offline WebM to GIF converters either on Windows or macOS computer, and with an online WebM to GIF conversion solution directly from a web browser. Some of these solutions are paid solutions while a few are free solutions as well. There should be the one that fits your demand.
If you still have other video conversion requests, such as converting MP4 to WebM, then you can feel free to check out our featured article centered on how to convert MP4 videos to WebM videos.
Other Articles You May Like:
Convert FLAC to MP3? — Why & How?
Convert MP3 to M4A — Is It Really Necessary?
How to Convert WAV to MP4 to Share Your Music to YouTube
What's a Video Converter Android?
How to convert videos to MP3 audios
How to Add Music to YouTube Videos
How to Convert OGG to MP3 for Better Compatibility
Most Competent Video Clip Editors Available in 2020
Top 13 Best Photo Restoration Software 2020
