Kindle Not Downloading Books? 8 Easy Fixes That Work
Summary: To fix a Kindle book not downloading, cancel the stuck download and retry it first. If the book still stays queued, restart your Kindle, reconnect to a stable Wi-Fi network, and tap Sync to refresh your library. This article walks through 8 practical fixes for Kindle book not downloading issues, from basic connection and sync checks to account, delivery, storage, and older-device problems, so you can identify the real cause and get your book downloaded again.
When a Kindle is not downloading books or a title stays queued, match the symptom before repeating basic fixes. Check Wi-Fi, storage, sync, and filters first, then separate a single purchased-book failure from an app, firmware, service, or older-device problem. This path shows when to redeliver a title or contact Amazon Support.
Quick Fixes to Try First
- Make sure your Kindle is connected to Wi-Fi.
- Turn off Airplane Mode.
- Remove filters such as Collections, Docs, Unread, or Downloaded.
- Restart your Kindle and download the book again.
- Sync your Kindle.
- Check whether your Kindle has enough storage.
- Check an older Kindle's support status before resetting or deregistering it.
Why Kindle Books Fail to Download
Start by identifying whether the problem affects the Kindle itself, a mobile app, or one particular title. Device-wide failures usually point to connection, storage, account, software, or service issues. A single missing title needs an order, license, compatibility, and delivery check instead.
Check the Device, App, and Book Source
| Symptom | Where it happens | First check | Next step | Escalate when |
| Several books will not download | Kindle e-reader | Wi-Fi, filters, manual sync | Storage and software | Queue persists |
| App downloads fail | iOS or Android | App update and account | Sign out and retry | Other devices also fail |
| One purchase is missing | Amazon library | Order and account | Redeliver to device | Other titles download normally |
| Kindle Unlimited title fails | Kindle library | Membership and title status | Sync and redeliver | Multiple eligible titles fail |
| Libby loan will not arrive | Libby and Kindle | Loan and Send to Kindle | Retry delivery | Delivery remains queued |
Device and service availability may change, so check Amazon's official support pages for your specific model.
Older Kindles May No Longer Support Downloads
As of May 2026, Kindle and Kindle Fire devices released in 2012 or earlier can no longer purchase, borrow, or download new content from the Kindle Store. Previously downloaded books may remain readable, but factory-resetting or deregistering an affected device will not restore support for new downloads.
Fix Kindle Books That Will Not Download
Work through these checks in order. If a book still will not download after the basic device checks, move to the title-specific or queued-download path instead of repeating the same steps.
1. Reboot Your Kindle
Rebooting a device can resolve various technical glitches or minor problems, as well as address incomplete tasks. When you face minor problems with your Kindle tablet, the initial step you should take is to restart it. Restarting assists in resolving temporary software errors, refreshing system memory, and establishing a reliable connection to Amazon’s servers.
Here is the process for rebooting your Kindle device:
Simply press and hold the power button till a menu shows up.
Choose Restart or turn off the device, and then power it back on.
Please attempt to download the book once more.
If the tutorial above does not work, you can try to force restart the Kindle device by pressing and holding the power button until the device restarts.
2. Double-Check the Internet Connection
To download books to your Kindle, a stable internet connection is needed. So, if your Kindle Book isn't downloading, it could be due to a slow or unreliable internet connection.
Check the following before moving on:
Reconnect the Kindle to Wi-Fi, then try another book or another network if one is available.
Confirm that Airplane Mode is off.
Use the Kindle's sync option after reconnecting.
If downloads still fail on a working connection, continue to the account, title, software, or queue checks below rather than repeatedly resetting the router.
3. Clear Out Storage Space
When your Kindle storage reaches capacity, you won't be able to download new books. To resolve this issue, you should manage your storage by removing e-books that you no longer need or have already completed reading.
Check the storage space by following the steps below:
Navigate to Settings on your Kindle.
Choose Device Options, followed by Advanced Options.
Select Storage to view the available space.
Make sure your Kindle has sufficient storage room for the new book. If it doesn’t, think about removing books you’ve already read to make room for the new one.
To remove a book, press and hold the book, then select Delete or Remove from Device.
4. Review Digital Orders
When one purchased book will not download but other titles do, review its digital order before changing device-wide settings. Confirm that you are signed in to the Amazon account used for the purchase, that the title is compatible with the intended device, and that any license or simultaneous-device limit is not blocking delivery.
Follow the steps below to confirm your order on Amazon:
Navigate to Manage Your Content and Devices, then proceed to Your Orders.
To view the list of all your digital orders, click on the Digital Orders tab located at the top.
You can now view all the orders you have placed and opt to download the file once more.
5. Manage Content and Devices
An important update: Amazon removed Download & Transfer via USB for purchased Kindle books on February 26, 2025. Manage Your Content and Devices can still help you review eligible titles and select a delivery destination, while this guide to download Kindle books explains the current local-download options. This change does not affect USB sideloading of personal documents.
You can also manage your content and device settings to resolve issues with Kindle not downloading books. This section allows you to view books that are not available on Kindle as follows:
Open Amazon and sign in to your account.
Select the All tab, then tap on Kindle E-readers and eBooks.
Navigate to the Apps and Resources part and choose to Manage Your Content and Devices.
Find the book that isn't downloading and select More actions.
Choose the option to deliver an eligible title to the Kindle or Kindle app you are currently using, then sync that destination.
6. Re-download the e-Book
A download can stall before it finishes. Cancel the affected title if that option is available, reconnect to Wi-Fi, run a manual sync, and then request delivery to the intended Kindle or Kindle app again.
Please attempt to re-download the book by following the tutorial provided below:
Remove the app or E-book that you are having trouble viewing.
Then, retry the download and confirm that the book is being sent to the intended device.
7. Check Kindle Software and Service Status
Check whether your Kindle or Kindle app has an available software update, but do not treat an update as a definite fix for queued downloads. If a failure began after a recent update, or several books remain stuck after Wi-Fi, storage, sync, and redelivery checks, the issue may require Amazon service or support review.
Here is what you should do:
Check that your Kindle has access to Wi-Fi.
Next, go to Settings and select More in the top-right corner.
After that, select Update Your Kindle and proceed with the instructions provided.
Before considering a factory reset, compare whether another title or another Kindle source can download. A broad failure pattern is more useful evidence for Amazon Support than another cycle of restarts.
8. Contact Amazon Support
Contact Amazon Support when a title remains queued or stuck at 1% after restart, Wi-Fi reconnection, manual sync, and redelivery, or when multiple books fail on a supported device. Account, delivery, title-license, firmware, and service issues may need Amazon's review.
Go to Amazon’s Help & Customer Service page and describe the affected title, device, Kindle app if relevant, and the checks you have already completed. That information helps separate a single-book delivery issue from a broader service problem.
Fix a Kindle Book Stuck in Queue
A book that remains queued or stuck at 1% after the basic checks needs a more targeted sequence. Repeating Wi-Fi and restart steps has little value once those checks have already failed.
Retry Delivery Before Repeating Basic Fixes
Cancel the affected download if the Kindle or app offers that control, then retry it.
Run a manual sync on the intended Kindle or Kindle app.
Use Manage Your Content and Devices to send the title to that destination again.
Compare the result with another purchased title or, for a library loan, the original Libby delivery.
Escalate a Persistent Queue or One-Percent Stall
If the same title remains queued after retrying delivery, check for a broader Amazon service issue or a recent firmware-related pattern. If several titles from different sources fail in the same way, contact Amazon Support with the device model, affected titles, and the point where each download stops.
When One Purchased Book Will Not Download
If other books download normally, focus on the affected title's order status, Amazon account, device compatibility, license limits, and selected delivery destination. A local-file workflow is separate from Amazon's official delivery feature and does not repair an Amazon purchase, account, server, firmware, or unsupported-device problem. For content you are authorized to access, where permitted by platform terms and applicable law, BookFab Kindle Converter works with the Windows Kindle app to identify eligible locally available Kindle books and export EPUB or PDF files, retaining cover, title, and author metadata where possible. BookFab's broader product line also connects ebook conversion with audiobook creation, but that is separate from Kindle delivery troubleshooting.
On a computer, the folder used for locally available files varies by platform, so knowing where Kindle books are stored on PC can help distinguish a completed local download from an unresolved delivery failure.
A limited trial may be available, with its scope set by the current official policy. This option is for readers who want to organize eligible local titles in a personal digital library after diagnosing the actual download issue.
Export eligible locally available Kindle books as EPUB or PDF files.
Manage conversion tasks for multiple eligible local titles.
Supports the Windows Kindle app environment as platform support changes.
Step 1. Prepare Kindle for PC
Before starting, use Windows with the Windows Kindle app installed, and make sure the Kindle books are ones you are authorized to access and that are available locally. Sign in with the Amazon account that provides access to the eligible titles, then download the books you want to convert. BookFab Kindle Converter detects locally available Kindle books through the Windows Kindle app environment.
Step 2. Install BookFab Kindle Converter
Install BookFab Kindle Converter, then open it to prepare the local-file conversion.
Step 3. Load Your Kindle Books
Inside the program, click the Refresh button so the software can automatically detect the books you previously downloaded via Kindle for PC. Your Kindle titles will then appear in the book list.
Step 4. Select EPUB or PDF and Convert
Select the eligible Kindle books you want to convert, select EPUB or PDF, and start the conversion.
Frequently Asked Questions
Why will a Libby book not download to my Kindle?
Confirm that the loan is still active and that you completed Libby's Send to Kindle delivery for the Amazon account and Kindle you are using. Sync the intended device, then retry delivery. If both Libby loans and Amazon purchases remain queued, check the broader device, firmware, or service path above.
AWhy does a Kindle book stay queued or stuck at 1%?
After restart, Wi-Fi reconnection, manual sync, and redelivery, compare another title or source. If only one title is affected, follow the single-title checks; if several remain queued, use the service or firmware escalation path.
ACan an older Kindle still download newly purchased books?
No. Kindle and Kindle Fire devices released in 2012 or earlier lost access to new Kindle Store downloads, so the model-support cutoff is more relevant than another Wi-Fi or reset attempt.
AWhy will one purchased book not download when others do?
Start with the title's order and delivery destination, then check the signed-in account, compatibility, and license or simultaneous-device limits. If several books fail, return to the device-wide checks instead.
AFinal Troubleshooting Checklist
Start with Wi-Fi, Airplane Mode, filters, storage, restart, and manual sync. If one purchased title fails while others work, review its order, account, compatibility, license limits, and delivery destination. If several titles stay queued after redelivery, check software and service symptoms, then contact Amazon Support.
A factory reset should not be the default next step when a queue persists. A local-file workflow such as BookFab Kindle Converter is separate from troubleshooting and may suit eligible locally available titles, but it does not repair Amazon account, server, firmware, or device-support failures.
![How to Convert Kindle Books to EPUB Easily [2026 Verified]](https://r5.dvdfab.cn/upload/bookfab/en/convert-kindle-to-epub-RDlf.jpg)
