Best DVD Copy Software to Remove Any Old or New Protection
Advanced Decryption
DVDFab DVD Copy can automatically detect and remove any copy protection without any hassle before copying DVD, such as CSS (Content Scramble System), APS (Analog Protection System), RC (Region Code), DADC, etc.
Moreover, DVDFab's exclusive Cloud Decryption Service ensures that even newly purchased encrypted DVDs can be decrypted timely and efficiently in the cloud server. This DVD copy software has you covered to open any old or latest DVDs in 5 to 10 seconds.
remove dvd copy protection
Duplicate or Compress Any DVD in 1:1 Quality
Lossless Backup
1:1 Copy DVD-9 to DVD-9 and DVD-5 to DVD-5
DVDFab DVD Copy is designed to create lossless backups from DVD-9 to DVD-9 or DVD-5 to DVD-5. The original video and audio streams are duplicated in a 1:1 ratio. Additionally, you can play the backup copies seamlessly on any home media server or media player like PlayerFab.
Efficient Compression
Compress DVD-9 to DVD-5 with high quality
This DVD copier can also compress a DVD-9 to a DVD-5 for the sake of storage capacity, while ensuring seamless playback of the compressed DVD-5 discs on any standalone home player. You won't have to worry about the issue of playback compatibility.
Multi-Format Output
Copy DVD to Blank Disc or as ISO/Folder for Playback
DVDFab DVD Copy allows you to copy any DVD to a blank DVD disc for future use. If a blank disc is unavailable, you can also save the DVD as an ISO image file or as a VIDEO_TS folder on your hard drive.
Note: DVDFab supports two burning engines for DVD to DVD copying: ImgBurn and the DVDFab Burning Engine.
Accelerated DVD Copying Performance
Maximum Efficiency
Batch Copy Multiple DVDs at Lightning-fast Speed
DVDFab DVD Copy software allows you to copy multiple DVDs simultaneously, including DVD discs and ISO files. You can add all the DVDs you want to back up to the task queue, letting DVDFab complete the task on its own.
Meanwhile, this DVD cloner delivers high-speed burning performance. The writing speed to disc depends on your optical drive, while copying to an ISO file or folder takes only 3 to 5 minutes.
Batch Copy DVDs at fast speed
Copy DVD with 6 Copy Modes to Meet Diverse Needs
To address different DVD copying requirements, DVDFab DVD Copy provides six distinct copy modes: Full Disc, Main Movie, Clone/Burn, Merge, Split, and Customize. Each mode serves a specific purpose to help you create perfect backups of your DVD collection.
Full Disc
Full Disc
Copy all the DVD content with or without compression.
Main Movie
Main Movie
Copy the main movie title of DVD with or without compression.
Clone/Burn
Clone/Burn
Clone DVD in a 1:1 ratio with no quality loss.
Merge
Merge
Merge multiple DVD content into one DVD.
Split
Split
Split one DVD-9 into two DVD-5.
Customize
Customize
Copy any titles/chapters you desire from the DVD.
Additional Features of the Smart DVD Copier
Generate Friendly Metadata
Friendly Meta Info and .nfo File Generation
When you open the DVD source, DVDFab's exclusive Meta Info feature will give it its full play. All meta information from the source is automatically synchronized with the server, allowing you to view the movie title, cast, and cover.
Meanwhile, the .nfo file will be generated by default so that the meta info of the source will be fully displayed on media servers like PlayerFab, Kodi, Plex, and others.
Cinavia-Free Playback
Remove Cinavia Protection and Produce Clean Audio
When copying DVDs containing the Cinavia watermark, DVDFab DVD Copy works with DVDFab DVD Cinavia Removal to completely and permanently eliminate Cinavia protection.
This process instantly produces clean and lossless audio with AC3 5.1, eliminating the frustrating Cinavia Error Message Code 3 permanently.
Functional Comparison of DVDFab Products
DVDFab DVD Copy
DVDFab DVD Ripper
$42.50
Buy Now
$59.49
Buy Now
Supported Discs
Newest Commercial, Rental or Recorded DVD
Output Format
DVD/ISO Image File/Folder
Over 1000 video and audio formats including MP4, MKV, MP3, etc.
Support Adult DVDs
Remove Newest DVD Protections
Lossless Backup to DVD9
Compress to DVD5
Supported Copy Modes
Full Disc
Main Movie
Customize
Clone/Burn
Split
Merge
Burn ISO image file to DVD
Output Video Resolution
Lossless
Lossless
Upscale to 1080P
Hardware GPU Acceleration
Launch DVDFab and load the DVD source.
Step 1. Launch DVDFab and load the DVD source.
Open DVDFab 13 and choose the Copy option. Insert your DVD into the optical drive, or navigate to it through the Add button. If the source is an ISO or a folder, you can simply drag and drop the file onto the main page.
Step 2. Select a Copy mode and customize the output DVD.
Click the Copy mode as needed. Then choose the output DVD size (DVD-9/5). You can also define the volume label and change other copy options. Finally, select your output directory as a blank disc, ISO file, or folder.
Step 3. Start to copy DVDs free and fast.
Tap the Start button to copy DVDs with lightning speed and top quality. You can cancel the process at any time, set your PC to automatically shut down, hibernate, exit the program, or do nothing at the end of the process.
Watch the video
80+ Million People Like Our DVD Copy Software
System Requirements
Icon
Windows 11/10/8.1/8/7 (32/64 bit)
Pentium 500 MHz
2GB of RAM
20GB of free hard disk space
A DVD-R (W) or DVD + R (W) Drive
Frequently Asked Questions
  • Is it legal to copy a DVD?
    Legality depends on the laws in your region. Generally, copying or creating a DVD for personal use is acceptable. However, you should always comply with local regulations to avoid any legal issues.
  • Is DVDFab DVD Copy safe to use?
  • How to duplicate a DVD with copy protection?
  • Is there a free DVD Copy software of DVDFab?
  • How to copy a DVD to hard drive?
  • How long does it take to copy a DVD with DVDFab DVD Copy?
  • What is the difference between DVD Copy software and DVD Ripper software?
Contact icon
Contact Us
Can't find the answers you're looking for? If you have other problems, don't hesitate to contact us.
Our Service Team is always ready to help. Your problem will be addressed as soon as we can.
Contact Us
Tips & Tricks to Copy DVD Easily
  • How to Remove Copy Protection from DVD Easily [2025 Update]
    DVD copy protection can prevent you from creating backup copies or transferring content to other devices. This guide first reviews and compares the best and free DVD decryption software with detailed usage instructions, before delving into the various protection types and methods to successfully overcome them for personal archival purposes.
    By Diana Smith - Sep 23, 2025
  • How to Convert DVD to USB Drive: Tools, Formats and Steps Guide
    Converting DVD to USB is a common need when archiving movies or home videos. This guide compares tools like DVDFab, MakeMKV, and HandBrake, explains format choices, and shows step-by-step how to copy DVD to flash drive, while avoiding playback errors on TVs, cars, and media players.
    By Diana Smith - Sep 22, 2025
  • How to Copy DVDs to Hard Drive Free on Windows 10/11, Mac and Linux?
    Copying DVDs to hard drive allows users to protect their collections from damage while enjoying seamless playback on TVs and various devices. This article explores the best methods to save a DVD to hard drive on Mac, Windows and Linux, providing clear steps and reliable software solutions.
    By Wenny Yan - Sep 25, 2025
