Top 7 Best DVD Editing Software for Windows & Mac [2025 Update]
Summary: Different from editing a video, editing DVD videos is more difficult because you need to extract the video from your DVDs first. That is to say, a DVD editor should serve as both a video ripper and editor. In this article, we tried to cover the best DVD editing software for Windows and Mac for your convenience.
We know that video editing is not difficult, as multiple top-notch video editors are easily accessible in the industry for Windows and Mac. But what if you want to edit a DVD video or need to cut some of its unwanted parts? This is impossible with any video editor, and it will require you to use a specially designed DVD editing program.
You have to import DVD videos into the editor first, so you need more than just a DVD editor, it should also be capable of ripping DVDs. That's the main purpose of this article, which is to introduce 7 best DVD editing software for Windows and Mac.
1. DVDFab DVD Editor
DVDFab DVD Ripper is an excellent DVD editing software program that enable you to rip and edit any copy-protected DVD/ISO image/folders according to your needs. It's built-in video editor allows you to crop, trim, merge DVD video, add effects, watermarks and subtitles, and even adjust video color as you like.
💻Working System: Windows 11/10/8.1/8/7 & macOS 10.13 - 15.x
- Keep updating to support the newly-release encrypted DVDs.
- Support batch conversion and powerful GPU acceleration.
- Rip the edited DVD to various compatible formats and compress the big DVD videos.
- Serve as a DVD to MP3 converter and editor that extracts audio from DVD in high-quality.
- Convert DVDs to play on 247 different devices like PlayStation 4, Xbox One, iOS, Android, etc.
- The metadata info. of the original DVD will be displayed on the media server when you play it.
- Clean cuts: Remove trailers/ads/outtakes; join chapters into one seamless movie.
- Perfect framing: Fix black bars, change aspect ratio, or crop for social-friendly sizes.
- Brand or protect content: Add logos or semi-transparent watermarks.
- Make it look right: Correct color cast, boost contrast, sharpen soft footage.
- Tell the story: Add and style subtitles; adjust timing to match dialogue.
- Sound your way: Extract audio (e.g., DVD to MP3) or export edited videos with your chosen codec/bitrate.
2. Handbrake
HandBrake is a free, open-source DVD editing/transcoding app for Windows, macOS, and Linux. It’s ideal for unprotected/home-made DVDs, letting you crop/resize, deinterlace, add subtitles, and convert your video to modern formats like MP4/MKV/WebM using efficient codecs.
💻Working System: Windows, Mac, and Linux
- Edit before you export: Crop and resize the frame; apply deinterlace/decomb, denoise, and sharpen filters; set constant or variable frame rates; add chapter markers.
- Subtitle control: Import external SRT, pass through or burn in subtitles, choose default tracks, and adjust timing.
- Audio options: Mix down tracks, adjust volume and dynamic range (DRC), and choose popular codecs/bitrates.
- Batch & presets: Queue multiple titles at once and use built-in device/quality presets for quick setup.
- Export formats: Transcode DVD video to MP4 (M4V), MKV, or WebM with modern codecs (e.g., H.264/H.265/AV1, where supported).
- This DVD editor only support 3 output video formats.
- It can not rip copy-protected DVDs without additional program.
- It may not be easily operable particularly for individuals using it for the first time.
3. WinX DVD Ripper Platinum
WinXDVD Ripper platinum is a dedicated DVD ripping and editing software that help you to rip your DVD in the same original quality. You will also enjoy its use to clone the DVD to an ISO image or folder. By trimming, cropping, merging, and adding subtitles or watermarks, you can further improve and personalize DVD content with its editing features. Furthermore, fast ripping speed and advanced video and audio parameter settings are provided by WinX DVD Editor.
💻Working System: Win 11/10 or lower & Mac Ventura or lower
- Edit DVDs: You can optimize the final DVD size, apply subtitles, cut or trim video and remove black bars. It will also help you to set codec, resolution, frame rate, and bitrate.
- Multiple DVD output formats: You can convert DVD to MP4, AVI, FLV, WMV, and other formats.
- Multi-core CPU support: The multi-core CPU supports delivering outstanding DVD image quality.
- Hardware DVD encoding/decoding: It offers hardware encoding, decoding, and integrated DVD video processing.
- There is no option for automatic cancellation online.
- Unable to rip all copy-protected DVDs and Blu-rays.
- The trial version only allows for ripping up to 5 minutes of video.
- The licensing terms for the free and platinum editions are confusing.
4. VLC Media Player
Although VLC Media Player is best known for its media playback capabilities, it also serves as a basic DVD ripper for Windows, Mac, and Linux. It allows users to convert DVD videos into widely supported digital formats such as MP4, WMV, and MKV. In addition, you can customize various audio and video parameters including bitrate, resolution, and frame rate to suit your desired output.
💻Working System: Windows, macOS, Linux
- Basic edits with filters: Crop/resize, rotate/flip, deinterlace, denoise/sharpen; adjust brightness/contrast/saturation; set bitrate, resolution, and frame rate.
- Subtitle handling: Add/burn subtitles and select default tracks during conversion.
- Audio controls: Choose tracks, normalize/adjust volume, and transcode to popular codecs.
- Free & versatile: Open-source, includes media conversion, simple screen recording, and wide format playback.
- Export formats: Convert DVD video to common containers like MP4/MKV with widely supported codecs.
- The editing settings are not very intuitive, and there is no live preview during the editing process.
- Unable to rip newly-released DVD videos with protection mechanism.
- DVD ripping process takes a long time.
5. Mac DVDRipper Pro
Mac DVDRipper Pro is a user-friendly DVD editor software designed for Mac users to effectively edit and back up scratched or broken DVDs. With this DVD editing program, you can ignore unnecessary trailers and ads and rip only the DVD movie to high quality M4V files that can be conveniently dropped into iTunes. Moreover, it also aids in improving battery life by converting energy-consuming DVDs into digital files.
💻Working System: Mac OS X 10.13 or higher
- Main-movie extraction: Capture only the feature film to M4V for playback on Mac, PC, iPhone, iPad, Apple TV, Android, and more.
- Edit & enhance: Enable/disable subtitles, optional HD upscaling (note: upscaling won’t add new detail), deinterlace, denoise, deblock/reduce artifacts, sharpen, and adjust colors.
- Framing control: Option to disable automatic black-bar cropping when you want full original framing.
- Only work on Mac system.
- Relatively slow DVD ripping speed.
- Unable to edit or rip copy-protected DVDs.
- Very limited output formats - only rip DVD to M4V format.
How to Choose the Best DVD Editor?
The table below contrasts five mentioned options on editing depth, subtitle control, format range, speed, and cloning.
| Product | OS Support | Editor Depth | Key Editing Tools | Subtitle Options | Output Formats / Containers | Accel / Batch |
| DVDFab DVD Editor (DVDFab DVD Ripper) | Windows 11/10/8.1/8/7; macOS 10.10–15.x | Advanced | Crop, trim, merge, rotate, speed, effects/filters, color (B/C/S/H), watermarks, subtitles | Import, burn-in or switchable; styling & timing | 1000+ video/audio formats (MP4, MKV, MOV, AVI, MP3, AAC, …) | GPU acceleration & multi-threading; batch presets |
| HandBrake | Windows, macOS, Linux | Moderate (filter-based) | Crop/resize, deinterlace/decomb, denoise/sharpen, chapter markers, frame-rate control | Import/pass-through/burn-in; default track | MP4 (M4V), MKV, WebM | Queue & presets (limited HW accel by build) |
| WinX DVD Ripper Platinum | Windows 11/10 (earlier); macOS (Ventura or earlier) | Moderate | Trim, crop (remove black bars), merge, subtitles, watermarks; quality/size controls | Add subtitles (basic) | MP4, AVI, WMV, FLV, etc. | Multi-core + hardware encode/decode |
| VLC Media Player | Windows, macOS, Linux (player also on iOS/Android) | Basic (filters only) | Crop/resize, rotate/flip, deinterlace, denoise/sharpen; basic color & audio | Add/burn; select defaults | Common targets like MP4/MKV | Limited; not preset-driven |
| Mac DVDRipper Pro | macOS 10.13+ | Basic–Moderate | Main-movie extract; deinterlace, denoise/deblock, sharpen, color tweaks; optional upscaling | On/off; basic handling | M4V only (iTunes/TV-app friendly) | / |
How to Edit a DVD Using DVDFab DVD Ripper?
Among the 5 DVD editing programs mentioned, DVDFab DVD Ripper stands out for its exceptional disc decryption, support for numerous input and output formats, diverse DVD video editing features, and impressive output quality. More importantly, it offers a completely free version to satisfy your basic DVD video ripping and editing needs. Therefore, we recommend you to try out DVDFab DVD Ripper.
Here we will show you how to edit a DVD videos while taking DVDFab DVD Ripper as an example:
Step 1: Open DVDFab DVD Ripper and Load Your DVD Video
Download and install DVDFab DVD Ripper and click on the ripper option. Insert the required DVD Disc or click on the "Add button" to add it. Use the "Drag & Drop" feature to upload an ISO file.
Step 2: Choose an Output Profile and Edit Your DVD Video
Tap on "Choose Other Profile," then click on "Format” to convert DVD to MP4 or other formats. You can also choose to rip your DVD to iPad, Android, and many other devices.
Go to the "Advanced Settings" and set the video and audio parameters as you want.
Then go to the "Video Edit" and click on the "Add text" option to add desired text on your DVD. The Video Edit part allows you to adjust brightness, contrast, and saturation, crop or trim the video. Moreover, you can speed up or down, and preview the final result. After doing all the settings, you need to click on the "Ok" button to save it.
Step 3: Start DVD Editing and Ripping Process
Finally, select where to save the video and tap on the "Start" button to start the ripping process. You will have complete control of managing the ripping process.
Bonus! How to Edit Blu-ray and UHD Videos?
For enthusiasts seeking top-tier editing tools for their Blu-ray and UHD collections, DVDFab offers professional solutions with its Blu-ray After Editor and UHD After Editor. These tools are specifically designed for the user's need to add or replace audio tracks and subtitles.
How to DIY Your Blu-ray with DVDFab Blu-ray After Editor?
This part takes Blu-ray as an example to introduce how to DIY audio and subtitles.
Step 1: Download DVDFab from its official website. Blu-ray After Editor can be found under Utilities on the main page. After clicking it, drag the source into the interface or use the"+" button to load the Blu-ray file.
Step 2: The main interface will display a list of all the Blu-ray titles once the source has loaded. Click the "Edit" icon behind the title. You can add or replace external audio and subtitle by selecting the "Audio" or "Subtitles" tab. The language and delay time can be adjusted in the "Settings" section.
Step 3: Click the "Start" button to initiate the Blu-ray DIY process. The procedure can be stopped at any moment.
To edit a DVD on Windows 7, you will need to use a third-party DVD video editing software. Some popular options include DVDFab DVD Ripper, HandBrake and Freemake Video Converter. Among them, DVDFab can easily bypass DVD copy protection and offers rich editing and customization options.
To edit a DVD on your Mac, you will need to rip the contents of the DVD onto your computer first. Once you have ripped the DVD, you can then edit the footage as desired. Make sure to save your edited project in a compatible format (such as MP4) before burning it back onto a DVD if needed. Fortunately, DVDFab enables you to do it all in one program.
In this article, we tried to cover the best DVD editing software for editing DVD videos on Windows and Mac. However, DVDFab DVD Ripping software is the overall best video editor and ripper for both operating systems. It will welcome you with its free trial of many advanced features. You can edit and convert any DVD to any popular format for playback on any device by using it.
![How to Convert DVD to MP4: 14 Best & Free Methods [2026]](https://r3.dvdfab.cn/upload/resource/convert-dvd-to-mp4-p2X3.jpeg)
