How to Convert MP4 to AVI Format: Know All the Details
Summary: You are at the right place if you are looking for a video converter to convert MP4 to AVI format. Now engage in a wise conversion of MP4 to AVI files.
Introduction
If you are running clueless to convert your MP4 files to AVI files, your search will undoubtedly be over now. Converting MP4 to AVI is no longer a tough row to hoe as we have you smartly covered with the same. Before jumping on to the conversion process, let us quickly peek at what MP4 and AVI files are.
MP4 files are usually designed for high video quality, and their storage capacity is relatively low, with the most common codec being the standard H.264. MPEG-4 format is widely used in Blu-ray and HD TV. Generally, the videos published on the internet are in MP4 format.
Microsoft developed the AVI files to produce a good image quality but require a high storage capacity. You can play AVI files on multiple media players. By converting your MP4 videos to a more appropriate format, say AVI format, you can easily use a DVD player.
You can use various video converters to convert MP4 to AVI files. Let us quickly check for some of the best and most convenient MP4 to AVI conversion methods.
How to Convert MP4 to AVI Using the Best Video Converter
There are various video converters available to convert your MP4 to AVI. But the best one is right before you, DVDFab Video Converter.
DVDFab Video Converter: Convert MP4 to AVI Smoothly
DVDFab Video Converter is an outstanding professional video converting software that smoothly converts your audio and video files without compromising quality.
It is a powerful software that can convert your videos into multiple formats, including 1080p, 4k, 5k, and 8k. It also converts your videos to mainstream audio formats, and you can play them from mobile devices to home theaters for a seamless experience.
Why Prefer DVDFab Over Other VideoConverters?
Some of the features of the DVDFab video converter include:
- Customizes audio and video parameters:
You can adjust the parameters of your output video by customizing the audio and subtitle of your preference. You can compress the video size without compromising on the quality.
- Converts audio and video in multiple formats:
DVDFab can read all the input formats across all the devices and then convert the audio files into multiple formats, including MP3, MP4, AAC, WAV, etc.
The video files are converted into MP4.8k, MKV Passthrough, MP4 Passthrough, etc., to run on all possible media players and devices.
- Supports saving metadata of the videos:
DVDFab supports saving the metadata information in the conversion of the TV shows, including the title of the show, number of seasons and episodes, etc.
- Advanced conversion speed:
The conversion speed of DVDFab is really quick as it supports multithreading, NVIDIA CUDA, and Intel Quick Sync, which boosts its speed 30 times the average rate.
- Provides built-in non-linear video editing:
Now you can edit, crop, and trim your videos in the built-in browser of the DVDFab that provides you with a non-linear video editing function. You can customize your needs according to your preferences.
How to Convert MP4 format to AVI format Using DVDFab Video Converter
Some simple steps to convert your MP4 files smoothly to the AVI format includes:
- Step 1: Launch the app:
Install and launch the DVDFab Video Converter app on your device
- Step 2: Select the Converter module:
Now, from the option bar, select the Converter module from DVDFab 12. Either drag and drop your source MP4 video or click on the + button to load the MP4 file
- Step 3: Choose a profile:
From the profile drop-down menu, hit the 'Choose Other Profile' option. Then select the AVI format after navigating to Format >Video >General/ Filter. You can also click on the 'Device' button to convert the video to any device of your choice.
- Step 4: Customize your output video
You can now customize your output audio and video. You can also try its built-in video editor feature for advanced settings. Click the option of 'Save to' and select the output directory from the folder icon.
- Step 5: Start the conversion process:
Now click on the 'Start' button to quickly convert your files from MP4 to AVI videos. The video will automatically convert to your chosen target profile, and during the process, you will also be provided with the progress details.
If you want to explore some other ways to convert MP4 to AVI files, you can also use a few options, such as,
- VLC
- Cloud Convert
1. VLC Media Player
VLC Media Player is a comprehensive and multiplatform player equally versatile in converting MP4 to AVI format. You can convert your MP4 files from multiple sources with a single click and choose a preset profile and embed subtitles in the output videos. It is available in a free version that supports Linux, Windows, and MacOS.
How to Convert MP4 to AVI Using VLC
Follow the below-given steps to convert your files using VLC:
Step 1: Install VLC and launch it.
Step 2: Select the 'Convert/Save' button from the 'Media' option.
Step 3: Using the 'Add' button, select the MP4 file to be converted. Begin the conversion process by selecting the AVI format.
Step 4: Before conversion, select the 'MP4 to AVI' file using the profile drop-down menu in the convert window.
Step 5: Select the location to save your file from the' browse' button. Start the downloading process.
2. CloudConvert
CloudConvert software is an online tool that helps you convert your files easily. It supports more than 200 media formats, including MP4, AVI, WEBM, etc. it also allows you to change video resolution, file size, audio bitrate, and video quality. Using time codes, you can even trim your videos and use them freely to convert 25 files per day.
How to Convert MP4 Files to AVI Files Using Cloud Convert
Follow the below-mentioned steps for a hassle-free conversion of your MP4 files to AVI files.
Step 1: Visit the website of CloudConvert.
Step 2: Choose an MP4 file from your device using the 'Select File' button
Step 3: In the 'Convert to' field, select 'AVI'
Step 4: Select okay once you have set your parameters.
Step 5: Hit the 'Convert' icon to convert your file
Frequently Asked Questions
DVDFab Video Converter is currently the best video converter that helps you convert your MP4 files to AVI formats smoothly.
Yes. You can try VLC Media player and Cloud Convert softwares, among many others.
Yes. DVDFab Video Converter allows you to save metadata with the original videos. If you are interested in Amazon Prime video download with metadata, have a look at StreamFab.
A Quick Sum Up
By now, you must be pretty clear about opting for the best video conversion tool, depending on your preference. We have provided some of the best video converters to assist you with the MP4 to AVI conversion. You can select any one amongst those that best fits your needs.
Suppose you are still confused among the many options and are thinking about which one to try. In that case, you can choose DVDFab Video Converter as it converts your videos and audios into high-quality output videos and is equipped with many advanced features.
Install your software to convert your MP4 files to AVI formats for a customized and seamless viewing experience. If you want an OnlyFans downloader, have a look at StreamFab.
