How Can I Convert GIF to MOV
Summary: 16 GIF to MOV converters are introduced in this post. You can convert GIF to MOV on Windows, turn GIF into video on Mac. Moreover, there are also online GIF editor and iPhone as well as Android GIF software. See how they work and start a pleasant GIF to MOV trip.
- • Offer diversified aspect ratio for display
- • Accept file or folder import like video, audio and image
- • Enable you to add text, filters, transitions, overlays and elements, mosaic
- • Allow you to rotate, split, crop, zoom in/out and edit your files in other ways
- • Output files in various formats of high quality
There are many ways to edit GIF, such as GIF to MOV, GIF to MP4, GIF to AVI and GIF to PNG. Here, let’s turn the spotlight on “how can I convert GIF to MOV”. The best way is to save a GIF as a video in the format of MOV directly with the assistance of GIF to video converter. Then where to find such a GIF to MOV converter?
Truth be told, GIF editor software is easily found on the market. Based on your needs, there are two suggestions about how to make a decision. If you expect a high speed in GIF to MOV conversion, offline GIF converter to video is your best choice. On the contrary, if you desire to convert GIF to MOV without software installation, online GIF editor is highly recommended.
In this post, let’s start with offline GIF and MOV converter and online GIF editor, exploring how to convert GIF to MOV on Windows. Mac, iPhone, Android as well as online free and fast.
1. GIF to MOV on Windows
In this part, I am going to introduce some GIF editor Windows to help you convert GIF to MOV. As a video editor, such software is not only able to convert videos, but also competent to edit videos in some other way. Check what kinds of output formats each GIF editor supports, what else functions they are equipped with, and then choose the best free GIF to MOV converter you are fond of.
(1) Video Editor
The first GIF to MOV converter I would like to recommend is Video Editor. It is a free GIF to video converter without any watermarks. As long as you log in, you will be able to enjoy such services below.
Powerful functions in Video Editor GIF editor:
• Input GIF in batches
• Convert GIF to MOV, MP4, MKV, AVI, WMV formats
• Add audio, text, filters, overlays, transitions and elements
• Rotate, speed up, split, crop, zoom, mosaic videos
Steps on how to convert GIF to MOV with Video Editor:
• Get this free GIF editor launched on Windows
• Choose preferred aspect ratio (9:16, 16:9, 4:3)
• Import your GIF(s)
• Dray to the Timeline section
• Customize your file(s) based on your needs
• Click the button of “Export”
• Set the output video formats as “MOV”
This is how to convert GIF to Video in the format of MOV. If you want to turn GIF to video in other formats, follow the same steps above. Video Editor is very easy-to-use and versatile for both beginner and expert.
(2) Windows Movie Maker
The second GIF editor software supporting GIF to MOV is Windows Movie Maker. Similar to ViddeoCruise, it also enables you to customize your video such as adding text, overlays and overlays. After inputting your GIF to this GIF editor Windows, drag your file to the Timeline and click the button of “Export”. Then you will be able to choose an output format ranging from WMV, MP4, AVI, MOV, F4V, MKV, TS, etc. This is the use method of this GIF to MOV converter.
Pro: easy-to-use and powerful
Con: watermark in free version
2. GIF to MOV on Mac
For those who are using Mac operating system, there are two GIF editors introduced. Of course, software able to convert GIF to MOV is more than them. For more MOV editors, there is another article available.
(1) Filmora9
Many people choose this GIF editor on Mac OS X 10.11 or later to convert GIF to MOV. Would you like to have a try? It allows you to set aspect ration and speed, trim, merge, crop and rotate videos, equally powerful as GIF editor Windows - Video Editor. With just a few clicks, you will be able to convert GIF to MOV easily. And Filmora9 offers a free trial. Take action and turn GIF into video with it. Besides GIF to MOV, you can also convert GIF to MP4 and MKV.
(2) ConverterLite
As an open-source GIF editor, ConverterLite is able to convert GIF to AVI, MPEG, FLV, MP4, MP3 and other formats. If you want to GIF to MOV in batches, just purchase this GIF to MOV converter and do what you want as fast as possible. Besides “convert GIF to video”, you can also use it for audio conversion as well as DVD and CD burning. How do you think of this GIF editor software? Make a decision and just do it!
3. GIF to MOV Online
“Can I convert GIF to MOV without software installation”? Of course. There are a number of GIF editors online you can use for GIF to MOV. Let me introduce some top online GIF editors for you.
(1) Cloudconvert
If you are a beginner in video editing, Cloudconvert is the most easy-to-use GIF to MOV converter for your choice. When you come to the main interface of this GIF editor online, set the “Convert GIF to MOV” mode and add your file. Then click the button of “Convert” and Cloudconvert GIF editor will work to prepare your MOV video.
Besides MOV output video format, this online GIF editor also support AVI, FLV, MKV, MP4, WEBM and WMV formats. Then how long should I wait to convert GIF to MOV? It depends on how many people are using the same software as you.
Pro: without software installation
Con: limited speed and file conversion
(2) Convertio
Similar to Cloudconvert online GIF editor, Convertio is also widely used for GIF to MOV. And the use method of this GIF to MOV converter has much in common with Cloudconvert. Here, you have more choices as to converting GIF to which formats, including MP4, SWF, WEBM, AVI, WMV, MPEG, M4V, MPG, FLV, MKV, OGV, MPEG-2, and among others.
(3) Online-Convert
The third online GIF editor is Online-Convert. Import your GIF file by entering its URL or from Dropbox or Google Drive. Then Click the button of “Convert”. With the help of GIF to MOV converter, you can convert GIF to MP4, AVI, ZIP, JPG, WEBP, DOC, PDF and PNG formats. But the conversion speed may be not that fast. So you have to wait for GIF to MOV patiently.
(4) Onlineconvertfree
Another GIF to MOV converter you need to know is Onlineconvertfree. It is claimed to convert files online free and fast. Do you know how to use this GIF editor? Add your file to it first, set the output video format as “MOV” and click the button of “Convert”. Apart from GIF to MOV, exported formats also include 3GP, AVI, FLV, M4V, MP4, MPEG, MPG, OGV, WEBM and WMV. This video editor is available to change GIF size, compress, crop, flip and merge a file as well.
(5) EZGIF.Com
EZGIF website is the next online GIF editor of great help. After coming to the main interface of this GIF to MOV converter, Import your file by inputting its URL or select it directly from your computer. Besides GIF, this video editor also supports JPG and PNG format. But there is a limit on the file size you input. That is, no bigger than 35MB.
(6) FilesConversion
If you want to convert GIF to MOV, FilesConversion online video editor is a good option. Different from other online GIF editor, this one allows you to choose video quality ranging from Low to Moderate, High and Very High. And you can convert GIF to Video to more than MOV format such as MP4, AVI, FLV, Flash and others.
(7) FileZigZag
When you are going to convert GIF to MOV, never forget FileZigZag online video editor. Drop your files here first or click “Browse for Files”. Then scroll down and you will find the imported GIF below. At this moment, press the option of “Please select”, and then choose MOV as the exported format. This is how to convert GIF to MOV using FileZigZag. The video formats involved in this free GIF editor include 3GP, ASF, AVI, BMP, DPX, FLV, JPEG, JPG, MOV, MP4, MPEG, PAM, PBM, PCX, PDF, PGM, PNG and PPM formats.
(8) FreeFileConvert
This is the last free online GIF editor I am going to list. Also three steps are needed to convert GIF to MOV using this software: Input file, select output format and click the button of “Convert”. And there are limited set on the number and size of input GIF. That is, no more than 5 files and less than 300MB.
4. GIF to MOV on iPhone
How do I convert GIF to MOV on iPhone? There are three methods for you. Continue to read and find the best solution to GIF to MOV.
(1) GifShare
To help you convert GIF to video on iPhone smoothly, GifShare is highly recommended. Search it in App store and get it launched. Select GIF from your Gallery or search for a GIF from GIPHY, add filters, background, text to it or adjust its playback speed. Then save it and convert video formats with DVDFab Video Converter.
(2) GIF Cracker
This is a free GIF editor with 4 stars. It can be used to convert GIF to MOV or other video and image formats. After starting this GIF to MOV converter on iPhone, iPad or iPod touch devices above iOS 9.3 version, choose the GIF file, set output format and click the button of “Start Conversion”. Then you will be successful in GIF to MOV. Besides this conversion, GIF Cracker also supports GIF to Photo and GIF to GIF.
(3) GifVid
Another GIF to MOV converter is GifVid. It supports GIF to MOV and vice versa. After “turn GIF into video”, share it on iMessage, Imgur, Tumbir or other platforms with your friends. It is easy and fun. If you want to find an alternative to GIF Cracker, this free GIF editor is a good choice.
5. GIF to MOV on Android
Till now, we have grasped the skills of how to convert GIF to MOV on all the operating systems except Android. So here we come to this topic: GIF to MOV on Android. Which GIF editor can be used to convert GIF to video on your Android smartphone? Choose Gifaroo APK download and you will make it.
6. Conclusion
This is how to convert GIF to MOV on Windows, Mac, iPhone, Android and online. You can choose an offline GIF editor or convert GIF to video without software installation. With the help of these 16 GIF to MOV software, there is a belief that GIF edit will be an easy snack for you. If you are still hesitated about which GIF editor to choose, Video Editor is your first choice, free and without watermarks. For more information on how to edit video, read another article.
