Wanna Know the Secret of MP4 Compressors? We Can Reveal It To You
Summary: This article deals with the compression of video files that belong to the .MP4 file format. For the conversion, you need a MP4 compressor software, and we have pitched the DVDFab Video Editor as the best application for this role.
MP4 compressors have been gaining a lot of popularity in recent years primarily because they help a lot of users in reducing the size of their video files. A smaller video size is always preferred by a lot of people because it makes it easier for you to store a larger number of files on your device, and sharing it becomes simple as well.
Now a lot of people often find it difficult to choose the best file compressor for MP4 files primarily because there are thousands of MP4 file compressor softwares available on the internet. Almost every one of these software claims themselves to be the best MP4 file compressor. However, barring a few softwares, a majority of these MP4 compressors are nothing but a hoax. They might not either work the way they advertise or they might contain some malicious files that can harm your device when installed.
If you are looking for the best MP4 compressor for your personal as well as your professional requirements, then you should not be looking past the DVDFab Video Editor application. The DVDFab Video Editor is one of the best video editing applications, and it would help you tremendously in reducing the size of your video files.
In this article, we are going to tell you everything you need to know about the DVDFab Video Editor MP4 compressor software. We will also include a detailed user guide that would help you use this application without any difficulties. So let's jump straight into the article.
How Does a Video Compressor Work?
A video compressor software is an application or an online website that helps you in reducing the size of your video file. But how does a video compressor compress or reduce the size of your video files? It is essential to know how a video compressor works so that you can use these methods in the future as per your requirements.
For example, if you want to reduce the size of the file significantly, and quality does not matter much, you might choose a different method when compared to a situation when you have to compress a video but you cannot compromise on the video quality significantly. However, it is worth noting that video compression is a process where you will have to make peace with the video quality.
With that being said, the following are the three most common methods followed by video compressor softwares to reduce the file size of your video.
Method #1: Changing the File Format
The easiest and most common method of compressing your favorite MP4 files is by changing their formats. Changing the file format means converting the file format from a higher quality, to that of a lower quality that occupies less memory on your device. For example, a lot of MP4 compressors often change the format of your file from MP4 to .MKV or 3GP. Alternatively, if you have a Blu Ray file, then you can change its format to MP4, to reduce the space.
Method #2: Cutting the Video
What is one of the most obvious ways of reducing a file size? You just trim any unnecessary part from it. A lot of video compressor applications work in a similar way, and they reduce the overall file size by just trimming several parts from the video. A lot of these softwares make use of dedicated AI algorithms, and techniques to read the video file. The software then analyzes the video file, and comes across several sections that the software finds to be unnecessary in the video. The software then asks for your permission, and gets rid of this part. The overall file size of your video is then reduced.
Method #3: Optimizing the Video
Optimizing the video is the final method using which video compression applications reduce the overall file size. In this method, the software again makes use of several AI techniques to analyze several parameters of your video file including frame rate, bit rate, volume optimizations, and more. Once the software has analyzed these parameters, it edits them in such a way that there is no real impact on the video file itself, and the size is reduced by some margin.
DVDFab Video Editor: Best MP4 Compressor
Using the DVDFab Video Editor application is like activating the cruise control mode on your vehicle: just initialize the mode, sit back, and relax for the entire ride. The DVDFab Video Editor is one of the best video editing applications of all time, and it is one of the most popular video editors which is the number one choice of a lot of professional content creators, and video editors.
You can use the DVDFab Video Editor application to edit your videos, but you can also use the software to edit images, audio files, and more with ease. It is an all in one software, and probably the only software you will ever require to create some stunning video projects that are really good.
One of the major reasons behind the immense popularity of the DVDFab Video Editor is that it is an extremely easy, and simple to use application. The user interface is really simple, and anyone even if they have no prior experience with video editing or video editing applications would not find it difficult to work with this application.
However, in case you are not sure of how to use the DVDFab Video Editor application, you can refer to the detailed user guide of DVDFab Video Editor application.
How to Use the DVDFab Video Editor to Compress MP4 Files?
We have already discussed the different methods followed by video compressors to compress or reduce the size of your favorite video files. The DVDFab Video Editor in particular follows the first method: changing the file format to reduce the overall size of the video file. If you want to compress MP4 files using the DVDFab Video Editor, all you need to do is follow these simple steps.
Step #1: Download the Application
Before you can start compressing MP4 files using the DVDFab Video Editor application, you need to install it first on your device. Now before you can start installing the application, it is worth noting that as of now, the DVDFab Video Editor is available for download only on Windows, and not on Apple or MacOS devices.
The first step you need to do is download the DVDFab Video Editor application setup file. Although there are multiple sites that allow you to download the application’s setup file, downloading it from the official website is by far the safest, and the best method to do so.
Just head on to the official website of DVDFab, and open the DVDFab Video Editor application page. Spot the “Download for Windows” option, and press the button. Wait for a few seconds, and the download process would start automatically.
Step #2: Installing the Application
Once you have downloaded the setup file, then all you need to do is install the application on your device. Locate the setup file in your computer’s download folder, and click on the setup file to initiate the installation process. Follow the steps the installation package asks you to follow, and wait for the file to install successfully on your device.
Step #3: Launch the Application
Once the application has installed on your device successfully, it's time for you to launch the application. When you launch the application, the startup window looks like the one shown below.
Select the “Converter” option present on the top bar of the Window, to enter the conversion mode of the software.
Step #4: Add the Files
This is where the real task starts. After the application has installed successfully on your device, you need to add the files so that you start the conversion process. To add the files, you can either click on the “+” icon located on the center of the page, or you can click on the “Add Files” option to select the files.
Then the software would redirect you to the internal storage from where you will select the files for conversion.
Step #5: Kick Start the Conversion Process
Once you have successfully added the files, it is time for you to kickstart the conversion process. First of all, spot the “MP4” option that would be located on the file library. You now have two options: you can either jump straight on the conversion process, or you can make the changes on your video as per the need arises.
If you want to make some edits or changes to your video, click on the “Edits” option. Once done, you will be redirected to the video conversion page that would provide you access to editing tools like cutting, adding filters, and more. After you have made all the edits, select the format you want to switch your video into.
What Makes DVDFab Video Editor the Best MP4 Compressor Software?
Now that we have discussed what the DVDFab Video Editor MP4 compressor is, and how you can use the software to compress your favorite MP4 files, it's time for us to discuss what makes the DVDFab Video Editor the best MP4 compressor software. For starters, the DVDFab Video Editor is one of the most powerful video editing softwares of them all.
You can throw almost any project at the DVDFab Video Editor, and expect it to execute the task smoothly. It is a highly capable software, and when paired with an equally capable machine, the DVDFab Video Editor becomes one of the best video editing applications of all time.
With the DVDFab Video Editor, your video compression tasks would get executed without any troubles whatsoever. The DVDFab Video Editor supports over a 1000 video formats, and almost every video file on the planet can be compressed using the DVDFab Video Editor video editing application. You can choose any of these video files as per your requirements: whether you want to reduce the size greatly, or would just small trims would do the job.
Some of the most useful features of the DVDFab Video Editor which makes it one of the best MP4 editing applications of all time are:
- Auto Detach
Have you put in a lot of effort before on removing an audio file from a video file? If yes, then the Auto Detach feature is going to be really effective for you. With just the press of one button, you can remove the audio from any video you wish. It's as simple as it gets.
- Customize Video Effect
You can control the features of any video like saturation, brightness, contrast, and others to customize the video as per your requirements.
- Picture in Picture
Wouldn’t it be great if you can preview the changes simultaneously during the time when you were editing? The picture in picture mode of the DVDFab Video Editor allows you to just do the same.
- Zoom
Often, when we are trying to notice small details in the video, we try to zoom the video file so that we can get a hold of those details much better. However, by default the zoom feature of multi media players, and multiple applications can be a bit blurry. However, the Zoom feature of the DVDFab Video Editor enlarges the file while maintaining decent quality.
- Set Background
How often do you think that you need to change the background of the video file you have? So how do you change the background of your video file? The Set Background feature of the DVDFab Video Editor application allows you to work with the background of the video file in an easy, and effortless way.
Overall, the DVDFab Video Editor is one of the best multimedia applications of all time. The MP4 Compression feature of the DVDFab Video Editor application that we have just discussed is one of the best MP4 compressor applications you will ever see. The DVDFab Video Editor application comes with a 30-day trial period, in case you are not sure whether you should invest your money in the software. You are free to use the software for 30 days, and if you are not satisfied with the products, you can ask for a refund from the company.
