Can PS4 Play DVDs? Yes - PS4 DVD Player How to Play & Fix [2026]
Summary: Yes, the PS4 can play standard DVDs and Blu-ray discs, but not 4K UHD Blu-ray discs or CDs. To play a DVD, connect your PS4 to the internet once to activate disc playback, insert the disc, and select the disc icon on the home screen. If the DVD will not play, check the disc region code, clean or finalize the disc, enable HDCP, update the system software, or convert the DVD to a PS4-compatible digital video file with DVDFab for USB playback.
PlayStation 4, or PS4, is a home video game console developed by Sony for game enthusiasts. But can the PS4 play DVDs? PS4 is not only a game console; it also works as a media player for DVD/Blu-ray movies and various video files, including 4K videos.
Watching free movies on PS4 is great, but you may encounter some annoying playback issues due to various known or unknown reasons. So in this article, we will show you how to play DVDs on the PS4 directly and how to rip them to PS4 video formats and then play movies on the PS4 through a USB stick.
Can PS4 Play DVDs? (Quick Answer)
Yes. PS4 can play standard DVDs, including DVD-Video discs, on all PS4 models: original PS4, PS4 Slim, and PS4 Pro.
PS4 is also a Blu-ray player, but it is not a 4K UHD Blu-ray player. PS4 Pro can output some 4K video content, but it still uses a standard Blu-ray drive and cannot play 4K UHD Blu-ray discs.
| Disc or Playback Type | PS4 Support | Notes |
| Standard DVD / DVD-Video | ✔ Yes | First disc playback requires one-time internet activation |
| Blu-ray Disc | ✔ Yes | Region restrictions may apply |
| 3D Blu-ray | ✔ Yes | Requires system software 1.75 or later |
| 4K UHD Blu-ray | ✗ No | Not supported on PS4 or PS4 Pro; may show an unrecognized disc message |
| Audio CD | ✗ No | PS4 does not play audio CDs |
| DVD-Audio | ✗ No | Not supported |
| External USB disc drive for movies | ✗ No | Movie discs must use the built-in PS4 disc drive |
| Region-free / Region 0 DVD | ✔ Yes | Can play on PS4 consoles from any region |
There are three limits you should know before you use PS4 as a DVD player.
- First, PS4 needs a one-time online activation before it can play movie discs. This activation enables the required disc playback keys for DVD and Blu-ray playback. After activation, you can play supported discs without an internet connection.
- Second, PS4 games are region-free, but DVD and Blu-ray movie discs are not. Movie disc regions depend on where the PS4 console was sold. For DVDs, North America is Region 1, Europe is Region 2, and Australia is Region 4. For Blu-ray discs, the Americas use Region A, Europe, Africa, and the Middle East use Region B, and Asia uses Region C. If the disc region does not match your PS4, you may see: “Cannot play this disc due to region restrictions.”
- PS4 lets you change the DVD region code only 4 times. After the fourth change, the console stays locked to the last selected DVD region. Region-free and Region 0 DVDs can play on any PS4.
- Third, PS4 does not play 4K UHD Blu-ray discs, audio CDs, DVD-Audio discs, or movie discs through an external USB optical drive. To play a 4K UHD Blu-ray disc, you need a disc edition PS5 or another player that supports 4K UHD Blu-ray.
PS4-supported DVD and Blu-ray Formats
✅Supported DVD Formats:
| Disc Type | Supported? |
| DVD-ROM (commercial) | ✔ Yes |
| DVD-R / DVD-RW | ✔ Yes |
| DVD+R / DVD+RW | ✔ Yes |
| DVD-Video (standard movies) | ✔ Yes |
| AVCHD (on DVD) | ✔ Yes |
Note: Copy-protected or region-locked DVDs may not work if they do not match your PS4 region.
✅Supported Blu-ray Formats:
| BD-ROM (commercial Blu-ray) | ✔ Yes |
| BD-R (single-layer and dual-layer) | ✔ Yes |
| BD-RE (rewritable) | ✔ Yes |
| 3D Blu-ray | ✔ Yes, with system software 1.75 or later |
Note: Ultra HD Blu-ray (4K UHD) discs are not supported on PS4 or PS4 Pro.
How to Play a DVD on PS4 Directly
Before you play your first DVD on PS4, connect the console to the internet once. This step activates DVD and Blu-ray disc playback. After it is done, you can play supported discs offline.
Follow these steps to play a DVD on PS4:
- Turn on your PS4 and sign in to your user account. Make sure the system is connected to the internet if this is your first time playing a disc.
- Insert the DVD into the built-in PS4 disc drive. Do not use an external USB DVD drive. PS4 movie disc playback works only with the internal drive.
- Select the disc icon on the PS4 home screen and press play. If the DVD region matches your console and the disc is supported, the movie will start.
For those interested in more than just DVDs, you might be curious about how to play Blu-ray on PS4. The process is similar, with the PS4 also supporting Blu-ray discs, allowing you to enjoy high-definition content seamlessly.
Why Won't My PS4 Play a DVD? (Troubleshooting)
A PS4 can work as a PS4 DVD player, but a few setup and disc limits can stop playback. If you cannot play DVD on PS4, check the causes below in order.
1. The PS4 has not been activated for disc playback yet
This is the most common cause when users try to play DVD on PS4 for the first time. Before the first DVD or Blu-ray playback, the PS4 must connect to the Internet once to activate disc playback keys, including AACS/DRM-related keys. This is a required first-time setup, not a sign that the DVD drive is broken.
What to do:
- Connect the PS4 to the Internet.
- Insert the DVD or Blu-ray disc.
- Follow the on-screen prompt to activate disc playback.
- After activation, the same PS4 can play supported discs offline.
2. The DVD region does not match your PS4
PS4 games are region-free, but DVD and Blu-ray movie discs are region-locked. The region is based on the market where the console was sold. Common DVD regions include North America as Region 1, Europe as Region 2, and Australia as Region 4. Common Blu-ray regions include the Americas as Region A, Europe, Africa, and the Middle East as Region B, and Asia as Region C. If the region does not match, the PS4 may show “Cannot play this disc due to region restrictions”.
What to do:
- Use a DVD that matches your PS4 region.
- Use a Region 0, region-free, or all-region DVD.
- If needed, change the PS4 DVD region carefully.
- Remember that PS4 allows only 4 DVD region changes. After the fourth change, the DVD region is locked permanently to the last selected region.
3. The disc is a 4K UHD Blu-ray
No PS4 model can play 4K UHD Blu-ray discs. This includes the original PS4, PS4 Slim, and PS4 Pro. A PS4 Pro can output some 4K video content, but it still has a standard Blu-ray drive and cannot read 4K UHD Blu-ray movie discs. If you insert a 4K UHD Blu-ray, the console may show “unrecognized disc”.
What to do:
- Use a standard DVD or standard Blu-ray disc.
- Use a PS5 with a disc drive if you need 4K UHD Blu-ray playback.
4. The disc is an audio CD or DVD-Audio disc
PS4 does not play audio CDs. It also does not support DVD-Audio discs, so these formats will not work even if the optical drive can accept the disc.
What to do:
- Use standard DVD-Video discs for movie playback.
- Use another CD or DVD-Audio player for those formats.
5. You are trying to use an external USB DVD drive
PS4 cannot play movie discs through an external USB optical drive. DVD and Blu-ray movie playback only works through the built-in optical drive on the console.
What to do:
- Insert the DVD into the PS4 internal disc drive.
- Do not use an external USB DVD or Blu-ray drive for movie discs.
6. The DVD is dirty or scratched
A dirty or scratched disc can fail to load, freeze, skip, or stop during playback. If one DVD fails but other supported discs work, the disc itself may be the problem.
What to do:
- Hold the disc by the edges.
- Use a clean microfiber cloth.
- Wipe from the center of the disc outward in straight lines.
- Do not wipe in circles.
- Try another DVD to check whether the problem is the disc or the console.
- For deeper disc repair tips, see this guide to fix scratched DVD.
7. There is no picture or no sound
The DVD may be playing, but the TV input, HDMI connection, or PS4 output settings may be wrong. This can make it look like the PS4 DVD player function is not working.
What to do:
- Check that the HDMI cable is connected firmly.
- Make sure the TV is on the correct HDMI input.
- Restart the PS4 and TV.
- Go to Settings > Sound and Screen > Video Output Settings.
- Check the resolution and display output settings.
8. Playback stutters, freezes, or the PS4 becomes unresponsive
This may happen because of system software issues, heat, dust, or a problem with the disc. If several supported DVDs fail after activation, the internal disc drive may need inspection.
What to do:
- Update the PS4 system software from Settings > System Software Update.
- Keep the console in a well-ventilated place.
- Remove dust around the vents.
- Try a different clean DVD.
- If several supported discs fail after activation, consider having the internal disc drive inspected.
How to Rip a DVD to a PS4-Compatible Video
DVDFab DVD Ripper can convert DVDs you own to PS4 compatible video files, such as MP4, for playback through the PS4 Media Player app. This may help when the DVD region does not match your PS4, the disc is scratched, or you want to watch the movie without inserting the disc each time.
Supported OS:
Key Features:
- Converts DVDs to PS4-compatible MP4 video.
- Converts DVDs to other 1000+ video and audio formats, including MKV, AVI, MP3, etc.
- Can process DVD region codes and common copy protections where legally permitted.
- Supports GPU hardware acceleration to reduce conversion time.
- Lets you adjust codec, resolution, bitrate, audio, and subtitle settings.
- Lets you edit the video with the built-in video editor and trimmer.
How to Rip DVD to PS4 with DVDFab DVD Ripper Easily:
Step 1: Install and launch DVDFab 13 on your Windows or Mac computer. Choose the Ripper module from the main interface.
Step 2: Insert the DVD disc into the computer drive. DVDFab will detect the disc. You can also load a DVD folder or ISO file if you already have one on your computer.
Step 3: Open the profile list and choose a video format that PS4 can read, such as MP4 with H.264 video. You can also adjust output settings, including video codec, resolution, bitrate, audio, and subtitles. If the DVD is old or low-resolution, you may use the AI enhancement option to upscale 480p video to 1080p.
Step 4: Choose an output folder on your computer. Then select Start to convert the DVD to a PS4-compatible video file. When the conversion finishes, move the video file to a USB drive.
How to Play the Converted DVD on PS4 via USB
PS4 cannot play movie discs from an external USB optical drive. However, it can play compatible video files from a USB storage device through the Media Player app. Before playing the converted DVD video, install the Media Player app from PlayStation Store first.
Before you start:
- Install the Media Player app from PlayStation Store.
- Copy the converted DVD video file to a USB drive.
- Insert the USB drive into your PS4.
- Open Media Player on PS4: Go to the PS4 content area or Library, then open Media Player.
- Select your USB device: Media Player will show the connected USB storage device. Select it.
- Choose the converted DVD video: Find the converted MP4 file and press X to start playback.
Can PS4 play DVDs from any region?
No. PS4 games are region-free, but DVD and Blu-ray movie discs are region-locked by the console's sales region. Region 0 or region-free DVDs can play on any PS4, and the PS4 DVD region can be changed only 4 times.
Can the PS4 play Blu-ray discs?
Yes, the PS4 can play Blu-ray discs in addition to DVDs. To play a Blu-ray on your PS4, simply insert the disc into the optical drive, and it will appear in the dynamic menu. Select the disc icon and press the play button. Ensure that your PS4 is updated to the latest system software to ensure compatibility with Blu-ray playback.
Can PS4 play audio CDs?
No. PS4 does not play audio CDs. It also does not support DVD-Audio discs.
Does the PS5 play DVDs?
Yes, the PS5 can play DVDs. Along with support for 4K UHD Blu-ray discs and standard Blu-rays, you can insert a DVD into the PS5's disc drive and it will show up on the home screen, where you can start the movie. For more details on how this works, you can check our guide on does the PS5 play DVDs.
Does the PS3 play Blu-rays?
Yes. All PS3 models can play Blu-ray discs and standard DVDs with up-to-date system software. For backups on PS3, I prefer preserving the full disc structure with PS3 ISO image to retain menus and chapters.
Every PS4 can play standard DVDs, so the console can work as a PS4 DVD player after the one-time online disc playback activation. The key limits are simple. Movie discs are region-locked, and the PS4 DVD region can be changed only 4 times. No PS4 model plays 4K UHD Blu-ray discs, audio CDs, DVD-Audio discs, or movie discs through an external USB optical drive. If your DVD has a region issue or the disc is too worn for regular playback, you can make a lawful conversion to a PS4-compatible MP4 file with DVDFab DVD Ripper and play it from USB through the Media Player app.
![How to Rip Copy-Protected DVDs: 6 Tested Methods [2026]](https://r3.dvdfab.cn/upload/resource/copy-protected-dvd-cnQ8.jpeg)
