How to Convert FLV to MP3 Audio Format?
Summary: If you want to convert your FLV videos to MP3 for playback on your audio player, you can have a look at the methods we provide in this article. Here we introduce you how to convert FLV to MP3 on desktop or online.
• Convert videos from one format to another like MKV to MP4
• Support video to video and audio conversion
• Enable you play converted files on mobile devices or home theater
• Competent to enhance video quality with Enlarger AI
FLV, which stands for Flash Video, is a file that requires Adobe Flash Player or Adobe Air to transmit video/audio over the internet. Nearly all video embedded on the internet are saved as FLV file extensions. This includes YouTube, Hulu, Vines and many more websites.
Note: Now that Adobe Flash Professional is called Animate, files in this format may also be referred to as Animate Video files. However, to clear the confusion Flash Video files are essentially the same as Animate Video files.
Since quite recently, websites that earlier supported FLV files have been moving over or completely eliminating all Flash video files. A major reason for this change is the fact that Adobe will no longer support Flash after 2020. Moreover, Flash isn't compatible with certain devices and needs a browser plugin installed for the Flash content to play. Therefore, it would be safe to assume that you would soon want to Convert FLV to MP3. You will be running many Google searches looking for “FLV to MP3 online” and “FLV MP3 converters”. We just thought we will make it easier for you. Here we have compiled a list of websites and softwares that will help you convert FLV to MP3.
Convert FLV to MP3 with DVDFab Video Converter
This should be yours go-to software because DVDFab Video Convertersupports all kinds of file conversions, including FLV to MP3 conversion. Being in the development for years, DVDFab promises to catch up with the latest technology trends. You are sure to have smooth user experience and a perfect output video with astonishing quality. Don’t forget; the conversions happen within seconds!
The FLV to MP3 converter is known for its simplicity. Whether you are a newbie looking forward to some quick edits or want to make professional technical changes in your video, DVDFab Video Converter makes it all possible. Designed with a simple and intuitive UI, it would be easy to navigate through even for a complete newbie. Not only does DVDFabVideoallow single file conversions, it also supports batch conversions, multi-threading, multi-core, the latest NVIDIA CUDA, Intel Quick Sync, etc., but DVDFab can also process any video conversion task within minutes.
Here’s how you can use DVDFabVideo Converterto convert FLV to MP3.
● Open DVDFab Video Converter, and load the source
Double click DVDFab 11, and select converter from the options bar when it runs. Drag and drop your video to convert FLV to MP3 for into the main UI for loading. You could also navigate it through the Add buttons on the main UI.
● Customize output video.
On the left panel click Profile Switcher. Then, select one format (MP3) or device profile you need after source loading and define the output content including the titles, audio tracks, and subtitles. In case you want to make specific changes in the original video, you can adjust the video and audio parameters with the Advanced Settings, and deeply customize the output video effect with the built-in video editor.
After you are done with that, move to the ‘Save to’ part and click the folder icon to select where you would like to save your output.
● Start your conversion!
Finally, hit ‘Convert’. DVDFab Video Converter will immediately begin converting video to the target profile you have set, and send the detailed progress details during the process. You can cancel the task anytime in case you don't want to continue the conversion process. Moreover, you can also set your PC to shut down automatically, exit program, hibernate or do absolutely nothing when the conversion is done.
Convert FLV to MP3 with Zamzar
Zamar is a free online website that supports over 1200 different conversions including - Video Converter, Audio Converter, Music Converter, eBook Converter, Image Converter, CAD Converter. Zamar requires no download or installation to convert FLV to MP3.
The entire conversion takes place online making it super convenient. The website promises to finish all conversions within 10 minutes making it one of the fastest free online converters.
● On the home page, you have the option of either uploading a video file or entering its URL link.
● In the next column, choose the format you want to convert the file into.
● You will have to enter your email address to receive the converted file.
● Lastly, click ‘Convert’. Remember that this step will by default take your acceptance for all the terms and conditions.
What are you waiting for? Go check your mail!
Convert FLV to MP3 with CloudConvert
The website remains true to its tagline “convert anything to anything”. CloudConvert supports around 218 different file formats. Like Zamar, CloudConvert does not need installations or downloads; all conversions take place on Cloud.
● When you log on to the website you will see “Select File” on top.
● Click on it and upload the file you want to convert FLV to MP3.
● Specify conversion format and hit ‘Start Conversion’.
Your file will be saved in the location chosen by you in no time!
