From Any Video to Playable DVDs Made Easy
Extensive Format Support
Create DVDs from 200+ Video Formats Freely
DVDFab DVD Creator can burn standard DVDs from more than 200 video formats, including AVI, MP4, MKV, M2TS, FLV, MOV, VOB, Xvid, TS, and more. Whether you're preserving travel footage, burning downloaded videos, or archiving family events like birthdays or weddings, this tool makes it easy to turn digital videos into physical keepsakes.
create DVDs from video
Flexible Output Options
Burn Any Video to DVD Blank Disc or Save as ISO/Folder
DVDFab DVD Maker allows you to burn any video to blank DVD discs, with full support for various formats like DVD-9, DVD-5, DVD±R/RW, and DVD±R DL.
You can also choose to save your DVD output as an ISO file or folder, making it easier to watch your movies on laptops without optical drives, or play them on home media servers and players.
burn video to DVD, ISO, folder
Broad Playback Compatibility
Burn High-quality DVDs Playable on Multiple Devices
This best DVD Creator lets you create high-quality DVDs from personal or online videos, preserving original visual clarity.
The resulting DVDs can be played smoothly on home DVD players, game consoles like PS5 and Xbox, or media player software such as PlayerFab, ensuring broad compatibility and a great viewing experience on your favorite screen.
output high-quality video
Personalized DVD Menu Design Options
Personalize DVD via Menu Templates
Customize Menu Templates with Your Own Style
Enhance Your DVDs via Free Menu Templates
DVDFab DVD Creator boasts multiple sets of static and dynamic menu templates to take your homemade DVDs to the next level. The built-in menu library with stylish templates will be updated regularly to meet your diverse DIY needs.
Besides, all templates enable you to switch audio tracks and subtitles, meaning you can create DVDs that support multiple languages.
Design DVD Menus with Your Personal Touch
Make Your Video Outstanding with Built-in Video Editor
DVDFab DVD Creator features a video editor that lets you easily crop, trim, add watermarks and filters, edit subtitles, and adjust brightness and contrast to customize your videos perfectly.
Crop
Crop
Crop video to desired aspect ratio
Trim
Trim
Trim unwanted clips to make a video just right
Watermark
Watermark
Add a watermark (image/text) to the video
External Subtitles
External Subtitles
Add external subtitles (SRT/ASS format) to the video
Brightness
Brightness
Adjust brightness, contrast, and saturation
Chapters
Chapters
Customize video chapter content
Accelerated Burning with Smart Organization
High-Speed Disc Writing
Achieve 50× Faster DVD Burning with GPU Acceleration
DVDFab DVD Creator enables you to burn multiple video formats onto a single DVD and customize their playback order as desired. With real-time preview, you can instantly check whether the final result meets your expectations.
Moreover, thanks to advanced GPU acceleration technologies including Multi-core CPU, NVIDIA CUDA, AMD, IQS, Video ToolBox, this free DVD Creator delivers up to 50× faster burning speed compared to standard programs.
Faster DVD Burning Speed with GPU Acceleration
Smart Meta Info
Output Friendly Metadata for Media Server Integration
DVDFab DVD Creator boasts an exclusive Meta Info feature that can automatically synchronize all the meta info of the source video, including movie title, cast, and cover.
Moreover, this DVD creator software is able to generate .nfo file by default. All the meta info will be clearly displayed on the media server, like PlayerFab and Kodi, making it much more convenient for you to create and organize your own DVD library.
output friendly metadata
Launch DVDFab and load the source videos.
Step 1. Launch DVDFab and load the source videos.
Run DVDFab 13 and select the Creator > DVD Creator module. Load your video by clicking the Add button or simply dragging and dropping the file onto the main interface.
Step 2. Customize your DVD and create a DVD menu.
After loading the source video, click Advanced Settings and choose the output size and quality you prefer. You can also click Menu Settings to select and customize your menu.
Step 3. Start burning DVDs for free and fast.
Select the output directory in Save to Part, and click the Start button to begin creating your DVD. This DVD Creator will provide detailed progress information throughout the process.
Watch the video
80+ Million People Like Our DVD Creator Software
System Requirements
Icon
Windows 11/10/8.1/8/7 (32/64 bit)
Pentium 500 MHz
2GB of RAM
20GB of free hard disk space
A DVD-R (W) or DVD + R (W) Drive
Input
MKV, MP4, AVI, M2TS, TS, MOV, WMV, WMA, 3GP, FLV, M4V, VOB, etc.
Output
DVD-9, DVD-5, DVD+R/RW, DVD-R/RW, DVD+R DL, DVD-R DL
Frequently Asked Questions
  • What Is the Best DVD Creator Software?
    When it comes to creating DVDs, DVDFab DVD Creator stands out as the best option available. It supports a wide range of formats with high-quality output and customizable menu templates. This DVD Creation software also allows users to tweak various settings, such as video quality, aspect ratio, and disc type, making it suitable for both novice and experienced users.
  • How to Create a DVD That Is Compatible with Any DVD Player?
  • Is DVDFab DVD Creator Free?
  • Can I Make a DVD with Menus for Free?
  • How to Choose Between Paid and Free DVD Creator Software?
  • What DVD Creators Are in Windows 10?
  • Does DVDFab DVD Creator Support Burning Video to Blu-ray?
Contact icon
Contact Us
Can't find the answers you're looking for? If you have other problems, don't hesitate to contact us.
Our Service Team is always ready to help. Your problem will be addressed as soon as we can.
Contact Us
Tips & Tricks for Easy DVD Creation
  • Top 10 Free DVD Makers for Windows & Mac – Create Your DVDs Easily!
    This guide reveals 10 tested free DVD maker software for Windows and Mac systems, helping you burn homemade movies and commercial discs, design custom menus, and avoid purchasing expensive software.
    By Wenny Yan - Sep 9, 2025
  • How to Convert MP4 to DVD Format for Free on Windows, Mac & Online
    How to convert MP4 to DVD format for easy playback on any DVD player? This article provides a comprehensive review of the best MP4 to DVD converters available for both Windows and Mac OS to help you do that. Each software is evaluated based on its features, ease of use, and conversion quality.
    By Diana Smith - Aug 26, 2025
  • 7 Best & Free DVD Menu Creators: How to Make DVD Menu on Windows & Mac
    Want to make a custom DVD menu templates for your DVD movie? Here we will explore the top 7 free DVD menu makers compatible with Windows, Mac and Linux, and provide detailed steps to make DVD menu.
    By Diana Smith - Jul 21, 2025
