Convert MOV to MP4 with Best Video Converter
Summary: Do you still have problems in finding out an appropriate MOV to MP4 converter? Or maybe you are curious about which is the best format for different occasions? Don’t worry. In the following passage, some detailed information about the two formats will be given to help you decide on which one suits you best. Besides, we will introduce to you a portable, convenient and safe MOV to MP4 converter.
A Brief Introduction to MOV and MP4
MOV
MOV is a popular video format file that was created by Apple. MOV is a video format commonly associated with QuickTime. It uses an algorithm to compress video and audio. Although it is proprietary to Apple, it works on both MAC and Windows operating systems. It is designed to support its QuickTime Movie Player and is frequently used to save videos, movies, and other media.
MOV employs complex algorithms created by Apple and is compatible with many versions of the Mac and Windows operating systems. It stores data using the track idea. Multimedia container files include tracks that hold particular sorts of data.
There are other tracks like this in the container. There are several tracks for storing various forms of data such as text, music, video, and so on. These orbitals sustain a hierarchy of object-like atoms. Furthermore, it employs a unique structure to store digitally encoded media streams.
MOV uses the concept of tracks to store data. Tracks are stored in multimedia container files. There are many such tracks in a container. There are different tracks for holding different types of data like text, audio, video etc. These orbitals maintain a hierarchy of atoms that are objects.
Additionally, it uses a specific format to contain digitally encoded media streams. If the digitally-encoded media stream exists in some other file, it makes a data reference to the media stream. The MOV format has many advantages that make it more popular and usable in the video. However, it has some proprietary issues such as larger files and more space usage.
MP4
Compared with MOV, the MP4 file format was later evolved based on the same format standard. When it comes to data marking information, there are just small changes. It was later adopted as an industry standard. The MPEG-4 format may be utilized by both MOV and MP4 container formats due to their almost comparable nature.
MP4, also known as MPEG4, is primarily a video format used to store video and audio data. The industry standard has greater support for operating systems other than Apple. There are various media players which support this format in different operating systems.
Usually, it is used to share videos over the internet. MP4 can embed any data through private streams. In addition, they are widely supported on various handheld devices such as video players and gaming devices. In addition, it has wider support for hardware devices such as the Sony PSP and various DVD players.
Which One to Choose?
MP4s are generally more compressed and smaller, while MOV files are generally higher quality and larger. For this reason, if you don't want your MOV file to take up too much space, converting MOV to MP4 is a good option to solve this problem because it can reduce the MOV file size as much as possible. Most streaming platforms recommend using MP4 files instead of MOV because MP4 files are compatible with more streaming protocols.
Despite the fact that MOV is developed for QuickTime players and MP4 employs the same lossy compression technology, in a QuickTime-only environment, they are essentially compatible.
Without modifying the video codec, MOV format files may easily be converted to MP4 and vice versa. This is really achievable in an Apple setting. You could run into some issues if you're not working in an Apple environment. Moreover, since MOV files are designed for QuickTime, they are therefore more suitable for video editing on the Mac.
Best Video Converter to Convert MOV to MP4
DVDFab Video Converter
As a portable and useful tool for your work, DVDFab Video Converter can read all popular video/audio formats from the Internet, digital camcorders, or capture cards, and convert them between 1000+ video and audio formats to fit all media players or mainstream devices. Quality conversion is provided in HEVC/H265, 3D, 8K, 4K, 10bit, 12bit, and Passthrough formats.
- Easy and gapless
The metadata information of the file sources, particularly TV And movies, will be fixed and applied to the resulting videos during the conversion process, with each episode named with Show Title, Season, and Episode Number, so that your media server, such as DVDFab Movie Server, or media player software, such as PlayerFab, can list them clearly for easy browsing and gapless playback.
- Simple and cost-effective
If you're new to video editing or looking for simple, cost-effective video converting software, the DVDFab Video Converter is a good choice. It is currently one of the most popular video converters on the market, with many experts claiming that its M4A to WAV conversion feature is the best in the industry.
- A must-have for editors
For video editors and content makers, the DVDFab Video Converter is a must-have tool. DVDFab Video Converter is a three-in-one video editing program that not only allows you to convert video formats but also assists you in creating and editing creative films. You won't need to buy anything if you use the DVDFab Video Converter.
How to Convert MOV to MP4 with DVDFab Video Converter
To convert between MOV and MP4, it is easy and fast to achieve the best result with DVDFab Video Converter. Just follow the 3 steps:
1. Launch DVDFab Video Converter and load the source.
When DVDFab 12 starts, double-click it and select the Converter module from the selection bar. Drag and drag the source video into the main UI to load it, or use the Add buttons to go to it. With restricted functionality, you may utilize this best free video converter.
2. Choose one file and customize the output form
You'll see Format and Device options in the profile library if you choose another profile from the drop-down menu. Choose your preferred format or device, MOV or MP4. Set all of the video and audio parameters via the Advanced Settings, and deeply customize the output video with the built-in video editor if you have more stringent requirements for the output video.
After that, go to the Save to section and pick the output path by clicking the folder icon. Using this free video file converter, you may upload the video directly either in a MOV format or MP4 format.
3. Click to convert MOV to MP4
In the last step, you just have to click the Start button. DVDFab Video Converter software will instantly convert video to the target profile you specify, while also providing you with detailed progress information. You may cancel the task at any moment throughout the process if you don't want to continue, and you can also tell your PC to shut down, leave the application, hibernate, or do nothing after the operation is completed.
This passage introduces two formats to convert MOV and MP4 and how to choose the best one on different occasions. Then a powerful software specialized in conversion between different formats, and the whole process of converting files between the two formats, featured by convenience and speed. Through the whole process, DVDFab Video Converter is regarded as the top priority, which is able to solve all the conversion-related problems, including MOV and MP4.
