If you are looking forward to the best WAV to MP4 converter, this passage will provide you with a wide range of options. Users could choose from these according to their demands.
Convert WAV to MP4 Using DVDFab Video Converter
In order to convert WAV to MP4, the perfect convert in the market is none other than DVDFab Video Converter. This conversion is the optimal choice for you. It can convert WAV to MP4. It also has the ability to convert video (up to 1080p, 4K, 5K, and 8K) from one format to different. This WAV to MP4 converter can convert video to normal audio formats as well as users can play these audio files on mobile devices and at home theater. With the help of Enlarger AI, poor-quality videos can be enhanced from 1080p to 4K by 300% without any loss in quality. Below are some noteworthy features of this tool.
Features
  • High Conversion Speed
As one of the best WAV to MP4 converters, DVDFab Video Converter has an easy and simple UI. The converter provides the best user experience in the market in comparison to other options. With the assistance of multi-threading, multi-core, the latest NVIDIA CUDA, and Intel Quick Sync, the converter can process any video or audio conversion task at a time at 30x faster comparison to normal speed. This drastically lowers the waiting time for you.
  • Supports for Different File Formats
DVDFab Video Converter can read all the popular video and audio formats from the digital camcorders, capture cards, and Internet, and convert them between 1000+ video and audio formats. This ensures that the output file is compatible with all media players and mainstream devices with its rich profile library. HEVC/H265, 3D, 8K, 4K, 10bit, 12bit, and Passthrough are provided by the converter to provide enhanced-level conversion.
  • Enlarger AI
Coupled with DVDFab Enlarger AI, an AI-powered video upscaling tool, the poor 480p files can be enhanced to 1080p, and 1080p files can be enhanced to the next 4K level. Meanwhile, the resulting output quality will be enhanced dramatically.
  • Speedy Compression with Multiple H/W Technologies
DVDFab Video Converter is the best MAV to MP4 converter, for it owns a simple and intuitive UI to display the utmost user experience. With the help of multi-threading, multi-core, the latest NVIDIA CUDA, and Intel Quick Sync, DVDFab Video Converter is capable finish any video or audio compression task in batch at 30X faster than normal speed.
How to Convert MP4 to WAV?
Now that you have had a look at the features, follow the below steps to know how to convert MP4 to WAV using this tool.
  1. Download and install DVDFab on your computer. Open the tool and tap the Converter module.
  2. Upload the source video into the main UI. Users can use this tool for free with limited features.
mp4 to wav
3. Now, from the drop-down menu, click the Choose Other Profile. Users will see Format and Device options in the profile library.
4. Select one device or format as they wish for. If you have higher requests for the end result, set all the audio and video parameters through the Advanced Settings.
5. Users can customize the output video with the in-built video editor.
6. Next, go to the Save to option and click the folder logo to choose the output directory.
mp4 to wav converter
7. Click the Start option to convert video fast and free.
8. The tool will instantly convert the video to the target folder you have selected.
9. Also, the tool will offer you detailed progress information during the conversion process.
10. Users can cancel anytime the conversion process if they wish to.
convert mp4 to wav
Convert MP4 to WAV with Freemake Video Converter
Operating system: Windows
Price: Free/ Charge for advanced functions
Freemake Video Converter is a freemium entry-level product if you are looking for software that is able to handle MP4 to WAV tasks. This Freemake software could handle all the conversion between popular formats, conduct basic video editing jobs, create photo slideshows and music visualizations.
Features
  • Support 500+ formats conversion
As a free and powerful video converter, Freemake Video Converter is able to tackle more than 500 formats including MP4, AVI, MKV, WMV, MP3, DVD, 3GP, SWF, FLV, HD, MOV, RM, QT, Divx, Xvid, TS, MTS, Fraps.
Besides, Freemake Audio Converter allows users to import photos or audio files to turn multimedia into video, which makes you get rid of the time-consuming procedure to download the videos from streaming platforms. Codecs included: H.264, H.265 (HEVC), MPEG4, AAC, AV1.
  • Convert various visuals
Apart from video conversion, Freemake Video Converter enables users to extract audio files from video clips or change them to MP3, MP4, AVI, WMV, MKV, 3GP, or other file formats. Once finished, Freemake Audio Converter will upload video and audio files into iTunes and iOS. With the help of Freemake Video Converter, all the steps become simple and quick.
  • Compatible with any gadget
As long as your device could play videos, Freemake Video Converter is capable of converting the video files to MP4, no matter you use Apple iPhone, iPad, Google Android, Sony PSP, Xbox, Samsung, Nokia, Huawei, Xiaomi, BlackBerry phones, tablets, consoles or smartwatch.
What’s more, users are allowed to convert different file formats to MP4 or 3GP for old cell phones, which make your memorable moments come to life again.
Pros
  • As an all-inclusive software, Freemake Video Converter provides a wide range of necessary and basic functions in the process of conversion and editing.
  • The intuitive interface is especially suitable for novices who are not familiar with the general conversion process.
Cons
  • You have to download some adware or donate first and you can gain access to the software.
  • The converted clips will have a logo watermark only when you buy the Freemake Remove Branding pack to get a Freemake Video Converter key
Using Guidance of Freemake Video Converter
  1. Add your files
Get the free file converter download & import your videos, URLs, DVDs, audio, or photos to convert using the respective buttons or drag & drop.
mp4 to wav
2. Choose a format or device
Select how you want to encode your files: MP4, AVI, MP3, WMV, FLV, MKV, Apple, Android, PSP, etc.
mp4 to wav
3. Change the format
Use the default file conversion preset (recommended) or change it. Click "Convert" to change a video format.
mp4 to wav
Convert WAV to MP4 Using VLC
As a matter of surprise, VLC has a built-in video converter. The tool can convert one video format to different audio or video format. It is not as simple as DVDFab Video Converter, but you can use the tool for this purpose.
Pros
  • Offers a variety of features such as convert, play, and stream.
  • Free to use.
Cons
  • Need to manually create WAV profile.
  • Difficult for new users to learn how to convert using this tool
wav to mp4
How to convert MP4 to WAV using VLC
Follow the below steps to know how to convert MP4 to WAV using this tool.
  1. Download and install VLC on your device.
  2. Open the tool go to Media >> Convert / Save.
  3. Tap the Add button to upload your MP4 video.
  4. Click Convert / Save button present at the bottom.
  5. As VLC does not have a WAV profile, you will need to manually create a WAV profile.
  6. Click the Create a new profile button. A Profile edition window will appear.
  • Specify a profile name
  • Go to Encapsulation section and tap WAV
  • Go to Audio codec section, check Audio, go to Codec and select WAV.
  • In addition to this, you can also set Channels, Bitrate, and Sample Rate.
  • Click Create option.
convert wav to mp4
7. Now, tap the drop-down list of Profile and select the WAV profile you just created.
8. Tap Browse and choose a destination folder. Make sure to change the file extension to WAV.
9. Click Start to start the conversion process.
Convert WAV to MP4 Using WinX Free Video Converter
WinX Free Video Converter is the next option on our list. Users can freely convert MP4 videos to FLAC, WAV, AAC, MP3, WMA, etc. You can also customize the music file by resetting the sample rate and audio channel. In addition to this, users can also trim audio files to keep necessary parts, batch convert videos, and merge output audio files into one.
Pros
  • Simple interface.
  • Easy to use.
  • No maximum file size limit.
  • Batch conversion.
  • Fast conversion speed.
Cons
  • Difficult to understand for new users
how to convert mp4 to wav
How to convert MP4 to WAV using WinX
  1. Download and install the tool on your PC.
  2. Tap the + Video icon on the top toolbar to browse MP4 video files on your device.
  3. Click open to import source MP4 video.
  4. Once you are done with loading the MP4 videos, an Output Profile window will appear.
  5. Navigate to Music section and choose WAV (Lossless Audio) as the output format.
  6. You can also define the destination folder to save the output WAV music by tapping the Browse icon.
  7. Click the blue RUN option to convert MP4 video into WAV audio file. The tool extracts WAV out of an MP4 video without wasting any time.
Convert WAV to MP4 Using VideoProc
VideoProc is another M4A to WAV media converter present in our list. With full GPU acceleration support, video and audio files can be converted in batch in quickly without any loss in quality. The tool supports different formats such as WMV, M4A, M4R, MP3, FLAC, AAC, OGG, etc. Apart from this, it is built-in with a powerful video and audio editor and recorder.
Pros
  • Support for different file formats
  • In-built editor
  • In-built recorder
Cons
  • Sometimes buggy
.wav to mp4
How to convert MP4 to WAV Using VideoProc
  1. Go to Video >> + Music. Click this option to add MP4 files to the list, or you can just drag and drop the files into the main interface.
  2. After uploading up all MP4 files, select Music in the Target Format section.
  3. Now, select WAV.
  4. Tap the Browse to set an output folder for the generated WAV files.
  5. Click the RUN option to begin the conversion of MP4 to WAV in batch or not.
Convert WAV to MP4 Using Audacity
As surprising it is to know that MP4 can be imported by Audacity, it is true. In fact, this audio editor only takes audio files. Hence, it automatically extracts audio from MP4. The only thing you require to do is to choose an output format for the audio in your final result.
Pros
  • Available on Windows and Mac
  • Easy to use
Cons
  • No enhanced features
  • Limited usage
mp4 to wav
How to Convert MP4 to WAV Using Audacity
  • Open the tool on your PC and head to File in the menu bar to open the MP4 clips that you wish to convert.
  • Users might need to wait for a while for it to accept huge-size MP4 files.
  • Next, once loaded, users will see the audio waveform in MP4.
  • Go to the Export option below File, and choose Export as WAV.
  • Select the output folder and the meta tags of the end result.
  • When the above settings are complete, click OK and wait for it to convert MP4 to WAV.
FAQs about WAV to MP4 Converter
Can Windows convert WAV to MP4?
No. Windows Media Player is not able to convert any WAV to MP4 or vice versa. You need a third-party app or converter to do so.
How do I convert MP4 to WAV in iTunes?
Follow the below steps to know how to convert MP4 to WAV on iTunes.
  • On your device open iTunes.
  • In the menu bar, go to Edit >> Preferences.
  • Tab the General tab and then click on the Import Settings option.
  • Tap the menu beside Import Using, then select the encoding format that you wish to convert your file to.
  • Tap OK.
  • Select the music in your library that you wish to convert and start the conversion.
Is MP4 the same as WAV?
WAV and MP4 are two different media file formats. MP4 can have both video and audio, and extra bit streams like text. WAV is an audio-only file format. MP4 was designed by the MPEG (Moving Pictures Experts Group) of ISO while WAV was designed by IBM and Microsoft.
Does converting MP4 to WAV improve quality?
Converting MP4 to a WAV file will not elevate the audio quality of a poor-quality file. A simple rule is that you cannot “enhance” the quality of a file by any kind of conversion. The best you can do is make a similar copy.
Having said that, you just had a look at the top 5 methods to know how to convert MP4 to WAV. You had a look at different converters but DVDFab Video Converter is the best MP4 to WAV converter due to its different features and ease-to-use design. The tool can convert WAV to MP4 and can easily convert video and audio files from one format to different.
