1080p to 4K Upscaler: How to Use It? [Solved]
Summary: Are you looking reliable solution to upscale 1080p to 4k for a better view on a 4K display or media player? What is 1080p to 4k upscaler? How to use it? This post covers everything you need when it comes to 1080p to 4k upscaler software. Read on for more details.
• Best free AI-based video enhancer software
• Upscale low-res videos to 4K resolution
• Enhance old videos to better quality
• Remove video noise and blur automatically
Are you looking for a professional 1080p to 4k upscaler to upconvert your HD videos or game console content to 4K for a better view on 4K Ultra HD TV or monitor? That’s really worth a shot! It’s not that necessary to spend dollars buying all the latest 4K movies or videos for home play. How about downloading HD videos or movies from popular streaming service providers like Amazon Prime or Netflix? What about vitalizing your old classic movies or collected videos in the form of resolution upscaling and quality enhancement with the aid of 1080p to 4k upscaler software? If you have such a plan, go ahead and read through this post. You will make it!
Table of Contents:
PART 1: 1080p vs 4K: What’s the Main Difference
PART 2: Can I Upscale 1080p to 4K? What is 1080p to 4K Upscaler?
PART 3: Best 1080p to 4K Upscaler Software:Video Enhancer AI
PART 4: Easy-to-use 1080p to 4K Hardware Upscaler
PART 5: Trust-worthy 4K Media Player: Hardware & Software
PART 6: FAQs: Why Do People Ask
From 480p (SD) to 720p (HD), 1080p (Full HD), all the way up to 4K (2160), 4320p (8K), people have witnessed the rapid revolution of resolution and are becoming accustomed to seeking peak viewing experience. Usually, resolution, in terms of TV hardware, refers to the number of pixels that constitutes the picture on TV screen. Thus, the term has been the most common specifications in TV industry. The higher the resolution, the better image quality will be. See below chart.
Resolution |
Horizontal x Vertical Pixels | Other Names | Compatible Devices |
720p | 1280x720 | HD, High Definition | TVs |
1080p | 1920x1080 | Full HD, FHD, HD, High Definition | TVs, Monitors |
WUXGA | 1920x1200 |
Widescreen Ultra Extended Graphics Array |
Monitors, Projectors |
2K | 2560x1440 | QHD | Projectors |
UHD | 3840x2160 | 4K, Ultra HD, Ultra High Definition | TVs, Monitors |
Cinema 4K | 4096x | 4K | Projectors |
8K | 7680x4320 | 8K UHD | TVs |
Let’s take 1080p and 4K for example. When you watch movies on a 1080p TV and a 4K UHD TV, sharp contrast will be formed in terms of screen size, resolution, and image quality. On the UHD TV, what you see from the screen will be much more crisp, totally visible to the human eye. Likewise, it goes for video streaming on TV monitors.
Thanks to the contributions of advanced technology and public demand, something impossible in the past can be turned into reality at present. If you happen to have a 4K UHD TV but a favorite movie video of 1080p resolution, what will you do? Just make do with the inferior HD quality on 4K UHD TV or upscale 1080p to 4K for a better view on 4K TV? If I were you, I would choose the latter without the slightest hesitation. Make the best use of everything that brings you desirable results.
Can I upscale 1080p to 4K? Put simply, you can resort to professional 4K upscale software or hardware tool to upconvert 1080p to 4K for better picture quality. Then what is 1080p to 4k upscaler? The software or hardware capable of turning 1080p input into 4K output is called 1080p to 4k upscaler.
As mentioned above, do you know any reliable AI-based video enhancer? In this part, we will focus on the rising star in the video upscaling field, DVDFab Video Enhancer AI, an AI-based 720p/1080p to 4K upscaler boasting below features.
- Available on: Windows 10
- Pricing: Free trial; affordable subscription
- Upscale low-res videos to 4K resolution
- Enhance old videos/movies/TV shows to better quality
- Easy-to-use interface and compatible with advanced HW technologies
Note that all video blur or noise will be removed in one click, video brightness, contrast, and saturation will be adjusted automatically and intelligently. Plus advanced hardware acceleration technologies, Video Enhancer AI can finalize the video upscaling process within a short time out of your expectation.
How Can I Upscale 1080p to 4K with Video Enhancer AI?
Powerful as DVDFab Video Enhancer AI it is, you will find much easier to upscale your HD video with this 1080p to 4k upscaler software.
Step 1: Launch the 1080p to 4k upscaler software and load video source
You are recommended to download the software from DVDFab official site. Remember you can enjoy free download of this 1080p to 4k upscaler PC program at ease and process 5 videos at most without any cost. Subsequently, add video source via the Add Videos button after installing and running the program.
Step 2: Customize video output
Select your desired AI Models (for Movie, for Home, or for Web video), Output Format (MP4.H264, MP4.265, MKV.264, MKV.265), Resolution (Same as Source, 200%, 480p, 720p, 1080p, 2160p), and Bitrate (Same as Source, Standard Quality, High Quality).
Do not forget to check your PC hardware information by clicking the Preview AI button, which points out Your CPU or GPU is capable (not capable) of upscaling video with AI. This popup window reminds you to ensure basic system requirements for the sake of desired video output.
Step 3: Wait for and save the enhanced results
Once done, click the Start button to upscale 1080p to 4k and wait for the final enhanced work.
Seen from above, you can vitalize your old videos, movies, or TV shows with this AI-based 1080p to 4k upscaler software in three simple clicks. One more word, if you long to Rip Blu-ray movies to 4k videos, or convert DVDs to Blu-rays, you’d better try out another AI-driven AI upscaling, Enlarger AI, which works seamlessly with DVD/Blu-ray Ripper, DVD to Blu-ray Converter, and Video Converter, able to upscale video from 480p to 1080p, or from 1080p to 4k.
For most game console buffs, upscaling 1080p to 4k will be a must for better image quality and color correction, thus bringing better game experience. After discussing 1080p to 4k upscaler software, now let’s gave a quick glance over 1080p to 4k hardware upscaler. When you Google 4k upscaler, the first search result popping up on the page will be Amazon store, meaning 1080p to 4k upscaler is available on Amazon online. Now let’s check its hot-selling 1080p to 4k hardware upscaler.
Marseille mClassic
- Connector type: HDMI, Plug-and-Play
- Compatible devices: Personal computer or TV
- Be the first add-on graphics processor for video game consoles able to upscale SD to HD, or HD to 4K, no compromise on color processing, delivering a perfect balance between sharpness and naturalness via fixing sharp edges and textures
- Analyze and improve every single pixel for beautiful image with no lag, and refocus spots automatically to create the best possible picture
- Work with Nitendo Switch, Retro Consoles, DreamCast, NES, N64, PlayStation, GameCube, PS2, PS3, PS4, Xbox 360, Xbox One, and more
How to Use This 1080p to 4K Upscaler Hardware?
Just insert mClassic into the HDMI port on your game console or dock, and connect the other end to your TV or monitor with an HDMI cable. The patented graphics post-processor technology dynamically enhances video quality with effectively no lag. That the whole video upscaling process.
Therefore, those fond of quality game consoles are recommended to use this 1080p to 4k upscaler to create quality picture image for better visual experience.
After upscaling 1080p to 4K, you need to find suitable 4K media player so as to enjoy upscaled video quality. Here is a brief list of prevailing media player, both hardware and software, for you option.
Hardware
Sony UBPX700: [$149.99] 4K Ultra HD Hi-Res Audio Wi-Fi Built-in Blu-ray Player
LG-UBK80: [$179.99] 4K Ultra HD Blu-ray Player
Software
DVDFab Player: [Win & Mac, PC & TV Mode] Best 4K media player for UHD/Blu-ray/DVD/HEVC/H.264 video playback with HDR & menu navigation support
5K Player: [Win & Mac] Play 4K/5K/1080p HD videos
VLC Media Player: [Win, Mac, Linux, Android & iOS] Play UHD and other videos
Now let’s focus on two questions that might haunt your mind frequently.
Does 1080p upscaled to 4k look better?
It has been proven that you can upscale video to 4k with professional tool. Truth is that the upscaled 4K video displays much better quality than original 1080p video in resolution and image quality, but still a bit inferior to native 4K video. Hence, you need to face reality.
Does 4K TV upscale automatically?
Normally, most 4K TVs adopts a processor named upconverting or upscaling to convert incoming low-res video source to higher one to fit 4K screen with better picture quality. Otherwise, low-res video in HD resolution will not fill the whole 4K display, thus causing unpleasant visual experience.
