Ways to Convert HEVC to MP4
Summary: As HEVC is a way of compressing videos, converting the videos to MP4 is an option. It supports mobile phone devices, laptops, and other computerized devices that are used to stream videos.
Introduction
There are different ways that enable video conversion from HEVC to MP4, ranging from softwares to online websites. Some of the ways include:
- VLC player software.
- Handbrake software.
- Cisdem Video Converter for Mac users.
- HEVC Converter App, which is a DVDFab product.
Online websites used to convert HEVC to MP4 include;
- Convertio.co
- AnyConv.com
- FFmpeg
Software Tools in Converting HEVC to MP4
1. To Convert HEVC to MP4 Using DVDFab Video Converter
DVDFab Video Converter is software used to convert videos or audios from one format to another compatible with other devices. Output video files obtained are small but high-quality as the original videos.
Features of the DVDFab Video Converter include;
- Enables converted videos to be compatible with many devices like mobile phones.
- It supports audio, video, and video conversion.
- Enables conversion of different video formats like Hevc, Mkv to mp4.
- Retains the quality of the output files.
Steps to follow;
a) Launch the DVDFab and then load your source files. Once you have downloaded the software, launch it on your computer. They proceed to files to the software by adding buttons or drag and drop options.
b) Choose the profile to use and customize the output video or audio. Once your video has been uploaded into the DVDFab converter, you will have to select the “other profile option”. These will enable you to select the video format of your choice, like mp4. Then you can customize more video settings through the Advanced setting options. Once you are done, click on the save setting options. It will lead you to the output directory where your video will be saved and suggest a sharing option where you can share the video directly to YouTube with the help of the Windows 10 feature.
c) Start the conversion process of the video. When you are done with all the settings, click on the start button to start the conversion process of the videos from Hevc to mp4. The process takes a few minutes, and you will be able to access your video. Other features on how to hibernate and exit the program are all provided.
Pros of DVDFab Video Converter
- Help to create a customized playlist.
- Provides high video and picture quality.
- Supports most of the popular video formats.
- The software has amazing features that are used to customize output videos.
Cons of DVDFab Video Converter
- Requires skills and experience to use the platform.
- It’s not affordable to some people.
2. To Convert HEVC to MP4 Using VLC Player
VLC is a common media player used in many computerized devices; hence it can also be regarded as a video transcoder. It can convert HEVC to MP4 easily, and it supports both Windows and Mac systems.
Steps to follow to convert HEVC to MP4
a) First, download the VLC player freely from the internet. You can do so from the website www.videolan.org
b) Launch the software in your system. Then navigate to the “Media” option, then to the “Convert/Save” button to be able to access the “Open Media” window, which will pop up once you click on the Save button.
c) Now under the “File tab” option, click the “Add button” on the right side to find the location of the HEVC- encoded video file.
d) Once you have selected the button as directed above, click on the “Convert/Save” button to continue with the process.
e) The next step is to specify your output format as “Video – H.265 + MP3 (MP4)” or “Video – H.264 + MP3 (MP4).
f) Now hit the “Browse” button. Select a location and name your output file.
g) Finally, click on the “Start button” to convert the HEVC codec to MP4 using the VLC player.
3.To Convert HEVC to MP4 Using Handbrake
Handbrake is one of the popular open-source tools used to convert HEVC to MP4 for both Windows and Mac systems. It allows you to convert HEVC videos and other multimedia formats to the MP4 and MKV formats.
Steps to convert HEVC to MP4 are as follows
a) The first step is to download the handbrake software from https://handbrake.fr/ and install it on your computer.
b) Then Launch the Handbrake on your computer, ready to start the conversion process. After launching, drag the HEVC file to the main dashboard or click “Open Source” to choose the file you want to upload to the software.
c) Navigate to the “Summary” window, then select “MP4 File” as the output format of your video.
d) You can opt to switch to the video tab and reset the “Video Encoder.” This step is regarded as optional hence one can decide to do the settings or leave them as default.
e) The final step is to click the “Start button” from the top menu to start the conversion process.
Websites to Convert HEVC to MP4
1.Convertio.co
This is a web-based platform that supports different conversion types, which include x265 to MP4. You can easily save your converted files to your google drive or Dropbox.
To start with the video conversion process, follow the below steps;
a) First, open your browser and go to the convertio.co webpage using the link https://convertio.co/.
b) Then you will be required to upload the HEVC file from the local computer folder, cloud storage, or any URL where your video is saved.
c) Then select the output video format as MP4. This is how your video will be saved.
d) Then click the “gear” icons to bring up the “Settings” dialog box, then configure the codec, profile, level, constant quality, and many others. Once you are done, click the “Ok” button.
e) The final step is to press “Convert” to start the conversion process.
2.AnyConv.com
This is an online HEVC video converter that helps to convert various file types like video, audio, image, documents, and many others.
Steps to follow include;
a) Navigate to the https://anyconv.com/ webpage to start the conversion process.
b) Then click on the “Choose file” button to be able to import the HEVC video from your computer or where it is saved.
c) Then select “Convert” to change your video to MP4 format.
d) Finally, click on the “Convert” button to start the conversion process.
e) Once the process is done, you can download your converted video back into your computer.
The different ways to convert MP4 files back to HEVC. Tools one can use include both software and online website tools. Some of the items to use are Convertio, Media.io, DVDFab Products, and many others.
Let’s look at Convertio, an online website that one can use to convert MP4 to HEVC.
3.Convertio.co
Convertio is a free online web-based platform that one can use to convert videos to different formats that one might need. Steps to follow to convert mp4 to HEVC include;
a) First, upload the video to the convertio webpage. To upload the video, you will drag and drop to the website to start converting to the HEVC format.
b) Then start the conversion process. One can choose any other format apart from the HEVC video format.
c) You can adjust the qualities of your output video on the settings tab. You can change the resolution, quality, aspect ratio, and many others. Once you are satisfied with the settings of the output videos, Click on “Convert process” to start the conversion process.
d) Finally, download the converted into your system.
Advantages of converting HEVC to MP4.
1. It helps to save the storage space of the computer.
2. MP4 has many different device compatibilities; hence videos can be played from many different devices.
3. The software can be used easily, and they take less time to do the conversion process.
4. Video quality is not altered.
Disadvantages of changing HEVC to MP4.
1. When a person wants to use the software, it must be installed on the computer first.
2. Online websites require the internet to be accessed.
The advancement of the software industry has resulted in many tools that can be used to convert HEVC to the desired video output format. With the help of the mentioned tools above, including the HEVC converter app, one can easily change the format of the videos without compromising the quality of video. This can also help you save the space in your computer, converting to formats that use less space.
1. What is the importance of converting HEVC to MP4?
It helps to utilize space in your computer hence you can easily store as many files as possible. MP4 format is also easily compatible with many devices; hence one can play the videos in any other format.
2. What are the best tools one can use to convert HEVC to MP4?
Best tools to use include DVDFab products like HEVC Converter app, Handbrake, and online webpages like Convertio.co. They help to create video outputs of any desired output.
