How to Rip and Convert Blu-ray to M2TS with Blu-ray to M2TS Ripper?
12/25/2020
M2TS is the container format is commonly used for high definition video on Blu-ray Disc and AVCHD.M2TS can provide you better viewing experience than other common HD formats. If you want to convert your Blu-ray to video files in high definition playable on computer and other playback devices, you can convert Blu-ray to M2TS. DVDFab Blu-ray Ripper is an excellent Blu-ray to M2TS ripper which can help you do the conversion job efficiently and effortlessly. Now let’s have a look.
How to Rip and Convert Blu-ray to M2TS: Step 1 > Run DVDFab 10, choose the Ripper module and load the source.
How to Rip and Convert Blu-ray to M2TS: Step 2 > Navigate to the profile library on the top left corner of the main interface and choose Format > Video > M2TS.
How to Rip and Convert Blu-ray to M2TS: Step 3 > After the source is loaded in, the longest title, namely the main movie, will be selected by default. But here you can choose other titles. You also can choose the chapters, audio tracks, subtitles, define the names of the chosen titles, and do advanced settings according to your needs. You are even able to edit the Blu-ray video with the built-in editor.
How to Rip and Convert Blu-ray to M2TS: Step 4 > Click the "folder" button to select a directory to save the output video. And then you can click the "Start" button to start the ripping process.
For more detailed information about DVDFab Blu-ray Ripper, https://www.dvdfab.cn/blu-ray-ripper.htm.
