How to Convert M4V to MP4 Free and Well [Updated]
Summary: Are you looking to convert m4v to mp4 for a better play on various devices or public sharing on social platform for personal or business purpose? You might have come to the right page. This post aims to recommend you the best solution concerning how to convert m4v to mp4 free, easily and fast. Check it right now!
- • Provides more than 20 video and audio editing tools
- • Enhanced video editing ability, such as editing filters, transitions, etc
- • 3-in-1 video editing tool that offer the most comprehensive solution
Do you want to convert m4v to mp4 efficiently? You might have encountered the most embarrassing situation when your media player reminds you that the current m4v file cannot be played? Despite the fact that there are numerous m4v to mp4 converter, easy to use yet versatile programs are few and far between. Anyway, this post offers you the best m4v to mp4 solution.
Table of Contents:
- PART 1: Why Need M4V to MP4 Converter
- PART 2: How to convert M4V to MP4 with Best Versatile M4V to MP4 Converter
- PART 3: Conclusion
It is an indisputable fact that M4V is a video container format developed by Apple Inc, similar to the MP4 format. The most essential difference between the two formats is that M4V files probably are protected by DRM copy protection since Apple applies M4V to encode video files in its iTunes store, which drives it difficult to share the files among the public.
In contrast to M4V, MP4 has been the most widely used and popular video format that is supported by almost all devices including media player, game consoles, TVs, or platforms including YouTube, Vimeo, Facebook, and Instagram. Considering this, it’s sensible to convert m4v to mp4 for a smooth playback and better sharing on social media sites for diverse uses. Hence, what’s the best m4v to mp4 converter? How to convert m4v to mp4 free and easily? To find the right answers, go and read through the next part.
PART 2: How to Convert M4V to MP4 with Most Versatile M4V to MP4 Converter
Among all possible m4v to mp4 converters, here comes the most versatile yet most professional desktop program, DVDFab Video Converter Pro, a 3-in-1 video converter and editor that allows you to convert m4v to mp4 quickly and edit video files with tons of basic editing tools and creative effects.
Compatibility: Windows
Pricing: Free trial, $59.99
Flagship features:
- Video Converter: convert videos or audios among 1000+ formats supported by various mobile devices or home theater systems
- VideoCruise: edit videos or audios with packed editing tools and creative effects
- Toolkit: process videos, audios or images via multifunctional toolbox for a simple and quick use
As the saying goes that each road leads to Rome, this versatile m4v to mp4 converter can convert m4v to mp4 free and fast in three simple ways. Check the following solutions with patience. No learning curve at all! Just free download DVDFab Video Converter Pro and choose desired module to proceed with m4v to mp4 conversion task.
Solution 1: How to convert m4v to mp4 with Video Converter
This m4v to mp4 converter performs well because it not only enables you to convert m4v to mp4 free and fast, edit video in simple clicks, and but also allows you to upscale low-res video from 480p to 1080p, or from 1080p to 4k for quality play on HD or 4K media players or TVs.
Step 1: Choose video converter module and add video source
After choosing Video Converter module, you will enter its operation interface. Select one profile as needed, and load video source to the m4v to mp4 converter.
Step 2: Customize output video quality
If you want to upscale video from 480p to 1080p or from 1080p to 4k, choose Enlarger AI as the profile. Alternatively, Mobile (MP4), Theater (MP4), or other profiles (Common MP4) will be optional.
Advanced Settings: choose the Wrench icon to set output parameters for video and audio when needed.
Video Edit: click the Pen icon to make simple edits. You can improve video quality by adding watermarks, subtitles, credits, trimming, cropping, or rotating, or adjusting brightness and contrast.
Step 3: Start to convert m4v to mp4 and save the output
Once finish customized options, hit the Start button to convert m4v to mp4 free and quickly. If the GPU option is enabled, the whole m4v to mp4 conversion process will be considerably shortened. The real-time process depends on your video size and system configuration.
Solution 2: How to convert m4v to mp4 with VideoCruise
Step 1: Choose VideoCruise module and video aspect ratio
Step 2: Edit m4v to mp4 video with tools and special effects
Numerous function buttons including video speed change, color correction, and audio setting are available for you to polish video to perfection. To make your video footage more captivating, you can resort to tons of filters, overlays, and transitions.
Once done, click the Export button and choose mp4 as the final output. Set file name or directory. Here you can choose to output HD video quality.
If you are wondering how to use VideoCruise from an overall perspective, click this link to get detailed information.
Solution 3: How to convert m4v to mp4 with Toolkit
When speaking of Toolkit, it is really a nice handy tool to edit video, audio, or image in simple clicks. This versatile toolbox can be well embodied by the proverb a sparrow may be small but it has all the vital organs. Now let’s check how it converts m4v to mp4 easily.
Step 1: Select Toolkit and add video source
Step 2: Choose output video parameters
After loading m4v video source to this easy-to-use m4v to mp4 converter, go to customize output video quality via the available drop-down options. You can choose video codec, resolution, quality, and bit rate etc.
Once done, hit the Start button and locate the finalized output via the File button. Aside from converting m4v to mp4, you can convert other video files to MKV format for specific uses.
Sometimes you might want to normalize audio when watching a video footage captured on your own. In this case, do not forget to ask Toolkit for help.
PART 3: Conclusion
Now you might have got the hang of how to convert m4v to mp4 in 3 ways with the best 3-in-1 desktop software. Apparently, this m4v to mp4 converter works well for diverse purposes. Above all, it comes at a rather cheap price for full advanced features. Anyway, if you hate software installation when performing m4v to mp4 conversion, you might turn to online m4v to mp4 converters. But you need to endure pop-up ads when converting m4v to mp4. Most free online m4v to mp4 converters attempt to attract massive clicks via free conversion service.
By the way, there is other way out there if you want to enhance video quality via a professional video enhancer tool in order to upscale low-res videos to 4K. DVDFab Video Enhancer is always waiting for your free download.
