Understanding the Difference Between 4K and 8K
Summary: The resolution of a video defines the number of pixels that a device (such as PC monitor, TV, tablet, laptop, and even smartphone displays) can display in each dimension. Normally, the resolution is described as width × height, such as 1920×1080, where 1920 is the width and 1080 is the height that the device display can be converted in pixels. Most popular video resolutions are 4K vs 8K. Although 4K and 8K both are considered as UHDTV (ultra-high-definition television) resolutions together, they have their own exceptional features. This article sheds some light on the basics of video resolution and also informs us about how these resolutions are different from each other. But, before we find the difference between 8K vs 4K, let us have a look at what is 4K vs 8K TV video resolution?
What is 4K Resolution?
Also dubbed as Ultra HD (UHD), 4K is a popular display resolution nowadays. People know that resolution is just the number of pixels in the format of length x width that a device has. 4K is nothing but a horizontal display resolution of almost 4,000 pixels. The DCI (Digital Cinema Initiatives), a branch of motion picture studios that develops standards for digital cinema, describes 4K video resolution as 4096 x 2160.
Movie projection sector also employs this DCI standard. On the other hand, monitors, normally dubbed as 4K, comes with a 3840 x 2160 resolution. The same goes in the case of consumer media and 8K vs 4K TV. Modern GPUs show support for 4K/Ultra HD (UHD) output, although a quite superior graphics processor is needed to play games in 4K. This is the reason why most users prefer running at 1080p resolution.
What is 8K Resolution?
Rationally 8K will be 2 times the resolution of 4K, but fascinatingly, that is not the case. In this battle of 8K TV vs 4K, 8K is termed as UHD-2. Currently, it is the highest UHDTV or ultra high definition television resolution. It defines the vertical resolution of 4320pixels and horizontal resolution of 7,680 pixels. Hence, it forms the entire picture dimensions of 7680 × 4320. 8K resolution is in fact, 4 times the pixels of 4K and 16 times the pixels of HD. Therefore, 8K equates to 33 million or 7,680 × 4,320 pixels.
In simple words, when four 4K TVs are positioned in a four-by-four group, that is a lot of pixels. That is why 8K can indisputably be noticed when on larger displays or up close. Nowadays, companies are beginning to declare the obtainability of their 8K device. Earlier, there was a bit 8K Ultra HD resolution movies to watch at home. But eventually this situation is altering. A few years back, Vimeo (the video-streaming site) added support for 8K, but now it already has over 6,000 videos hosted in 8K.
4K VS 8K: What’s The Difference Between 4K and 8K?
In this 4K TV vs 8K TV resolutions, there are some perceptible technological differences. They are very different when it comes to frame rate, resolution, broadcasting, audio channel, and viewing angle. Below are some points that cover basic difference between 4K and 8K video resolution to help you better understand. Have a look.
Frame Rate
Frame rate is nothing but the number of images or frames that are shown per second in a monitor. It is related closely to video quality and broadly employed in synchronizing pictures and audio. It is claimed that the higher the frame rate is, the more exceptional the video quality of the output will be. 8K resolutions supports up to 120 Hz of progressive frame rate as compared to 4K that supports only at 50 to 60 frames per second.
Resolution
A vertical resolution of 4320 pixels and a horizontal resolution of 7680 pixels describes 8K UHD resolution. On the flip side, a vertical resolution of 2160 and a horizontal resolution of 3840 describes 4K UHD. Hence, the 8K UHD has two times the vertical and horizontal resolution of the 4K UHD. Normally, the 4K UHD has 8.3 megapixels, while the 8K UHD has a humongous 33.2 megapixels.
Viewing Angle
When it comes to viewing angle, it refers to the maximum number of angle that users can see with tolerable visual performance on a display device or a monitor. It is an essential feature that effects users experience of viewing. When it comes to viewing angle, 8K support horizontal viewing angle of 100 degrees while 4K provides a viewing angle of 55 degrees. 8K permits for more visual angles as compared to 4K.
Audio Channel
4K and 8K are very different when it comes to supporting audio channels. 8K shows support for 22.2 audio channel, while 4K shows support for 5.1 audio channel. Apart from this, while using 8K, user might experience the 3D super stereo.
Broadcasting
H.265 (also known as High-Efficiency Video Coding) must permit 4K streaming content with a 20 to 30 Mbit/s of bandwidth. Earlier, the capability of a transmission network to transmit 8K resolution was limited by internet speeds and relied on satellite broadcast to transfer the high data rates. This requirement will seemingly drive the acceptance of standards for video compression and place distinguished pressure in the near future on physical communication networks.
In addition to this, as per a latest research, Host Broadcasting Services earlier claimed that minimum 75% of the broadcast limit on every match might come from 4K cameras (wrapping almost every main angle), with instant replays. Earlier, FIFA World Cup was the first event in which all matches were shot in 4K. Experimental transmissions of the 8K resolution were experimented with the 2012 Summer Olympics.
Below is the table that tells the differences between 4K and 8K resolutions in short. Have a look:
Specifications |
4K |
8K |
Pixels |
4K Ultra HD devices have a pixel count of 8 megapixels or 8 million. |
8K boasts 33.2 megapixels or 33 million pixels. |
Resolution |
4096 x 2160 pixels for digital cinema or 3840 x 2160 pixels for Ultra HD television. |
Vertical resolution of 4320 pixels and horizontal resolution of 7680 pixels. |
4 times as compared to Full HD resolution. |
16 times as compared to Full HD resolution. |
4K resolutions are 4096 x 2160 pixels for digital cameras. |
8K resolutions are 8192 x 4320 pixels for digital cameras. |
Frame Rate |
50 to 60 FPS |
120 FPS |
Audio Channel |
4K Ultra HD supports 5.1 audio channel. |
8K Ultra HD supports 22.2 audio channel. |
People can also use the Super stereo with the help of 8K TV in the coming period |
Viewing Angle |
Comes with a viewing angle of 55 degrees. |
Comes with a viewing angle of 100 degrees. |
Permits you to see videos through more visual angles. |
Bonus: Convert Videos to 4K and 8K With DVDFab Video Converter
What if you had 4K and 8K compatible devices but no content. Nowadays, companies are launching 8K and 4K devices. Hence, there is no shortage of devices. However, when it comes to content, not a lot of content is available. Even though streaming platforms have recently started to launch their content in 8K and 4K resolutions, not a lot more is available now.
Hence, one of the best option is to convert the available content to 8K and 4k resolution and enjoy it on compatible device for offline viewing. In this way, you get to enjoy the beauty of high resolution, that too offline. And in order to convert videos, DVDFab Video Converter is the best option that users can have. The tool can be used to enhance the video size as well as change the resolution of the video without losing any quality. Follow the below steps to know how to use this tool to change the video resolution.
Step 1: Download and install DVDFab 12. Next, tap the Convert module on the main screen.
Step 2: Click the + button on the main screen to upload the source video. You can also drag and drop the video to upload it.
Step 3: Once the video is loaded, click on the Video Edit option to open the editor.
Step 4: Once the editor is open, Adjust the video parameters as per your needs. Once done, click OK.
Step 5: Doing this will exit the editor and you will be redirected to the main page. Now, select the desired output format of the file.
Step 6: In addition to this, you also get the option to decide the size of the file by clicking on the drop down list next to the format list.
Step 7: Select the file size with the highest resolution so that it is viewed better on higher-end devices.
Step 8: Next, click Start and wait for the process to end.
Which top TV brands make 8K TVs?
With TV technology for 8K being the newest developing tech, it is no shock that users are seeing tons of companies announce them as part of their portfolio. Samsung was one of the first, followed by Sony, LG, TCL, and Hisense. All these companies have declared their 8K models and have launched a few in the market, as well.
Why 8K TVs are preferred over 4K TVs?
If you are thinking about upgrading to a bigger TV or a Smart TV with the newest TV technology, 8K UHD technology is ideal for sports, blockbuster movies, and 8K resolution gaming, among others. An 8K big-screen TV offers you an exceptional viewing experience hence you feel right amongst all the action. An 8K big TV is also ideal for a smaller room since it offers you perfect picture definition close up—from a just 2.5 meters for the enviable 82” 8K TV, 2.3 meters for a 75” 8K TV, and 2 meters away for a 65” 8K TV, all due to the unbelievable 8K resolution.
In the end, it can be said that 8K display resolution is the heir to 4K resolution and is surely far better. Both 8K and 4K, the two Ultra HD formats, can offer excellent visual sense and super vivid image. It is, on the other hand, a luxury for common people to buy a 4K or 8K UHD TV.
It is also hard to get different contents which are entirely compatible with such high-tech products. Hence, to deal with this situation, users can convert normal content to 4K and 8K resolution. This can be done using DVDFab Video Converter. Itis the best option that users can have. The tool can be used to enhance the video size as well as change the resolution of the video without losing any quality. A
