UniFab's Star Products: Fully Enhance Your Videos with Super Handy Tools
Video Enhancer AI
Upscale Videos Up to 16K with Detail Enhancement
Boosts your videos from low resolution to 1080P, 4K, 8K, and even 16K. UniFab AI intelligently detects and fixes issues like compression artifacts, noise, and blur — delivering crystal-clear results for all video types.
- Upscale up to 16K resolution
- Universal & Animation Models
- Detail & clarity enhancement
Discover how AI can transform your videos. Learn More>
Video Enhancer AI
Video Colorizer AI
Add Realistic Colors to Black & White Videos
Bring old or monochrome videos to life by adding natural, vivid colors instantly. UniFab Video Colorizer AI uses advanced AI models to analyze each frame and apply consistent, realistic colorization for any video type.
- AI-powered automatic colorization
- 4 unique color styles for customized looks
- Maintain color consistency across frames
See how AI can revive your B&W videos. Learn More>
Video Colorizer AI
Subtitle Generator AI
Subtitle Generation: 98% Accuracy, 30+ Languages
UniFab Subtitle Generator AI not only quickly generates accurate subtitles but also provides natural, fluent translations across multiple languages. Enhance your videos' accessibility and engagement.
- 98% speech-to-text accuracy
- Supports over 30 languages
- Time-synced .srt subtitle files
Make your videos accessible to everyone. Learn More>
Video Converter
Convert Videos to 1000+ Formats for Any Device
UniFab Video Converter supports a wide range of formats and devices, ensuring fast, seamless conversion. Batch processing lets you efficiently convert large or multiple files without quality loss.
- Supports 1000+ video and audio formats
- Batch conversion for multiple files at once
- Built-in video editor with customizable settings
Convert and optimize your videos effortlessly. Learn More>
Video Converter
Explore More UniFab Tools You'll Want to Try
UniFab Studio
AI Video Enhancement Suite for Ultimate Quality Boost
Mit StreamFab können Plex-Videos im MP4- oder MKV-Format gespeichert werden. Das äußerst vielseitige MP4-Format lässt sich ohne zusätzliche Einstellungen zuverlässig auf Smartphones, Tablets, PCs, Fernsehern und den meisten Set-Top-Boxen abspielen.
Andererseits bietet MKV Flexibilität für mehrere Audio- und Untertitelspuren, Kapitel und robuste Metadaten bei gleichbleibend hoher Video- und Audioqualität. Wählen Sie das Format, das zu Ihren Geräten und Ihrem Arbeitsablauf passt.
UniFab Video Editor
Edit Videos with Ease — Cut, Trim, Merge, and More in One Tool
Untertitel können als reine externe SRT-Dateien gespeichert werden, um eine flexible Gestaltung und einfache Bearbeitung zu ermöglichen, oder direkt in das Video umgewandelt werden, um alles in einer einzigen Datei zusammenzufassen.
Wählen Sie zwischen erzwungenen oder vollständigen Untertiteln und legen Sie bevorzugte Sprachen für das Sprachenlernen, gemeinsames Anschauen oder laute Umgebungen fest. Dank eindeutiger Titelbezeichnungen und präziser Tags lassen sich Dateien leicht suchen und auf verschiedenen Playern abspielen.
UniFab Screen Recorder
Smooth HD Screen Recording with Audio and More
Die heruntergeladenen Plex-Videos werden in 1080p Full HD mit AAC 2.0-Audio gespeichert. Lebendige Bilder und klare Dialoge bewahren das Erscheinungsbild Ihrer Filme und Serien auf Fernsehern, Streaming-Sticks, Spielkonsolen und Smartphones. Die Wiedergabe bleibt auf allen Geräten flüssig und konsistent, ohne dass zusätzliche Konvertierungen erforderlich sind.
Enjoy a Flawless Video Enhancement Journey
GPU Acceleration
GPU Acceleration
Powered by NVIDIA, AMD, and Intel GPU acceleration for lightning-fast processing.
Batch Processing
Batch Processing
Save time with one-click batch conversion for multiple videos or entire libraries.
AI Technology
AI Technology
Harness the power of AI to intelligently and automatically enhance your videos.
Seamless Import
Seamless Import
Directly load video files from DVDFab or StreamFab, streamlining editing workflow.
Trusted by Over 80 Million Users Worldwide
FAQ
  • Is a free trial available?
    All UniFab's products are sold as "try-before-you-buy" software. You can try all the modules in the UniFab client for free for 30 days, giving you ample time to verify its functionality. Each module can be tested up to three times during the trial period.
  • Can I use UniFab across multiple devices?
  • If I purchase UniFab All-In-One, will I have access to future upgrades?
  • What are the system requirements of UniFab?
