Edit MKV | Top 6 Best Free MKV Video Editors
Summary: Can you edit MKV file? What are the best free MKV editors to edit MKV files? How to edit MKV files free and easily? This post details the best MKV video editors that enable you to edit MKV files as desired. Read on to take your best pick.
Can you edit MKV files? How do I trim MKV files? Having the best free MKV editor at hand will facilitate your quality playback on supported mobile devices or upload on specific social networks.
Lots of people think editing MKV videos takes a lot of work and patience but that’s not always the case. The truth is that anybody can do basic video editing nowadays thanks to the myriad of easy-to-use editing tools now available. Finding software like that online isn’t that big of a problem but you will need to do a bit of research if you have the best MKV file editor for the job. This article focuses on the best free MKV editors, in particular, most of which will also let you edit video in any format.
1. Top 6 Best Free MKV Editors to Enhance Video Quality
Based on the detailed comparison, user reviews and personal experience, here are the top 6 best MKV video editors that can be used to edit MKV files free and easily.
UniFab Video Converter: Best MKV Editor for Lossless Output
If you want the best MKV editor out there we recommend trying UniFab Video Converter, a professional yet easy-to-use video converter that allows you to convert video or audio and edit it as desired. First, let's check its feature highlights as below.
Just as its name suggests, this best MKV editor-free tool is meant to be used primarily as a video converter. In that regard, it’s one of the best tools of its kind as it can support all major formats, including 1080p/4K/8K and 3D ones, as well as video to audio conversion. UniFab Video Converter can also convert files for tons of brand devices and allow users to import videos that need to be converted directly from their mobile devices and then export them back once the process is complete.
As far as the editing options are concerned, UniFab Video Converter offers plenty of tools that can help you customize videos to your liking. For example, the Advanced Settings menu lets you pick the encoding method, resolution, video quality, and frame rate of the video, among other things. You can also edit.MKV files by playing around with the audio options or by choosing if you want soft or hard subs on your video. Meanwhile, another menu known as Video Edit contains another set of useful tools that let you crop and trim the video or change color proprieties like brightness, contrast, and saturation. The video editor MKV tool also makes it easy to add your own subtitles and watermarks.
SolveigMM Video Splitter 5: Simple MKV Editor
This MKV video editor promises high speeds and lossless editing tools that are very simple to use. The interface is quite basic but that actually makes it a perfect choice for users interested in quick and painless editing jobs that don’t require a lot of fancy extra tools. Video Splitter 5 can help you remove or join together different parts of a video, repair damaged files, add or remove subtitles, and more. Overall, it’s a pretty simple MKV editor designed for a few specific tasks but is always able to handle those tasks very well.
Avidemux: Popular MKV Editor
Avidemux is a very MKV editor open-source program that can also support a wide variety of other formats. This software is perfect not only for cutting parts of a video and converting them to different formats but also for extracting, merging, and even building new MKV files from scratch. The MKV video editing software also offers a variety of filters that can be used to change the appearance of videos in various ways. The software is a bit harder to use than others on our list but Avidemux’s minimalistic interface makes it an accessible tool for users of all skill levels.
MKVToolnix: Easy-to-use MKV Video Editing Software
MKVToolnix is yet another simple to use tool that doesn’t require a lot of previous experience. Just as its name indicates, this MKV editor software was designed specifically to edit MKV video files so its approach is a bit more focused compared to some of the other entries on our list. As MKV video editing software, MKVToolnix is pretty basic and doesn’t offer a whole lot of advanced features. However, what’s really handy about this tool is that you can use it to easily create your own MKVs by using putting together any video and audio files you may have at your disposal.
Shotcut: Free MKV Editor
Shotcut is a free open-source MKV editor that has a lot to offer to those who take the time to learn all its ins and outs. The software can generate truly professional-looking videos but the interface is quite complicated and it may take you a while to get used to it. Fortunately, at least basic functions like applying filters and cropping videos are fairly straightforward. If you want to start playing around with all the advanced stuff, however, be prepared to invest a lot of time because Shotcut has a very steep learning curve.
VSDC Free Video Editor: Non-linear MKV Editor
Last but not least we have VSDC Free Video Editor, a software that strikes a good balance between functionality and ease of use. Despite offering a whole lot of advanced features, the tool is actually pretty easy to learn, which makes it a good pick for beginners and veteran video editors alike. VSDC is a non-linear MKV editor that allows you to work with multiple scenes and transitions at a time. You can take clips or bits of text and add them anywhere on the timeline or add various visual and audio special effects. The best thing about VSDC Free Video Editor is that it can actually also be used as an audio and image editor in addition to an MKV video editing software.
2. How to Edit MKV Files Free & Easily with Peerless MKV Editor
As mentioned above, you must have figured out which MKV video editor you shall choose based on a detailed description of their advantages and disadvantages. To cut a long story short, to edit MKV files as desired, even than expected, you are advised to choose UniFab Video Converter, a versatile yet powerful video converter fully dedicated to enhancing your video quality while converting video formats.
Install and launch the UniFab Video Converter on your device first.
Select the mkv video you want to edit, add it into UniFab Video Converter.
Customize the format and video resolution you want, then, click the Start button.
MKV is one of the most popular multimedia formats you’re going to come across so it can be very useful to know how to edit MKV files for better quality. All of the best free MKV editor tools we discussed today can help you with that so it’s up to you to decide which one might work best for your particular needs. It’s probably best to start off with a very simple to use the tool and try making a few simple edits until you get used to the process.
Then, you may want to try your hand at more complex software that offers advanced features. Alternatively, you could simply grab the UniFab Video Converter and shot two birds with one stone. The MKV editor is both simple to use and offers a lot of great editing features. Of course, the software is not just a solid MKV editor, it’s also a very reliable video converter so there’s a lot to look forward to here. One more word, if you want to convert MKV to MP4 free and fast, do not miss out on this post.
